4
Everything posted by SDgoods
Thanks for the input! I have a speedhut revolution tach that's pretty accurate. And whether or not its exactly at 3500 rpm, its at that place on the tach everytime. Regarding the CAS, I have 2 seperate sensors, one from the ET and one from the Z31, both of them giving the same exact symptom, which now that you say it, is probably too coincidental. Ill try and get my hands on another ECU. I suppose if it got fried and happen to be on the CAS circuit it would throw the same code. The circuit does recieve 12v and does have a ground but it could still be 'bad'
There's only one way to put the trigger wheel on I dont know how people manage to install it upside down. I havent tested another ECU I need to find one and do that. The maf is about 9 inches from the compressor but Ive been running this setup for a while now. it ran rich but physically ran great. Ill try and move the maf farther away from the turbo, however, the other side of the maf also greatly influences turbulence as the air needs to smooth out before hitting the hot wire. Ive tried a couple variations of piping before the maf but am very limited to room as I have a same sided intercooler. Running draw through setup, its your typical ET setup. is no one else curious about the fact that its at 3500 rpm every time, no matter of load? This means that no matter what volume of air (under boost or not), it's leaning out at that exact RPM. This and the CAS code really makes me think its CAS related. What do you think?
Well I thought I knew the system quite well but I cant figure out this problem... I redid some intercooler piping and went as far as using a smoke machine to get rid of most of the leaks... (although even before with some the car run great) Ever since the car never ran right. 73 240z with l28et, z31 300zx maf, ecu, trigger wheel. Aftermarket FPR set per FSM. I can visually see fuel pressure raise when revving while standing still. Fuel filter is clean. Car will drive mostly fine at low RPMs and idles great at 800 RPM. It lean surges once in a while but every single time no matter what load while driving (from letting RPMS rise slowly to WOT), it will lean and hesitate at 3500 RPM where I let off. with the car standing at idle I CAN rev past 3500 and the AFR's stay fine. This only happens when im driving. I tested a known good maf that seemed to fix the problem, only to buy another known good one and the problem persists. Ive replaced the CHTS that tested bad as well. I am throwing a Crank angle sensor code and swapped it with the z31 sensor I got with the rest of the z31 stuff, doesn't change anything. It gets 12v and the other tests passed. Straight Ohming out the sensor none of the pins have any resistance on either of the CAS's. Is this normal? Can someone ohm out a known good and let me know if this is the same? I plan on cleaning connectors and such tomorrow and tinkering around but Im pretty stumped. I feel like its CAS related because of the competely RPM dependent symptom but cannot find any issues with it. Any input would help!
76 280z rough idle after warm up...
SDgoods replied to J240ZTurbo's topic in Trouble Shooting / General Engine
Which sensor did you replace? It would help if you explained a little more about what exactly is happening. So it stays on (drives? idles?) and then you turn it off and when you try to start it again does it crank? does it fire up? does it die right after it fires up? If you take note of all these things it can help you and other members help fix the problem. -
Like the title says need z31 300zx turbo OR NA let me know if you have one!! Im in San Diego CA, willing to pay for shipping if the price is right.
rough idle, barely runs L28et z31 ecu/maf
SDgoods replied to noelawinslow's topic in Trouble Shooting / General Engine
Glad you got it figured out for the most part. I would just buy a wideband 02 sensor with the gauge... Theres a guy selling AEM Uego on here for 157 shipped brand new. I have the same one and I love it.. You can just run it straight on its own, I use mine every day I guarantee it will come in handy, especially on a modified/swapped car. http://forums.hybridz.org/topic/114817-aem-wideband/ -
I went through all this Car sat for a couple months as I had a lot of other stuff to do but these systems are still relatively finnicky. Took me a while to figure out. My advice... I made the mistake of leaving the air filter off the maf, make sure you put a filter on the maf/intake.... the maf does not like the turbulent air and after I put mine on it helped immensely as it did another member who did the same thing... Make sure you have The constant + voltage to the ECU for the ECU memory. It was not in the right up I used and I discovered it just comparing the s130/z31 wiring diagram. Were your guys cars running alread before the z31 stuff swap? I'm running fine with no 02 sensor and no burn cycle on the maf (although I still plan to wire it in)... make sure injectors 2 and 5 are switched for batch firing. Make sure if you have 81, the dropping resistors are removed. Have you all verified fuel pressure? If you have a wide band are they running rich or lean? -
SDgoods replied to k3werra's topic in Brakes, Wheels, Suspension and Chassis
My 30 year old Hayashi Racing perrier 503's refinished by me and HRE wheels.... 15x7 +4 front 15x7 -16 rear on 205/50/15 on original center caps slightly refurbished by me -
Ive been thinking about someone swapping one into an s30 ever since i saw this, although its a built 5.2 L, it maxed out the dyno at 1700whp and they estimate it at 2200-2500 whp! 1:1 power to weight ratio anyone? http://www.superstreetonline.com/features/sstp_1203_2005_infiniti_g35/viewall.html
My new custom BOLT IN roll bar/half cage setup
SDgoods replied to SDgoods's topic in Brakes, Wheels, Suspension and Chassis
Officially Im not sure but like my last post said it seems to be designed better than the autopower scca so i assume it would -
I didnt like how close it sat to my head in my bride seat that leans a little further back than most. The new bar sits slightly farther back but doesnt sit as high. Its also just designed a lot better as the autopower only bolts up to the fender wells while the new one utiliZes the strut towers, a bar between them, and an extra diagonal bar from the strut tower to the main hoop. -
just added pictures -
I can find out but for a tight and clean fitment depending on how intricate you want the bar it would probably be easiest for them to have the car. Ill find out and let you know -
Ya ill post some pics tonight -
It should but its made from scratch so they can virtually make you anything you want -
To duplicate it would be about $650. Its 100% bolt in other than drilling 8 holes in the fender wells. -
Hayashi racing 503's refinished by HRE , original center caps repainted on me on my dirty car! -
I have front and rear off my 73 in good condition, some surface rust specks
^^ Thanks, I know what the JDM ones look like hence why I want pics of the MSA one to see how similar it really is.
I couldn't find any angles other than whats on the MSA website.... Does anyone have some pictures of this spoiler from some different angles... Overall quality of spoiler? I had the victory on my last z and I was for the most part happy with it..
My l28ET 240z on refinished Hayashi 503's!
SDgoods replied to SDgoods's topic in S30 Series - 240z, 260z, 280z
Added some more photos!
