IdfMF
Everything posted by IdfMF
OMG!! Steering locked up at 45mph!!!
IdfMF replied to cygnusx1's topic in Brakes, Wheels, Suspension and Chassis
Hi Cygnus, I have been watching this thread hoping that you would find not only the cause but that it was a freak thing. I've owned my 240 since 1979 and now that I am about to unleash it with 400HP and modified everything, I could not help but wonder if this would happen to me. You can damn well bet that I'll be going over the engine compartment with a fine tooth comb looking for loose parts!! Thanks again for bringing this up, Tom -
I am going to use a product called Dead Zone Sound Deadening which I bought off Ebay. It's not cheap and it's kind of heavy, but I'm getting too old to ride around in hot, noisy cars! I haven't installed it yet, but it seems like really good stuff. You can search "dead zone" on Ebay and find the stuff. The seller has 34 sets left as of 10/29. Tom
I scraped all the tar off the floor of my 240Z and removed the firewall padding. I can tell you that it got mighty hot inside the car while I was getting engine dialed in. It was also too loud to be comfortable; sports car or not. I have not driven it on the street yet with the Chevy 350 so that may cool things down a little. I plan on installing heat/sound deadener to keep it reasonable. My deadening material will weigh about 15 lbs. With 400HP I am not worried about this weight gain. Tom
Toyota Echo hands down in my book. So UGLY I get angry when I see one. I'd vote Pontiac Aztec for second place.
Hi All, I have used Myk's Pivot Plate to get my V8 in and out of the Z. It works great. I have not used the more traditional engine tilter, but I can you tell that mounting this plate to the carb flange on the intake manifold works really well. I have used it on aluminum manifolds with no problems. Check it out: http://www.myks-tools.com/index.html Tom
Hi All, I came across this site today. These look beautiful, the price seems reasonable and they have rear sump oil pans. Time to shave down those front strut towers! Tom http://www.karkraft.com/new_page_2.htm
Excellent info and just what I needed. Thanks, John Tom
Brian, I keep forgetting my camera at work, so please forgive me not posting pics of my rear bar setup. I'll do it this weekend. Yes, the Suspension Techniques rear bar (PN 51075) is specifically made to be rear mounted and the AZC Billet Diff mount has provisions for this bar. You can see this set up on the Arizona Zcar website. Tom
kev240Z, I should add that I have not made any modifications to the end links at this point. I am also using Modern Motor Sports Lower Control Arms which may help the fit. I'll try to post some pics later today. Tom
I just installed a Suspension Techniques rear mount sway bar to the AZC billet rear diff mounts. I am using 300ZX TT CV joints and the fit seems to be okay. The sway bar does not hit the CV joints and boots when the car is sitting on the ground. The sway bard does hit when the suspension is at full droop, but this should not be problem. I haven't driven the car yet, so stay tuned for more info. I do believe that others on this site have installed the Suspension Techniques rear bar/AZC billet brace combo with success. Tom
BuZy, I too have the MMS LCAs along with the AZC billet mustache bar and rear diff mount . How is your clearance between the rear mounted sway bar and the axle shafts? I am using 300ZX TT CV joints. At this point I haven't installed a rear sway bar but I am considering the Suspension Techniques rear mounted bar. Tom
Now I can screw up my alignment like the best!
