ShinyRedZ
Everything posted by ShinyRedZ
Chrome euro bumpers - what're they worth?
ShinyRedZ replied to MazterDizazter's topic in S30 Series - 240z, 260z, 280z
Those bumpers would look great on my car! It looks like you need at least 1 rear hatch strut, it not 2 struts. I will trade you a pair of rear hatch struts for a pair of bumpers. -
Does anyone have a source for a stock S30 speedometer cable? I have tried nismoparts.com, zcarparts, and all the Canadian Nissan dealers, but none available.
If you only change the front brakes to the S12+8 calipers, then the stock 260Z master cylinder is fine. Or at least it is on my car. The 280ZX master cylinder (15/16" piston) is the next step up from the 260/280Z master cylinder (7/8" piston).
Just pulled my invoice from MM, dated 9/5/2007. Prices may have changed. All prices quoted in US$ Billet 6061 aluminum rotor spacer, one pair, for use with 240Z hubs and vented Toyota 4x4 calipters. Includes 4x4 240Z high grade rotor hardware. $118.80 Note: I changed the order from 240Z to 280Z with no change in price. Price does not include shipping. I basically deleted everything else from the kit to only get the spacer(s).
Toyota 4x4 Vented Brake Pads Options?
ShinyRedZ replied to Cable's topic in Brakes, Wheels, Suspension and Chassis
I looked through the Porterfield catalog, and found that the pads for a 86 - 95 RX7 5 bolt hubs are ALMOST the same size as the Toyota truck pads. The RX7 pads (Porterfield AP331) are 4.18 inches across, while the toyota pads (Porterfield AP137) are 4.21 inches across. Has anyone tried RX7 pads in the Toyota S12-8 calipers? -
The spacer from MM comes in 2 widths, depending on your hubs. 240Z need a thicker spacer (16mm ??) while the 260Z and 280Z take a 9mm spacer. Modern Motorsports supplies the correct spacer with the correct length and grade of bolts to install the rotor to the hub with the spacer in between. I installed this spacer on my 260Z with the vented toyota S12-8 calipers and '84 300ZX rotors with no problems.
Could you measure the length of the cylinder on the H4 oil pump? I have an H2 oil pump, and would be interested in comparing the length of the cylinders.
Brake confusion, some one kill me
ShinyRedZ replied to wax's topic in Brakes, Wheels, Suspension and Chassis
I have a new "spare" pair of 44155-04S10 brackets. Now sure of the cost to ship from Canada to Aus. PM me if interested. -
L13,14,16,18,20 all will take the standard Six Cylinder Bellhousing and the tranny will sit correctly. Tony, I have owned L13, L16, L18, L20 engines, but I have never heard of the L14 engine. What did the L14 come in?
Extending the stock LCA (non-adjustable)
ShinyRedZ replied to subtle_driver's topic in Brakes, Wheels, Suspension and Chassis
On the street car with the 1/2" increase in LCA length the camber was about -1 degree. On the rally car with the 1" increase in LCA length the camber was about 0 degrees, which was an improvement over the positive camber, as my increased ride height gave me about 9 3/4" of ground clearance at the front crossmember. -
I took 4 LCA's, (2 for each side), cut them near the middle, and them welded the longer halfs back together, so that the total length was 1/2" longer than the original LCA. Also built 2 LCAs this way for my rally car that were 1" longer. Never had a problem with either set of LCAs. Easy way to get more negative camber (or less positive camber). -
Longer wheel studs for 76 280z
ShinyRedZ replied to Comrade_Charlie's topic in Brakes, Wheels, Suspension and Chassis
Only the rear wheel studs from a Quest will work. Then fronts have a larger diameter. -
how much to cut from springs?
ShinyRedZ replied to burninator's topic in Brakes, Wheels, Suspension and Chassis
I coil spring is not in tension or compression, it is in torsion. Cut 1/2 coil at a time only as JMortensen recommends. -
Modified oil cooler lines for L28ET auto?
ShinyRedZ replied to 280Z Turbo's topic in Nissan L6 Forum
Bolts for the banjo fittings are M18 x 1.5, the o-rings are Nissan part #21334-R2400 for the large one, and #21311-V0700 for the small one. -
There are 2 o-rings in the adapter. The large o-ring seals the adapter to the block, and is Nissan part 21334-R2400. The small o-ring is inside the adapter, seals the bolt that goes through the adapter, and is Nissan part 21311-V0700. I got both of these o-rings from the Nissan dealer in Dearborn, Superior Nissan.
Koni 86-1918 shock question
ShinyRedZ replied to mclark999's topic in Brakes, Wheels, Suspension and Chassis
For the RED Koni shocks, the procedure is: 1. Remove the strut from the car, remove the spring. 2. Fully collapse the shock absorber at the same time turning the piston rod slowly TO THE LEFT (anti-clockwise) until it is felt that the cams of the adjusting nut engage in the recesses of the foot valve assembly. The damper may have already been adjusted. Therefore check whether the shock absorber is in the unadjusted position or not by keeping it collapsed and gently turning farther TO THE LEFT counting at the same time the half turns until a stop is felt. Stop turning then and DO NOT USE FORCE. 3. Keeping the shock absorber collapsed make 2 half turns (360 degrees) TO THE RIGHT (clockwise). In case of prior adjustment add the number of half turns previously found. The total range is about 5 half turns. 4. Pull the shock absorber out vertically WITHOUT TURNING for at least 1 cm to disengage the adjusting mechanism. The piston rod may now be turned freely. N.B. Adjustment must always be carried out in pairs, and for the same amount. -
The 240sx rear calipers require brake lines with banjo fittings, so you will need the 240sx SS lines on the rear. The S12+8 calipers require the same fitting as the stock 240Z calipers, so 240Z SS lines on the front, unless you modify the S12+8 calipers for banjo fittings, and then you can use the 240sx SS lines on the front. See also: Toyota vented caliper fitting ?????
wrong spacers for toyota caliper conversion?
ShinyRedZ replied to lowdown's topic in Brakes, Wheels, Suspension and Chassis
For the 280Z hubs the spacer needs to be 8mm thick (5/16") -
Will Z32 Hubs and Brakes fit?
ShinyRedZ replied to waezsn's topic in Brakes, Wheels, Suspension and Chassis
Have a nephew interested in Z32 5 lug front and rear hubs and 30mm turbo brakes for his 240sx. Let me know if you are interested in selling them.
