datman
Everything posted by datman
  1. in order to upload the picture It had to be no more tha 97kb which is why its so poor
  2. yes i tried different wheels on the same hub and they were fine. seems the holes are slightly off centre. Here is the picture of the car that you couldn't see how do you get the pictures to appear full size in the message window?
  3. got a few things left to do but its looking good! http://www.zclub.net/forum/attachment.php?attachmentid=2096&d=1154118148 http://www.zclub.net/forum/showthread.php?t=7411&page=2&highlight=wheels
  4. Total cost for all 4 shocks and struts including materials is $1200 so far, oh and $140 for springs
  5. Hi Yes the adjustment is made from the top (hex nut) only rebound, bump is fixed although this guy also makes double adjustables. All valving is custom, I hade the shock bodies machined to the length i wanted and they made the internals to suit. I will get some pics of the internals. The guy that made them was the original owner of AVO shocks. adjustment is easy, they give you a plastic thing that sits on the hex nut and you turn it to adjust, can be done from under the bonnet (hood) I asked for compression to suit my 250lb springs, they usually set it for much higher as they mainly make race shocks. International shipping is no problem
  6. http://www.zclub.net/forum/showthread.php?t=7340&highlight=struts finished pictures here cost £300
  7. Guys I have just had some custom aluminum shocks made for my 240 by a local company. If you have heard of AVO shocks, well this guy is MR Avo! has now started another company and did a very nice job on some fully adjustable inserts. He also make double adjustables at a fraction of the normal cost. I doubt with the current exchange rate will help but if anyone wants to give me dimensions and spring rates I can get you a cost. Cheers
  8. Guys I have just had some custom aluminum shocks made for my 240 by a local company. If you have heard of AVO shocks, well this guy is MR Avo! has now started another company and did a very nice job on some fully adjustable inserts. He also make double adjustables at a fraction of the normal cost. I doubt with the current exchange rate will help but if anyone wants to give me dimensions and spring rates I can get you a cost. Cheers
  9. Mark, I can get you a cost Friday as thats when I get the bill. I would imagine he will charge me somewhere near £180 so times that by 1.7 for a rough dollar cost.
  10. Yeah will do, if you look at the strut it has been machined down to fit all the way down in the hub, it will then be welded (properly). There will be no chance of it falling out. The guy who is making them makes some serious stuff, these are like scrap metal toys to him!
  11. It was just regular steel tube, machined to shape with a thread cut on the outside, a small disc welded on the bottom and a nut made to go in the top to hold the dampers secure. I'm thinking I'll get the next set made in stainless. Do you think there would be enough interest so sell a few sets? not for profit just to cover costs
  12. Hi Guys Here are some pics of the struts I have had made for my 240. They are shorter than standard with fully adjustable custom made inserts. The hubs had the original bored out and new tubes fabricated with thread on the outside. Just got to weld the tubes inot the hubs now
  13. My 240 had the larger OD tubes like fitted to the 280's, a guy I know took my struts, cut them at the hubs, borded the hubs out and fitted new steel tube with an outside thread cut all the way up. Much neater solution than welding slip on tubes over the top. It wan't hard for him to do, I think it was around $75 a corner and for that he made spring 2.1/4 spring platforms and the gland nut to hold the shocks in the tubes. Will post some pics if you'd like to see. I also had some custom length fully adjustable shocks made....now these were pretty expensive. $735 for cash:o
  14. Mine has unique customs built struts and shocks, fully adjustable aluminium shocks all round. Struts have had the tubes bored out of the hubs with new short tubes welded in place, also have thread up the whole length of the strut giving a very wide range for spring length adjustment. Body wise..ZG flares and 17"x9.5 3 piece split rim ultralites($2800) without tyres...255/40/17rear 234/45/17 front, fibreglass bumpers and spoilers on order. Will post some pics soon.
  15. http://www.grapheine.com/bombaytv/v2/play.php?id=19896 Part 3
  16. Ok I will make another episode later today
  17. http://www.grapheine.com/bombaytv/v2/play.php?id=19033 part 2 http://www.grapheine.com/bombaytv/v2/play.php?id=19113
  18. Nice thread, some good info there. I removed my front struts and had a guy machine the old tube out of the hub, he then replaced the tube with a thicker section tube and cut a thread down the whole length and made adjusting rings to suit. Cuting a thread inside was no problem and he also made the shock retaining nuts. The shocks I'm using are custom made fully top adjustables.
  19. The VIN number checksout , the only reason I had some concerns was another member explained that the car was a 76 not a 72 from looking at the advert http://www.datsun240z.co.uk/parts_sales.htm Im looking/buying the car tomorrow if it all checks out. I have done a background check on it and its all good. vin#HS30-101293
  20. Yes I realise the cosmetic differences like bumpers, Pop n wood explained just what I wanted to know. Things like the door latch changes and chassis rails. Thanks guys
  21. Hi I am about to buy a 240z 1972 and would like to know if there are any tell tale signs to body swaps? I have searched and not found the answers I'm looking for. I have checked the car details out and all seem to tie up but didn't want to get caught out and find that I have a 76 body with 72 vin numbers welded in! Are there any parts of a 72 240z body that are unique to that model? Any info would be much appreciated. Thanks
  22. BTW the car in question is a 240z fitted with a 2.8, stage 2 cam, full performace exhaust, ported and polished head, electronic ignition and triple twin webers...220BHP!
  23. I guess I have been a little boisterous in my remarks for a new member. I guess I've had one too many girlfriends,meaning I tend to snap at comments like "what if","you really should", "why haven't you" you get the idea . The funny thing is I have had SR240Z's car as my screen saver for a while so it was very nice to actually here from the owner. I would hate to copy someone elses car but I'm having a hard time on this one!. SOT here but why do women find the cars that men think are gorgeous, ugly? ....Lambo's, Lanica Evo, Audi quattro(rally) to name a few. I wonder if Lesbians like powerful looking cars? no offence to females that bat for the other side....Respect! Thanks for the welcomes/Info
  24. But then again you Ausies are just a bunch of criminals! Being upside down obviously gives you a different angle on things. P.S only kidding!
  25. Dave I didn't make a stupid comment about a Yank, a yank made a stupid comment. I take it you think I am trying to insult the guy by calling him a yank,I wasn't trying to. I lived in the Staes for a few years and think its a great place to live. I made a lot of good friends. I do appreciate any info given I just can't see the point in leaving a post "use the search" maybe "have you tried searching?" I would answer "yes and I didn't find what I was looking for, this is why I am asking the question". I thought that was the idea....to share knowledge to help others in the Z community. Other members here seem to have no problem in answering my question without making assumptions. He assumed I hadn't searched and I assumed he was an *** fair enough! As for a slap in the face, how can you say that when I have thanked all those that bothered to help. I do agree that is far easier to search and read..which I did, I then asked here as I don't want to spend a few thousand $ and end up with wheels so far in it looks like an E-type from the back..before anyone with an E-type gets upset and post a sarcy remark...I spent a lot of time sat in the back of one as a child and think they are great cars. Flame suit on!
