Everything posted by jkh280zx
Shanks, Have a Nissan T5 manual transmission that has been remanufactured via a Memphis machine shop (purchased two; one went into my next 280zxt). T5 is located in Paragould, AR. Stored indoors. Photo available, if interested. jkh280zx
83 L28ET Engine was rebuilt with aftermarket upgrades. *edited*
jkh280zx replied to jkh280zx's topic in S130 Series - 280ZX
The journey has come to an end. During Labor Day vacation, I drove to Paragould (AR) to see the on-going upgrades to my 1983 280zxt. The following pictures were taken. Much progress has been made and Stage 1 is almost complete as noted in the last photo. I sat in the new leather seats for the first time; all electrical components worked; shifted through the gears; checked out the new speakers (larger than OEM) in the back; the black dashboard and the interior looked great; and the LoneWolf IM looked great under the hood. The pictures tell it all. All chrome pieces, rear mirrors, valve cover, OEM wheels (grooves sprayed gold), rear window louvers and front-rear bumpers were carbon-coated black. As noted in the left picture, a piece was cut out of the radiator frame to allow for the turbo IC tubes (same sided IC) and the air cooler to run to their corresponding parts. Lonewolf is ready for its component parts; OEM heat screen will be used; fuel injector leads and the electric modifications need to be hooked up; and the IM looks great with the new carbon-coated valve cover. I am really pleased with the work that Rick (The Shop) has done to finish out Stage 1. October 2, 2011: Now the bad news; James (Jim’s Auto Machine Shop in Paragould) called me tonight; there was a fire at Rick’s home while he was away this morning and his home was completely destroyed; the whole second floor felled down onto Rick’s Shop where my Zcar was located. Fortunately, no-one was hurt. I want to thank all in HZ who helped me make the critical decisions; especially, John and Paul. Thanks to Chris for almost all the interior parts. Thanks to Rick and James for their skills and so many contributions too numerous to relate involving this journey. I know that I am not the only one who has lost a Zcar; however, she had been with me since 1984. Her journey was my journey. John -
Specs of Lonewolf (LW) intake manifold (IM) purchased & runners inter-diameter of an OEM IM (83’ 280zxt). LW IM purchased via JR (spork) (http://www.lonewolfperformance.com/Nissan.htm) Notes: the TB opening is 65 mm (above left); the 240sx TB (to be attached to the LW IM) is 60 mm; the OEM TB opening is 52 mm; and the vacuum ports as noted (above right) are located on the lower side of the plenum, which will make the engine bay have a less cluttered appearance. Personal Communication from James (LWP): “As for the specs on the manifold, I don’t have a “spec sheet†of sorts, … They change based on the customers needs. I know you don’t have the intake in front of you to do your own measurements, but they can be easily measured with a tape measure. The measurements of the inside of the plenum is 20†long and approx 3.75†diameter. To figure volume it gets tricky as there is also the velocity stack plate that protrudes into the plenum area slightly. Without figuring in the velocity stack plate your intake has approx 222.16 CI or 3.64 Liters. The runner length …you’ll have to do yourself, or have the shop that is installing the manifold do for you. (The Shop: runners length - 8.25“). Inside diameter was approx 35mm. (The Shop: 34.5 mm left to right as noted above). TB angle was using approx a 45 degree bend but it is angled in the direction it was welded to the manifold as well to make it easier for running intercooler piping.†Post #19 (spork) via James Roraback & Lonewolf Performance http://forums.hybridz.org/index.php/topic/52826-intake-decisionslonewolf-vs-thagard-vs/page__p__472197__hl__%2Bintake+%2Bdecisions...lonewolf+%2Bvs+%2Bthagard+%2Bvs+%2B%3F%3F%3F__fromsearch__1#entry472197 “The question(s)…what kind of work have you done to the head? Do you have any flow numbers? As a lot of people don't understand…is that the intake is just part of the picture. I'd be curious as to how the head is really set up and that can really help determine what you actually need. One of the benefits of our intake is the options in runner size, length, and just about anything else you can think of. For the high powered turbo cars, we step up the runner size to allow the head to be opened up (as well as the gasket) to allow the head to flow a lot better. With a stock sized runner, you'll only get "X" cfm out of the head. When looking for quite a bit more power than stock, you're going to need a head that flows better and your setup will work much more effeciently. As mentioned before, its the difference of making 400hp @30psi vs. 600hp @30psi. If possible, I suggest finding someone that can either do the head work and the intake at the same time, or atleast is interested in knowing about your head to help suit the intake best for your application. … I just want to make sure you get an intake that will work well for your setup. Anyways, if you have any questions, feel free to call or e-mail.