Content Count
860 -
1 -
Feedback
0%
Matt Cramer last won the day on June 11 2014
Matt Cramer had the most liked content!
Community Reputation
13 GoodAbout Matt Cramer
Rank
Member
- Birthday 04/13/1978
Gender
Male
Location
Covington, GA
Recent Profile Visitors
Tuners in the Atlanta area that we often work with would be Doug Wilkes at DBW Motorsports, or Arif Hossein at YAI Racing. There's also Zen Motors in Suwanee.
The MAP sensor isn't the only thing giving weird readings - there are massive battery voltage spikes too. Where exactly is the relay board grounded, and are you using high or low impedance injectors?
Can you post up your MSQ and a tooth log of the loss of sync?
It's losing RPM sync. Can you capture the RPM problem in a tooth log?
Data logging is pretty straightforward: To get a data log, go to the Data Logging menu and click Start Logging. You will be prompted for a file name. The log starts when you save the file (this is an easy one to get tripped up on as a lot of people expect saving the file to be what you do at the end of the log). Once you have recorded what you need, go to the Data Logging Menu and click Stop. If you want a video, though, check out Andy Whittle's How EFI Works channel on YouTube. https://www.youtube.com/watch?v=LeqAzDNOeaI
Got a data log of this? It could be the ECU is losing the RPM input.
A digital dash in a gauge sized package
Matt Cramer replied to Matt Cramer's topic in Vendor's Forum
It uses 29 bit CAN in the MegaSquirt version. At this point, I believe it only receives data from one device on the line - but if the MegaSquirt can read the 11 bit CAN and retransmit on the 29 bit CAN, that would be a workable option. -
Are you a car enthusiast looking to get your foot in the door of the aftermarket racing parts industry? We build and sell racing fuel injection systems, and we're looking for a technical sales and service position. We are looking for someone with experience with installing and tuning tunable aftermarket fuel injection, even if the experience so far has just been on your own personal project or friends' cars rather than paid work. MegaSquirt or AMP EFI experience preferred. Here's what you will be doing. Entering phone orders and creating customer accounts. Helping customers de
DIYAutoTune.com is now carrying a digital dash that fits in the space of a conventional gauge! It can display up to eight sensor readings at once. Plus, this gauge monitors almost all your ECU’s sensor readings, and can interrupt its display to switch to a warning message if you run into an unsafe condition such as overheating, leaning out, and more available warnings. Works with all ECUs in the MS2 and MS3 family, and also has three built in analog inputs. The NEW Perfect Tuning 24x Multicolor OLED Universal Gauge is enclosed in billet aluminum and boasts a real carbon fiber f
The block or head can be an acceptable second choice, but sheet metal grounds are generally terrible. Grounding the ECU to the battery cuts out any potential for voltage drops with the block to battery ground. I have not seen the starter cause a voltage spike that would be a problem with grounding the ECU to the battery but not the block.
In my experience, good chassis grounds are usually bad, and bad chassis grounds are horrible. A chassis ground may look like a nice thick piece of metal running straight to the battery. But in practice, there's often a fair amount of rust, spot welds with poor contacts, and possibly sections where the current is trying to get through paint and rusty screws in the path of current that you try running through the chassis. So grounding the ECU to the battery is the best option for grounding.
Try grounding the MS directly to the battery. Chassis grounds often tend to have noise issues.
Could be the solenoid is failing mechanically, but it might respond well to a bit of machine oil in all the ports. I've seen times where they "stick" and some oil frees them up.
You can use the tooth logger feature to watch the signal coming in. See this link for how it works:
The mods in that picture are set up for D14 spark output. Please be sure your tune is configured to match.
