milesz
Everything posted by milesz
  1. I recently purchased a 27' x 19' Griffin radiator from a dude on Craigslist. I read on line that this was the size dimension I need for my 240z. I really like the radiator but it don't go down all the way (not fitting). What do you suggest how I can get it to fit? Thanks in advance for any help
  2. I am looking at a set of 16" aftermarket wheels that came off an 88 Honda Accord and was wondering will they fit? They are 4 lug. Thaks
  3. Hi all, I just scored a 1988 zx turbo diff for my 240z. Now, I am looking for the bracket that would allow me to keep the finn cover. Anyone know where I can get one without breaking the bank? Thanks in advance
  4. Ok, I think I have discovered the answer I was looking for. To keep the finns I need to buy or make a bracket or replace the cover. Thanks
  5. I have a 73 240z with a z31 1987 diff (non turbo). I recently purchased a 300zx 1988 turbo diff and was looking for a DIY on how to install it. Is there a write up with pictures anywhere? Any help in this regard is appreciated.
  6. The car rides so much better without the front lowering springs. By cutting 1/12 coil off I got the ride height I wanted and the comfort I need.
  7. Ok, I thank eveyone for their thoughtful responses. I am embarassed to tell you guys what was making that noise. As I said, I was trying to move the car but it would not move. I jacked the car up and checked the tire and it was fine. I tried it again, still would not move. The following morning I decided to cut the other spring while waiting for a friend to come and help. I could not find the spring, so I decided to check under the car and low and behold there it was. The spring was trapped under the car was making the noise. Again, I am embarassed.
  8. I have a 240z and just cut the passage side spring 1 and 1/2 coils and button everything back together. Got in to move the car to do the other side and it seems like something is dragging preventing it from moving. I jacked the car up again and spin the wheel, all good. I can not find anything that can cause this problem. Anyone else had this problem? Thanks
  9. I have a 240z and was just wondering if 300zx or 350z suspension springs would fit the 240z. If so, what mods needed?
  10. All my hazard works. I checked the flasher connection and the green wire is getting power but the white wire sending no signal at all.
  11. Looking for 280z turn signals, hit me back if you gotem. milesj64@hotmail.com
  12. Now, all the hazard lights work ( changed the bulbs). I still do not have turn signals. I also replaced the turn signal switch but no change.
  13. I have a 73 240z and I have no trun signal. My hazard light in the rear and on the front driver side works. But no turn signal. I changed the flasher and still no turn signal. I also checked the flasher wiring harness and the green wire is getting power to the flasher but the white wire is not send a signal out to the lights. Need a little help Thanks
  14. Thanks would be great my cell is 661-910-5467. Looking forward to hearing from you.
  15. Will, thanks for your reply. It happen when it in gear. It can be idling at 5.6 rpm and put in R (initally) it will move normally and then surge to where I have to apply the brakes to slow it down. This also happen when I first take off and at highway speed it like I have a cruse control.
  16. No, it just idles high, but when you put it in gear, you really have to have your foot on the brakes. And sometimes with your foot on the brakes the rear tire tries to spend.
  17. I had it retuned when I changed over the cam and intake. I did not have this problem at first, but now I think about it, have been having this problem for awhile.
  18. No, I do not have the PNS hookup. I have the 4l60e tranny, how do I go about hooking it up?