†Original IM specs: Inner diameter of the runners of the OEM IM, which was on my Zcar. The Shop: OEM IM – Runner’s length of head-to-plenum is 7 inches. Inner diameter of runners given below that attaches to a p90a head (my ‘83 280zxt). Other updates: OEM seats were recovered with black leather with a non-OEM pattern. They fit here: Next: OEM wheels were power-coated black and grooves sprayed gold. Thanks for stopping by. jkh280zx -
Modification of a stock 83’ IM or to an after-market IM or to an eBay’s premium IM???? In preparation for the next intake manifold (IM) for my Zcar, I have been accumulating pictures, HZ threads and literature in my “wish notebook†to aid in the decision-making process. The following information summarizes just part of this journey. The picture below shows the current status of the existing stock ’83 turbo IM, except the original POV has been removed. Modification of a stock IM: In his HZ thread, Challenger has provided visual information that denotes the obstructions in a stock IM; has shown how to modify the stock intake manifold for Zs; MONZTER has demonstrated increased air flow through a modified stock IM (See: refs below pictures). After porting the inlets to IM plenum/runners, several HZ members have focused on the modification of the inner surface of IM (plenum & runners) (MONZTER); however, the internal diameter of the runners remains the most critical limiting factor to air flow (See: BRAAP & others below). Challenger via. http://forums.hybridz.org/showthread.php?t=134422 With a customized stock IM, which provides an increased air flow, elevated HP has been noted. MONZTER via. http://forums.hybridz.org/index.php?showtopic=66748 (post #3) http://forums.hybridz.org/showthread.php?t=145256 Other interesting modifications & literature in regards to modification of stock IMs: Blue via. http://atlanticz.ca/zclub/techtips/intake/zintake/index.html http://atlanticz.ca/zclub/techtips/engine.htm z boi via. Which intake manifold has bigger runners? http://forums.hybridz.org/index.php?/topic/28482-which-intake-manifold-has-bigger-runners/page__p__511129__hl__which%20intake%20manifold% 20has%20bigger%20runners fromsearch__1entry511129 KTM-EXC via. Porting Intake Manifold. http://forums.hybridz.org/index.php?/topic/47991-porting-intake-manifold/page__p__413844__hl__intake%20manifold%20__fromsearch__1entry413844 BRAAP via.“The stock EFI L-28 intake manifold port runners have only 53% the area of the L-28 intake valve!†http://forums.hybridz.org/index.php?/topic/54034-big-throttle-bodies-why/page__p__487857__hl__intake%20manifold%20__fromsearch__1entry487857 As noted via Blue in the above atlanticz references, “1 fast Z of BMC demonstrated that intake manifolds from maxima LD28 motors have larger runners and mouth. The LD28 runner diameter is 35mm (same as the Z head and Z carb manifold runner). The LD28 runners are longer too. They just need a TB plate and injectors bungs attachedâ€. (Below L). Also note that “BMC makes custom intakes for Zsâ€. (Below R) http://forums.hybridz.org/showthread.php?t=133795 As originally found in ZSelect.com, a high-flow, custom intake manifold was available via Lonewolf Performance. ComicArtist via http://www.zcar.com/forums/885094/lone-wolf-intake http://www.lonewolfperformance.com/nissan.htm Next, custom-made intake manifolds have been made via HZ members. VinhZXT via. http://forums.hybridz.org/showthread.php?t=137723 Mayolives via. Which Intake Manifold Should I Use? (post # 6 Speeder) http://forums.hybridz.org/index.php?showtopic=25602 Philip1 via. Show Off Your Engine Bay! Pics Wanted, L-series Rate Topic http://forums.hybridz.org/index.php?showtopic=73648 (post # 9 Stagefummer11) RTz via. Scratchbuilt L6 EFI Intake Manifold http://forums.hybridz.org/index.php?showtopic=51825 PrOxLaMuS via. DIY ITB turbo intake manifold http://forums.hybridz.org/index.php?