regggggggg
Everything posted by regggggggg
Datsun s30 3 Piece Spoiler for 240z 260z 280z
regggggggg replied to jc240z's topic in Parts for Sale
i’m interested in purchasing one if you still have these available -
Much thanks to the OP for starting this. i made my own thread as well in the same board.
My 1972 Datsun 240Z was stolen on December 6, 2012. It was last seen in San Bruno, CA near San Francisco Airport. Keep your eyes peeled Norcal and contact San Bruno Police Department (650) 616-7100 or local 911 if you have any information leading to where the car is or who took it. Post any info on here as well if you have seen it. It is very hard to miss this car it has a huge exhaust that sticks out a foot past the bumper. License Plate # 2GAP983 Distinctive Parts to look for if you see them pop up on craigslist: 4x114 Silver Rota Shakotans Grip Royal Grain Steering Wheel Corbeau Forza seats RB20DET Motor w/ aftermarket intake manifold 280Z Air Dam (no front turn signals) Polished Fuel cell with steel braided lines that can be seen from behind Pretty slammed car I spent almost a whole entire year building this car from the ground up after buying it stock and as i finally got it running and ready for the road, it was taken from me. I never even got the chance to enjoy my creation. so with that being said, please please please help me find it.
Hello everyone! I just finished swapping an RB20DET motor into my '72 240Z and it is now running. The only problem is that I do not have a tach or temp gauge hooked up. The tach isn't a big issue right now, but i have no idea how hot my engine is running and i wanted to know if i would be able to hook up the stock coolant temp gauge on the z? I also have a wiring specialties harness that has outputs for those two signals but i don't know if they would work. If anyone has any ideas, please let me know. thanks!
Post Craigslist/Ebay links here- West Coast
regggggggg replied to Phlebmaster's topic in Parts Wanted
1972 240Z motor with 5-speed transmission: http://sacramento.craigslist.org/pts/2710337908.html -
So I've been checking around all the Z forums and I can't get a confirmation of this but... Will the stock RB20DET motor mounts work for this swap? Or will I need to make some modifications to it?
While I was driving home earlier tonight, all my dash lights went out including my rear tail lights and side marker lights. I checked ALL the fuses. Nothing is blown. Rheostat was already bypassed so it can't me the source of the problem. Took a volt meter and ran it IN CIRCUIT between the battery and negative ground wire to check for AMP draw. Readings say its pulling 0.02 AMPS. I'll pull OUT the dash fuse and the reading drops to ZERO. The light switch normally used to turn ON/OFF the dash lights is not working because whether in the OFF or ON position it still draws 0.02 AMPS. Could the switch itself be the problem? OR... Could there just be a short before the switch? And if so, is there a certain way to find the source of the short?
Rota Shakotans.... anyone running them?
regggggggg replied to ComicArtist's topic in Brakes, Wheels, Suspension and Chassis
Yep, thats me -
I'm not sure if this is the right section for this but I was thinking about selling some decals showing love and support for Z's. I have one design down right now... Question is...would anyone be interested in buying any? Or does anyone have any other ideas for design? I can make custom ones as well.
It shouldn't be a problem. but of course you just would have a lot of wheel gap -
Thanks. Don't get me wrong, I am satisfied but I've always loved the wider stance of the Z with the fender flares. -
I have a 1972 240Z. Pretty much stock L24 but i do have 2.25 diameter exhaust piping running from the stock headers and with a Magnaflow muffler. Now be aware that I am pretty new to carbureted engines and I've been told that they do need warming up. But what boggles my mind is that I was at a meet today with another 240Z with pretty much same setup except he was able to just start his car and drive off with no problem. Whenever i try that, my car would struggle and sometimes the engine would die out. Even if i were to just rev my engine while the car is parked, it would make a pop sound and the engine would cut out for a moment but then continue to run. Once my car is at normal running temperature though, it would run perfectly fine. Is there something wrong? any input would help.
Awwwww. I wish I knew about these sooner -
I was surprised as well. I thought they would poke out more too. But the fronts fit perfectly, no rolling needed even with no camber. The back looks like it would poke a little though if I were to straighten it out. But thanks for the compliments. -
Well my tires are stretched and since the car is lowered, the wheels are cambered in a lot. So I'm working on getting rear lower control arms with camber adjustment to straighten everything out and then I'll roll the fenders so I don't rub. Yeah, I personally like the stretched look but I didn't think 195's would give me as much stretch as it did. So I'm gonna go with 205's next time. -
just in the front. -
im on tokico illuminas and ground control coilovers. no rub at all and my fenders aren't rolled. i could go lower but it just wouldn't be practical for me. -
they're actually 15x9 0 offsets all around. i went with 195/50/15's because i thought i would need the stretch to fit them but i could have easily fit them with 205s -
i actually have a set on my Z... -
like the title says: i have $3000 cash to spend on a 240z or 260z. must be in running condition will all or most of interior in place, manual transmission only. minimal rust, and withing the bay area.
