Everything posted by Pennyman
STOLEN: Blue 280z in Downtown San Jose
Pennyman replied to Pennyman's topic in S30 Series - 240z, 260z, 280z
Hey, car was found in Cupertino behind some mall last Monday. Insurance adjuster is coming tomorrow to come asses. Fools took the smoked signals, wheels/tires, stereo, speakers and center console, strut braces, and a bunch of interior trim. But they left basically everything that's hard to get or expensive (coilovers, bumpers, engine, zx 5speed and diff) They could have messed it up a lot more so I think I got off easy. The thing that pisses me off the most is that the forklift that courtesy tow yard used to move my car around totally crushed the lower tank of my radiator. Now I have to replace that too! -
Yeah, I'm pretty down. The memories are worth more than the car is worth in my opinion. It was my first car. It was DEFINITELY stolen. My landlady has a security camera and it shows 2 guys watching for traffic while a 3rd dude drives off in it. Can't really make out their faces though. I've been checking craigslist too. There are certain features on this car I can recognize from a mile away, even if it's repainted. Subtle things that only a Z owner would understand. BTW, it has no cat on it, so it won't pass smog (its a 1976), the tires are bald and the clutch is going out, and the registration is due in Dec. Vin# HLS30283344 -
Hey dudes. My blue 1976 Datsun 280z was stolen last night from the corner of San Fernando and 12th st. in San Jose. It was there at midnight when I came back from the school shop (working on FSAE) and this morning it was gone. If you guys see this car, let me know. plate# 4PVR522 can't remember the vin off the top of my head mods: GC coils, tokico illuminas, MSA sways, 83 5spd and rear end, and some other random stuff.
I got some MOOG T/C rubber bushings and they seemed to be the right size. They sure work better than the old ones for sure. Good deal at $15.
Don't forget the fuel lines! I found that the lines that go from the tank to the fuel pump were WAY too short to allow you to access the bumper shock without disconnecting them. And yes I did smell like fuel once the project was over. should have plugged them up with something instead of simply trying to angle them upward haha:icon56:
Here's a pic of mine after the swap. Made my own front brackets similar to what was on the previous page. Used the stock 240z rear beackets bent a little to fit in the rear.
BTW, Kaaz and Tomei LSD's are made in the same factory, they are identical units. It's like saying "Buy a power brute or a nismo".
I'l probably end up getting on of these, considering the powerbrute is now out of comission (japan earthquake destroyed the tooling). Just got a 5 speed out of a 83 zx and I'll be going back for the 3.90 diff tomorow. My future diff will most likely end up in that one. Should be fun.
Pennyman replied to k3werra's topic in Brakes, Wheels, Suspension and Chassis
Do I even need to say? -
Those are amazing. Looks like good craftsmanship. I don't think the isolators experience anything but compression when the cars on the ground and a little tension when it's on jackstands, so your units should work as long as they fit well. These look like the prefect solution to adding some ride hight to those cars which have maxed out the coilover sleeve and still want to go a little higher, or whose lowering springs make it difficult on around-town journeys.
Steering pops, wanders while turning
Pennyman replied to Pennyman's topic in Brakes, Wheels, Suspension and Chassis
Not recently, but that shouldn't be the issue here should it? My first guess would be a mechanical issue, not an allignment issue. Seems to me that an alignment couldn't solve the problems I've been having, or am I mistaken? -
Wheel bearings are not loose. Infact, my car passed tech at an autoX last month, and I haven't driven much since then. It's also not the steering insulator, because I've upgraded to the urethane unit. I guess I'll keep chasing it down... -
I have coilovers, sectioned about 1.25 inches. Sportmax 002 16x8 with 225/50 Falkens. I'd say its at least 1.75 inches lower than stock. I'm sure I do have some bumpsteer issues, but I can't remember it being this bad when I had my old 14x7 rims on there, which leads me to believe that something is wearing out. Especially since the steering wheel doesn't come back to center after I hit bumps/go around corners. -
Hey. Just got some new wheels and tires and it's really magnified my steering issues. I just replaced both steering outer tie rod ends, and the problem has persisted. My symptoms: Eveytime I turn the wheel and back (as if i was on a slalom) I hear a pop from the passesnger's side front. I think it might be either the lower ball joint (under the steering knuckle) or the inner tie rod on the steering rack. This noise only occurs while the car is moving down the road. I cannot recreate it when the car is stationary. When I'm cruising down the road, and the passenger wheel hits a bump, the steering wheel changes angle a little, like something was just knocked out of alignment. As it roll over things like manhole covers and bumps, the car darts left and right. Sometimes pulling left, and several bumps later, pulling right. I thought it was the tie rod end, so I replaced it, but it still occurs. This leads me to the two things I mentioned earlier. I think Pusher had a similar issue with his steering (changing angle while driving), but it was never reported what was causing the problem. Any advise would be apreciated. I'll be skipping an autoX to confront this problem unfortunately, so I'd like to be headed in the right direction before tearing things apart.
Sportmax002 wheels - they fit!
Pennyman replied to bubbleguinea's topic in Brakes, Wheels, Suspension and Chassis
Actually, he sold them already, I spoke too late. Blacks are on backorder in the groupbuy as well. I contacted Next Level Motoring and they said that Sportmax gets about a containerfull of wheels per day. The also said that Black was the ONLY color they were out of so they should be getting more soon. -
I'm going with azenis too. But I've got coilovers so I might have to roll/trim the inner fender lip to keep things from rubbing. On their highest setting they're about as low as the car shown in the picture. -
I'll buy them. Check your PM. Get back to me ASAP! -
It's actually a catapult that I built for an engineering statics class. I tried to keep the design simple, it used a length of surgical tubing to create the tension needed to fire. I'd say it shot a balloon about 100-150 feet horizontally. It hit the target we needed to hit to get a good grade too. I hope you like my car as well, haha.
Damn, I would have. But I just got mine from Next Level Motoring for $416 shipped, plus 30 for lugs. I hope they fit with a 2 inch drop. (lower than whats shown here...) I might have tucked tired with 50 series rubber, amazing! -
First time I've shown the new look...
They fit. What a shocker. Seems like everyone's getting these wheels...even me... -
Talk to Big Phil. I believe he's done the swap.
Sport Max 002 wheels falling apart..
Pennyman replied to proxlamus©'s topic in Brakes, Wheels, Suspension and Chassis
+1 -
Hey all. I'm debating whether my car is too low for 16" rims with 225/50 tires. I have coilovers with sectioned struts, and right now they're maxed out at the tallest setting. The wheels I have on there right now are 14x7 with 195/70 tires with +0 offset. I want to upgrade to 8" rims with +0 but that's another story. I'm afraid that the added diameter will begin to "tuck" the tires, and become more of a problem than a advantage due to clearance issues and when driving on bumpy roads. Or if someone can suggest some sort of mod to help me raise the back end (perhaps increase the spring rate so there's less compression to begin with?) Thanks a lot guys
It's a toss up between these wheels in flat black or the sportmax 002 15x8s for me. I'm pretty set on 8" wheels. This thread may help me make up my mind.