/topic/61956-diy-itb-turbo-intake-manifold/ MONZTER via. Turbo Intake Plenum http://forums.hybridz.org/showthread.php?t=127863&page=14 Wiki via. Manifold (automotive). http://en.wikipedia.org/wiki/Manifold_(automotive) howstuffworks via. How do tuned intake runners work on your car? http://auto.howstuffworks.com/question517.htm/printable team-integra via. Intake Manifold Tech: Runner Size Calculations (Page 1) http://www.team-integra.net/sections/articles/showArticle.asp?ArticleID=466 team-integra via. Intake Manifold Tech: Runner Size Calculations (Page 2) http://www.team-integra.net/sections/articles/showArticle.asp?ArticleID=471 Out with the not so old OEM IM with a fuel rail + gage combo and 265 cc injectors: In with the LoneWolf intake manifold with a fuel rail + gage combo, 300 cc Bosch injectors and the 60 mm TB that was on the OEM IM above: Thanks Paul for assimilating all critical information on the OEM ’83 IM and options; thanks to all HZ posters for their creativity in this area too. Follow-up, the critical dimensions of the LW IM that was purchased in comparison to the original OEM IM, etc. Thereafter, will post plans for Stage 1 and, then, Stage 2 (Nistune and 550 cc RC injectors). Thanks John for your input; it is difficult for a lay person to make critical decision regarding “which is best for my Zcarâ€. The plan is to drive my Zcar for several months before Stage 2; I have already purchased everything except a boost controller and the RC injectors for this latter stage. I will need to research a tuning shop down in this area. Beginning to realize how much of refreshment she has under gone since this thread began. Thanks for stopping by. jkh280zx -
PYW: Update on Nissan D5733 & Interior Went up to Paragould (AR) and took these pictures. Previous post showed the new coat before wet sanding and polishing. Current Status: I am pleased. All bumpers and chrome pieces have been power coated (black). The wheels will be power coated black with gold painted grooves. The valve cover will also be power coated black with silver letters; a pattern to match the next intake manifold (hint! hint!). New OEM emblems will be returned to their respective locations. A picture is worth a thousand words; something is missing. Decided that the AC should be returned to this Zcar; TX is too hot. The IC & piping system will be acid washed and returned. Next post involves the stock intake manifold. The dash was not spray painted; it was perfect. Thanks ckelly78z. Thanks also to Rick (The Shop) who is taking the lead for the final stages of this refreshment project. She is in a good place. Thanks for stopping by. jkh280zx -
These next figures supported the decision-makers, who have recently taken the lead in the refreshment of my Zcar (12/23/09). The following diagrams were obtained from Sam (Parts Manager) at Nissan (Jonesboro, AR). Sam was a great help; he sourced the needed parts within Nissan Incorporation (CA) and the inventories of individual dealerships. He also possesses knowledge about Zcar aftermarket parts; a great source over-and-above MSA and BD. As stated, the windshield was taken out to look for areas that needed attention. One corner spot had only slight surface rust and the top area of the windshield was bad as indicated by previous post. So, the necessary parts to secure a new windshield (Gene’s in Paragould, AR) were purchased from Nissan (Jonesboro) as noted in the first photo (see below); the original side pieces are to be re-used after being painted black. The glass windshield, door glass plates and the 3/4 windows will be tinted after the interior and other upgrades have been installed. All chrome pieces and bumpers on the car will be painted black. As noted previously, new rubber weather seals for the t-tops were purchased from MSA; however, the door rubber seals could not be found (see below). Finally, this and other needed parts were purchased from ckelly78z. Also, the chrome-felt clip-ons (80820 & 21) that fit on the outside of the door next to the glass window were OEM replaced (MSA). One inventory part was purchased and the other is coming from Japan (soon, right!). Water channeling in this area is critical. The next diagram (seen below) denotes many major parts that were not needed; however, many small rubber parts in these areas were purchase from MSA and aftermarket (ebay). The rubber seal set, which secures the back tail lights were purchased from MSA. As the next photo illustrates, I was interested in a front air dam (type2 for 280zx). One was purchased from MSA and put in 'near' place as shown below. I have read many threads about improving wind channeling with air dams, etc. After reading the instructions, I felt that the