IdfMF replied to auxilary's topic in Brakes, Wheels, Suspension and Chassis
Nice stuff indeed. Who are you going to use to setup your camber/castor/toe? I have the AZC front set up. I also live in the Bay Area and would like to find a good shop for chassis tuning the first time around. I figure I let the professionals set it up first so I can "screw it up" later myself!! -
JTR kit SBC and WCT5 mockup in chassis. pics w/questions
IdfMF replied to bjhines's topic in Gen I & II Chevy V8 Tech Board
Hi Pete, I thought about the after market bellhousing as soon as I saw the placement of the shift mechanism. At this point I would have to pull engine out of the car and I am so close to getting it running. After 16 years of no Z, my anxiousness is getting the better of me! Since I've already altered the trans tunnel, I think it will be easier and quicker to find a shift boot. Tom -
Hi All, Here are some photos of my Pro 5.0 shifter installed on a Chevy T5 with my 350 + JTR combo in a '72 Z. It is a tight fit. The tranny has not yet been aligned with the diff (I'm using a Ron Tyler style mount), but it's pretty close. Since taking these photos I have cut away a portion of the tunnel to gain some additional clearance. The shifter is in 1st in these photos. I am 6' 2" and the shifter falls into comfortable positions in each gear. The stock Z rubber boot really does not work. While it does fit over the Pro 5.0 shift lever, due to the extreme offset of the tranny, it tends to bind the shifter in 1st and 2nd and also pulls the right side of the boot off the tunnel when in 1st and 2nd gear. I will be searching for a shift boot that allows for enough movement while covering the hole in the tunnel. I may start with the '88 Camaro boot to see how it fits over the thinner Pro 5.0 lever. Hope this helps and I'll post more photos as I move forward. The Pro 5.0 shifter is absolutely awesome so I am determined to make it work! Tom -
BJ, Thanks for the idea regarding the Camaro shift boot. How well does the Z center console fit over the Camaro boot? Tom -
Greg, I just replaced my brake lines and went the 90-10 Cunifer copper-nickel line. I bought the line,fittings and rented an awesome flaring tool from Fedhill Trading Co. http://www.fedhillusa.com/ The line was pretty easy to bend. I did not need to use any tools to bend the lines. The rented flaring tool was extremely easy to use and every flare came out perfect. Tom
Is Modern Motorsports still in business...!!!
IdfMF replied to snarpee's topic in Brakes, Wheels, Suspension and Chassis
Hi Ross, Can you please give an update on the Z31 billet companion flanges? Tom Magee -
Moved the Proportioning valve
IdfMF replied to Zmanco's topic in Brakes, Wheels, Suspension and Chassis
I like your idea. I am about to install a bias valve and have been pondering a location. Like you I did not want the valve sitting next to my legs or those of the passenger, nor did I like the idea of having to pop the hood to make adjustments. Besides, this set up will make good use of the two holes that are already in the firewall! Good work, Tom -
HICKL, I went with a Stewart Warner 3 3/8" Maxium Performance tach. I had to remove the clear plastic cover and fab a plastic ring which is glued to the stock bezel and holds the tach in place. I like the 3 3/8" guage because it puts the face of the gauge in the basically the stock position. I think the 5" gauge sits too close for my liking. PM me if you would like some photos. Tom
Hi Tom, I just ordered a set of Z31 axles from CV Unlimited. I spoke to a guy named Greg or Gray. He said he was expecting you. I am hoping Ross has a set of Z31 billet companion flanges that I can trade for my 280ZXTs. Apparently he's been having a supply issue with billet parts. I am only lowering my Z by about 1.5" so hopefully I will not experience the problems you are having. How much is your Z lowered? Tom
I am installing a setup quite similar to yours using Modern Motorsports adjustable LCAs, AZC billet MB and Brace Kit, R200 CLSD. At this point I am going with 280 ZXT CV halfshafts which I'll bolt up to Ross's billet companion flanges and stub axles (if they ever show up). I may switch over to Z31 CV shafts. I was searching today for Z31 CV half shafts and came across CV Unlimited: http://www.cvunlimited.com/mainfram.htm They claim they can design almost any CV configuartion you could ever need. Good luck and great looking under carriage. Do you have any more photos of your Z? Tom M
I got the PRO 5.0 for $199 delivered off Ebay. Bruce at Modern Driveline highly recommends. It's a very stout piece compared to the Hurst model. I do believe it fits both T5 and T56. I am using on a T5.
Rota RB 16X8 on 280Z??
IdfMF replied to Midnight-280Z's topic in Brakes, Wheels, Suspension and Chassis
Hi All, I emailed Kim at Rota and was told the offsets on the 16X8 RB is +12, +20 and +25. I called 18Racing.com today and was quoted $650/set special order. I think the offsets are going the wrong way to look good with ZG flares and may not fit under the stock fenders. Tom -
Hi Thomaz, I am going to give your SC solution a try. I have one question for you; How much did you cut off from the end of the clutch arm?
