                Posts352
                Days Won4
Everything posted by G-Tech
	I would love carbon fiber parts too, poor s130 gets no love!!! please someone make something
	You might be able to use the stock master cyl. for the clutch but I went with a willwood 3/4 bore cause it wasn't too expensive and it works great. I used a cable drive throttle body, seemed easier to set up than drive by wire. My tuner guy said a stock throttle body that is port and polished is just as good as any other aftermarket. Make sure u use a good clutch cause I'm not sure you can pull the tranny by itself. I pull engine and trans as one. And last thing for now, the power steering rack (which is probably the only luxury we have that s30 guys don't)is metric so u need adapter fitting to go from metric to standard.
	I used aeromotive also part#11106 good for 700hp, aeromotive regulater,before and after filters, 8an feed, 6an return, and braided flex hose the whole way.i did the same thing making the feed line my return line.i didn't know much on modifying the sender so I used and external pump but my understanding with fuel pumps is they make better pushers than pullers so I put a fitting on the bottom of the tank for gravity feed. I had to drill holes in the tub inside the tank cause now my feed is outside of that tub, I put fuel cell foam in too. I eventually want to weld a sump in the bottom for better pickup, right now I cant get less than a quarter tank or it will suck air which is obviously bad. there is a thread that says how to use a autometer gas gauge for a ford to work with the Datsun sending unit but It didn't work right, I gotta play with the resistors a lil more to get it accurate.You will want all new gauges to work with the new motor, you could save the gas gauge and maybe volts and oil pressure but new ones fit perfectly in the old pods.
	I think it is important to tie the front and rear to the body in some form but you don't have to get crazy. I have 400whp and ive told you what ive done. i beat the hell out of my car and it takes every bit of it with no issue. I think a 4 point "cage" will take care of the rear (don't get confused as i did, a "roll bar" doesn't do much for strength)and you will want something for the front. maybe tie bars from the fire wall to the strut towers and from there to the frame rails would work. i don't think stitch welding is necessary but like i said, if it makes you feel better then do it.you may wanna try the s130 pages for more specifics on chassis stiffening. the 280zx has kinda been the black sheep of the z's, not many have gone all out on them. i've searched the best I can and have found 4 other s130's with LS's, and one is in Australia or something. none have posted much in specifics as what they've done. that's why I started this thread. i have been working on mine for 10yrs and just recently decided to post about it.for weight, the most popular is take spare tire out and put battery there, aluminum radiators are affordable, brake rotors with aluminum hats, I tried getting Fiberglass panels from company called show cars, horrible experience I had with them.
	I say have at it!!! For drag racing or racing from a red light, who cares about balance. You just won't get the most out of it when it comes autocross or having fun on off ramps or on ramps. Sounds like u know what your doing. Do something with the stock brakes, your gonna want stiffer springs in the rear and definitely do Stub axles since you have a stick shift. What I did to stiffen it up was strut braces and made my own frame ties. If u go turbo, it will help with header issues. So just build it how ever it makes you fell warm and fuzzy inside. There is no text book way to do an s130, the cage is gonna be a custom built thing so make it up as u go. And yes u hijacked my thread but there doesn't seem to be many already done so let this thread be about help people build a 280zx LS swap. Good luck, keep us posted.
	Dirty dingo has good parts. I have their alt. Bracket..just make sure to take your time putting the motor in the right place. I know I was getting frustrated and wanted to just make it work but I'm glad I went threw the extra work to make it low and close to the fire wall. It will also be needed to get the tranny to fit right without any mods to the tunnel. I'd like to see what u do with the cage. I did floor and frame rail replacement but I did the MSA roll bar and I'd like to replace it with a real cage
	Those mounts could work. What I think will be your problem is were the mounts bolt to the motor end up behind the cross member. I had a small block Chevy in the car first so I already had the jtr mounts. Then I got sbc to ls swap plates. Problem then was the motor moved to far foward. My dad said to try reversing the mounts. I put the passenger side on driver side and visversa and it actually put the motor in a good place. I had to weld bushings on the mounts cause now the slots in the mounts went up and down Instead of right and left. Hopefully u can make sense of the pics, I know this may be confussing but I was able to make this work and I'm sure there is other ways to get mounts to work.just be creative. Good luck with yours, keep me posted. the headers i felt were the biggest obstacle.
	.jpg.b34f27553f5960421801c8ab2cbf5db3.thumb.jpg.7889e8073010b6a0d8d6aae0626e768b.jpg)  Chassis rust repair/reinforcement suggestions wantedG-Tech replied to turbogrill's topic in S130 Series - 280ZX I didn't have it that bad but I had the same spots. I bent up sheet metal and replaced part of the rails. the corner part was for sure the trickier part but just piece by piece replaced it all. at some point I tell myself to stop looking and start doing. I did do afterwards frame ties out of stainless 1x3. welded it to the front frame rails, welded along the bottom of the car and made a piece that went up to the rear subframe and welded to that, that would help you a lot. hope this helps
	From the album: 280zx customization Frame ties are Stainless 1x3, welded from front frame rails to the rear subframe
	From the album: 280zx customization Out with the old exhaust, in with the new and improved. Dual 2 1/2 to single 3 1/2 full stainless. Oval pipe to get over the sub frame.
	From the album: 280zx customization Techno toys shortened strut tubes
	From the album: 280zx customization Billy boat stepped shorties for a c5. This is after I replaced the primary on the right
	From the album: 280zx customization 300m 39 spline Stub axles with 300zxt CV joints. I broke 2 stock Stub axles
	From the album: 280zx customization Hello ls motor. L33 bored to 5.7, ls2 dart heads. 400whp
	From the album: 280zx customization Azc brakes 6 piston front 4 in the rear. Absolutely stops on a dime..rotors did warp after a couple years. I use them but haven't seen a road coarse or auto cross YET!!!
	From the album: 280zx customization Made gauge cluster auto meter gauges, indicate air/fuel.i used a Ford gas gauge but I couldn't get the amount of resistors right to work correctly dispute what I read on a forum before
	From the album: 280zx customization First motor swap. Was fun but nose heavy and old school
	From the album: 280zx customization <p>Good bye SBC</p>
	From the album: 280zx customization <p>Original look. Been in my family since 84</p>
	if you find somewhere to get them please post it. there is not much out there, I need for the door seal mounted to the car that goes all the way around the t-top
