JSM
    5
Everything posted by JSM
  1. I searched both TVM website and "TVM Website" with nothing found. Does someone have the link to TVM? Tried google and yahoo too. Thanks
  2. Family friend? I know no one in my family that would give me that kind of a deal, nor none of my friends! You should give him/her another 500 just for kicks to keep that friendship going! Unless their rich. In that case, pass their number along to me!
  3. I'm looking at this truck. Its got 96K on it looks to be in pretty good shape. Not a king cab, just a plain old short ped. Only a two owner, original FL truck. Is it worth $3200? According to KBB it is not, $2500 or so. Checked ebay and not a lot for this year but the few I found were in the 25-2700 range. Is the 4 cyl in these trucks pretty stout? Timing chain? I'm wondering if KBB takes into account the demand for small, good running, little trucks? Any advice? Thoughts? Any major concerns, known problems? Things to look for?
  4. Drifting around a road course? Maybe it's just not for me. Seems like it would be so much faster to driver normal.
  5. Instead of me wasting time replacing parts are there any "good" front end specialsit anyone would recommend. I've got a bad shimmy when I step on the brakes. Thanks
  6. I want to start building my own exhaust and welding intake plumbing. What would be a good welder for this type of application? Looking for something reasonably priced, but decent quality. Thanks
  7. Yes she was attractive, no I couldn't do that and she is flexible, but yes I thought the video was stupid. Not trying to offend anyone.
  8. If the car is lowered due to shorter stiffer springs, do the bumpsteer spaces affect the ride height at all?
  9. Check all the vacum hoses as well?
  10. I searched for velocity stacks for the SUs and folks suggested TVM. Any other sources? What is TVM's web address? If you know of any other sources can you post the web address? What are they worth used? Thanks!
  11. For XMAS, Just ask for cash. That way there is no mix up w/ what you want.
  12. I would change the plugs for sure. Being that it has been sitting so long I'd venture to say the vacum hoses are probably shot. Especially in the extreme cold as you are in. I'd replace all of it because it is cheap. Sitting 25 years also i'm suprissed it started at all with the injectors sitting that long. I'm sure their dirty. Did you flush the lines? Who knows what kind of build up are in those lines. And as you run it, more of it (build up from the old gas) will probably come off.
  13. JSM
    Test stand?
    I think Zero and my concern is just not touching are cars until it works even minimally. I don't want to lose the use of my car at all unless I can have planned down time. I'm always amazed at how a few hour project on my Z turns into an all weekend thing. I've got the space in the garage so I don't mind setting up the stand.
  14. JSM
    Test stand?
    Great question. I'm thinking of doing the same thing. I missed out on my 83zx turbo car purchase for 400.00 so I'm still looking. My concern was the starter since if I recall it bolts up to the tranny. How would you run this and cap the drive shaft end w/out oil coming out? Also would you mock the piping for the intercooler?
  15. So how much is the total Package? Includes VR sensor mount, EDIS 6, Escort Crank wheel, etc?
  16. Hey Nion I know this is an old post but what was the outcome of your Hayden Controler? I just bought one myself.
  17. Picked up a Hayden Adjustable Controler from Pep Boys good from 160 - 210 @ 30AMPs. $44.99. Couldn't find a Flexalite, even though Napa suppossedly sells them. Looked all over Orlando.
  18. For controling the fan, which wire is best to connect into for the ignition? 73 240z.
  19. Where do you buy Spal and Flexlite controlers? The one I picked up from Autozone did not have a tempature adjustment screw. It was 24.99. Pepboys had one which had a screw adjustable from 160-210 but was 44.99. I did search on the fan but didn't find anything about the controler. I was curious to what other folks had installed. Thanks! Tried to remove the ~~ to no avail. Even in advance mode.
  20. I'm upgrading to an aluminum radiator from Jags that run and replacing the mech. fan w/ an electric. Can you guys tell me where you got your Electric fan control unit from? What brand? Is your temp adjustable? Or are you using Megasquirt to control the fan? This is for a 73 NA w/carbs. And what electric fan did you find that fit best from the Junk yard? Model of car. Thanks!
  21. Welcome! This is an amazing site! I always thought Dirty injectors would result in a poor idle? I would check the timing, and fuel pressure. Make sure the plugs are clean along w/ the air filter and fuel filter. Check all hoses including vacum, PCV valve, etc. How long was it sitting? Do you know the history of maintenance?
  22. Let me be more specific. What year cars/trucks have EDIS in Ford. Is Ford best to use? I was under the impression that the coil pack came from a Six cylinder and the VR Sensor and 36-1 came from an escort? Is this correct? Did all Escorts come w/ VR and 36-1? Which Fords came w/ EIDS 6? Thanks, just a little clueless! Forgive me If I seem dumb, I'm just trying to get a little better understanding.
  23. Braap, For these Parts below. What year vehicles did u pull them from? Thanks. --------------------------------------------------------------- Here are the parts.. 1) Is the Coil pack and EDIS-6 module from an Explorer, Trigger wheel and VR sensor are from an Escort. 2) Crank trigger wheel and VR sensor as mounted on our L-28, ( I did relocate the alternator to the driver side for radiator clearance reasons.) 3) My EDIS Module mounted just under the fender. 4) My coil pack with Magnecor wires. (I used a Chrysler coil pack as its terminals are just like GM-HEI, more options for plug wires). 5) Just a cool photo of a Ford EDIS-8 system sparking on our EDIS test bench, (Yes, an EDIS-8 system destined for a SBC V-8)..
