MY77Z
Everything posted by MY77Z
  1. i'm in kuwait city, 115? yup in the shadow blowing sand = sand storms where u cannot see a thing because of the sand
  2. dlouis7 ........... thanks alot but i live in Kuwait getZ ......... 110 degrees? sounds cold, supposed to be 130 here in Kuwait this week.
  3. WOOOW, great color dude, congrats and waitin for the finished thing
  4. what is the blue tape for ?? and BTW, this is my favorite car ever
  5. thanks guys for the info, this is a photo to show how close my rad to the pullies i'll have to check tomorow but we dont have alot of tauruses here in kuwait, its not really easy to find one but i'll try, what do you guys think about the benz's dual pusher type fans?
  6. hi guys, i have a small question about electric fans, since the space between my new rad and my crank pully is very tight, i'm thinking about getting a new electric fan, i noticed on sites that they say pull or push type, what is pull type and what is push type? if the fan is mounted between the rad and the engine, what type should i have to flow the air toward the engine? and if mounted between the rad and the frontend, what type is needed in this case? thanks, P.S. does anybody know if they make slim Efans?
  7. congrats!! car sounds great, powerful and smooth. and BTW, we are never too old to play with HotRods, you look my age Dale, i'm 27 and still playin with them LOOOOL
  8. WOOOOOOOOOW great job, why electric? why not nitro?
  9. hi Ed, well my Water pump is a highflow pump that turns both directions, clocklwise and counterclockwise, so i dont think its a problem anymore and BTW, your son's engine looks great, good job on the install. keep up the good work
  10. hi there, one question, does the car run ?
  11. hi guys, i had few hours to use yesterday and i installed the new water pump, cleaned the surface around it and painted it in gray, modified the alternator bracket and painted it too, had the radiator mounts fabricated and welded on the rad. i'll use some 4mm rubber piece under the mounts not to mount it directly on the body, my only problem now is the Electric Fan, it will not fit easily between the rad and the crank pully, the only way to make fit now is to mount it more to the drivers side and not in the middel, i thought about cutting few mm from the crank pully but i dont think its a good idea. what do you guys think?
  12. I used an 7/8" master cylinder (MC) from Wilwood (WIL-260-6765) and it's good while driving, a bit stiff but i'm used to it. i dont know how a bigger MC would feel but i'm happy with this setup for now knowing that i haven't floored or sprayed the car yet. David K thanks for the kind words about my ride, i'm not sure if you are asking Ed or asking me about the SSI intake but to be honest, i've never driven a mustang with the SSI intake on it, but i've never had problems with BBK's products at all, if i build another ford engine, i'll definatly go with the SSI intake/fuel rail combo from BBK.
  13. well, i dont want to start a new photos thread of my car so i'll just post them here, few weeks ago, i bought a new clutch setup and modified the SC to make it fit, MC, SC, hose and fittings new RAM powergrip HD clutch kit out of the box installed after few modifications another one this is it for my clutch upgrade. now i'm working on my cooling system, got new high flow water pump, griffin 24*19 radiator, 160degree t-stat, swivel t-stat housing, i'm trying to do my best but got no time to work on the car because of my job. thanks
  14. Justin, thanks for the advice, since this is my first aluminum rad, i'm not familiar with them, i was thinking about a soild mount, i'll check the JTR mounts, if not, i'll just fabricate some here in kuwait with rubber support VinhZXT, well, yesterday i was chekin the space and how to mount it, i'm not really sure that i have enough space to make a shroud, i'm not even sure if i'll be able to mount the fan between the rad and the water pump pully, my engine is not sitting all the way to the back, so space between rad and pully is tight. i'll see how it goes and post photos when its installed. thanks again for the advice
  15. hahahaha no you dont wanna be here, its no bodys kind of weather, 130 and sand storms well, i'll try to find it here in kuwait, i know that there is a parts shop that might have it, if not, i'll let you know thanks alot
  16. hi guys, parts received today i took everything out of the car except for one Water pump bolt this thing is stuck, i tryed everything but i cant remove it. i'll be trying again today, and than i'll install all the new stuff but still i have to fabricate mounts for the radiator.
  17. hi guys, parts received today i took everything out of the car except for one Water pump bolt this thing is stuck, i tryed everything but i cant remove it. i'll be trying again today, and than i'll install all the new stuff but still i have to fabricate mounts for the radiator.
  18. Welcome to HybridZ! nice looking Z you got, looks clean and love the red interior ok lets get down to business, forget about your engine, get the 5.0 mounts, find a nice 5.0 at the junkyard, get an eagle 331 stroker, AFR 185s, 51012 Lunati cam, TKO 500, 8.8 narrowed with 4.10 ratio and ........ "ALI.... SHUT UP'' what?? am i talking alot? LOOL welcome again to HybridZ dude.
  19. MY77Z
    Should I?
    what about fixing the Snake and building a Z at the same time?
  20. nice engine bay looks very clean, as for the rearend, i would recommend a ford 8.8/31 spline axels, it could handle as much power as the 9'' and you will save few pounds because the 9'' is heavy. for the engine, i aint wiring freak but i'll always go with an LSx over anyother engine.
  21. MY77Z
    Should I?
    TDMCOBRA...... YES YOU SHOULD well it's 1:20AM here in kuwait and i have to go to bed, check those sites and i'll catch up with you later http://www.jagsthatrun.com/ http://brokenkitty.com/index.htm http://zcar.netdojo.com/fordswap.php and check this photo, just to motivate you good night guys
  22. LineC.......... RESPECT on the new Snake. gotta do somthing about the interior dude. next thing to think of should be, air intake, pully, tune and a 75hp shot of NOS
  23. Project_BBZ DRAG LITES DRAG LITES DRAG LITES DRAG LITES what color your Z is gonna be?
  24. looks good but expensive, the setup i went with didnt coast me 150bucks with all the mods i did to make it fit.
