OK just to clarify, the small line from the diaphram on top of the canister goes to the T fitting inline with the dizzy, what this does is open the PURGE line to the intake to burn the collected vapors. now to clean up this line, you can run it along the frame rail with your wire harness to the firewall, then up the back to the sealing lip , going under the hood latch, then run it to the back of the intake and along you fuel rail. and connect it to the stock location, or to the line that runs to the A/C vacuum motors on the fender next to the canister if you have an a/c system. you can do the same with the other line, and run it the same way to the vacuum T fitting for the throttle body to distributer line. for dress you can use braided steel line, or covers for the hoses and use a larger cover for both lines to run in together. hope this helps, soryy for the long post
