From Tony D at zcars.com Taken verbatim.
ANY Datsun engine can be TURBOCHARGED WITHOUT CHANGING THE PISTONS.
Jeebus guys, SHUT UP ABOUT DISHED PISTONS!
SniperX is ABSOLUTELY CORRECT! At 7psi the 'lower compression' does NOT even REMOTELY come into the picture.
As for SniperX being used to 'MAP Based Vehicles' I'd suggest you search on "Megasquirt" and use THAT as your ECU right from the get-go on the conversion. They are available for $400 from a number of sources, and give you full adjustability.
Matter of fact, I'd say with stock turbo injectors in the block and a Megasquirt, you will easily be able to run 10-12psi of boost on your conversion without an Intercooler simply because you can douse the cylinders in extra fuel to compensate for the lack od density.
Having had a NON-DISH TOP N/A conversion for 23 years, and putting 40K+ miles on it running normal boost at 12psi, and up to 21psi (WITHOUT DISH TOPS) it just maddens me when PARROTS spout and confuse people.
IF YOU DON'T KNOW, SHUT UP!
ARGH!
