jt1
    4
jt1 last won the day on October 14 2016
jt1 had the most liked content!
1 Follower
  • Gender
    Not Telling
  • Location
    North Carolina
Recent Profile Visitors
jt1's Achievements
Newbie
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
13
  1. Very nice! A beautiful and well done car.
  2. Sweet car!!!!! I love it. I wish we had a JCR car for the wind tunnel. I would like to see how the vented fenders worked. I suspect they would have done very well.
  3. Great vids and a good job driving! What tires do you run?
  4. Appleslicer- First you must understand that Mark and I are old friends. We both are subject to over engineered solutions just because we think it's cool. This leads to ongoing jokes about stuff like "I checked the oil and it was a little low so I went ahead and overhauled the engine, used a new callies crank and had the heads max ported. Maybe the oil will be ok now". A lot of people on HybridZ call it "while I'm at it" disease. Generally trans alignment isn't a problem with T56's and LS engines, I wouldn't even worry about it. It's difficult to check with the T56 bellhousing arrangement, but I've never known of anyone having trouble. I used to run a TKO in my car, and they are much more sensitive to alignment than 56's. I posted a write up about centering the bellhousing several years ago if you want to hunt it up. Sorry to cause you to have second thoughts. If the trans went together smoothly and the clutch works OK, I wouldn't worry about it. Most likely you just got a worn out trans, Been there/done that too. John
  5. When you built that engine, how close did the rear surface of the block check to being perpendicular to the crank C/L? It should be less than 0.002" max. You should also indicate the bellhousing to be sure the radial runout is less than 0.001". Any more than that and you'll have shifting issues for sure. Very imp on a T56.
  6. Probably need to overhaul the trans while you've got it out. 3rd gear syncro is always suspect.
  7. Jeromio, I'm glad to see you're doing well. I've been a fan of your car since way back. Sad to see you selling it, but I'm sure you will see that it winds up in good hands. Best to ya' John
  8. Sad news indeed. Prayers for all his family and friends. May he rest in peace.
  9. Check to see if the throttle blades are fully closed. If so, check for any vacuum leaks.
  10. That's a very nice car. Not many still in that shape. I hope you go back with the 903. I used to own a 71 that was 903 and it's one of my favorite Z colors. jt
  11. I've used a 7.25" Tilton triple quite a bit, in a mostly track/barely streetable car. It's great for track, holds 600 crank hp with no problem, but it's very quick and hard to modulate for a smooth takeoff. Playing with master cyl diameter helped some, but it's still easy to spin the tires, kill the motor, or jerk away from a start like you're in the wrong gear.
  12. Indeed. Your notching, bending, and fitting is top shelf.
  13. Seymour "Cast Blast" is one of my favorites.