addition of this part would require modification and, therefore, add more vulnerability to the front end; it was not installed. However, I still like the look and the advantages air dams bring to the performance of a Zcar. So, time will tell. The instructions for air dam installation are given below. PYW: Allocating out the component parts for both 5733 & D5733 were done by pouring each stock paint from their corresponding source to the customer’s product can; the latter was placed on an analytical balance. This procedure is subjected to errors by the individual mixing the 6 oz sample & final paint combination. The color and accumulative amount of each component part is given in the table below for both 5733 & D5733. The first selected color was Deltron 5733 (Nissan 2003), which was noted as 'burnt cherry burgundy' according to the clip (chip). This color was dark maroon within the garage without sunlight; when the garage door was opened the color turned to dark pink as shown in the previous post. Be sure you talk to the head man within the paint department and be sure you ask for a 6 oz sample of your color; then have your paint guy spray a metal surface to verify the color that you have chosen. It should be viewed out in the direct sunlight before you give your final OK. Do not just look at the paint on the lid can or a stick dunked into the paint can. Notice that the D component for Deltron D5733 (Nissan 2004) is high-lighted in yellow; this component represents a darker flop to the final paint code that was selected. The second attempt to have my Zcar painted has been accomplished as noted in the last two photos. Clean-up of the engine bay, intercooler and its corresponding tubing by Rick (Jim's Auto & Machine Shop). Current status: progress is being made. I am pleased; have to be patient; up-grades require time and cost money, etc. Next, the wheels will be power-coated black; bumpers have already been painted black; original bucket seats have been refitted with black leather; OEM black steering wheel has been purchased (ckelly78z); the floor mats are brown (sorry!) [they were purchased new several years back from MSA]. These floor mats will be changed-out over time. Interested in MSA’s black, leather, door-side panels. By the way, a new alarm system has been purchased and has been installed; the AC has been removed. New decisions: intake-manifold will be changed-out with an aftermarket product; plug&play by Spectre eMS-Pro is at the top of the list for a new ECU AND ~440 cc spark plugs will be purchased. Any other suggestions that I have over looked? Spring break is coming soon; the hemp might be traveling to Paragould (AR). If nothing else, I will go for a drive in my refreshed car as shown above in the parking lot located next door to Rick's home. She is in a good place. Progress!! Thanks for dropping by! john -
The last update showed my Zcar being gutted with the target to completely refresh the interior (black) and a new coat-of-paint (dark maroon). First, the body work was done. There were several major problems: area between the windshield and t-top, two underneath “cancer†holes; and the left-front fender area (backing out of narrow garage). Of course, small areas of body surface rust and joint regions between the hood and right-vent section. From what I have read in HybridZ, these are common spots for the 280zx. These areas were addressed as indicated by the pictures below. When I saw this damage, I was sick. I doubted my decision to repair the engine first; however, James and Rick stated that they rather be the first step in car restoration and not have to worry so much about working around a new coat-of-paint. Next, a new coat of paint. I went to O’Reilly’s several times to find the color for the ‘second generation’ of 300K miles. OR has many albums of paint options for domestic and foreign cars. Finally, in the Nissan 2003 book, PPG ‘Deltron 5733’ was selected; the color was very dark with reflections of gold maroon. This looked great when only the garage lights were on; however, when the garage door was opened, “Ouch!†The paint selected was PPG ‘Deltron 5733’, which was called ‘Burnt Cherry Burgundy’ but the clip showed a very dark maroon color. The whys for the pink color are too numerous to elaborate. However, if you read Bob Story’s Automotive Paint FAQs and others, then you will know some of them. (References are given at the end.) One of the problems was that the car was painted with a (70 ±10) reducer during the middle of the summer (95◦+); the correct curing time is critical with a new coat-of-paint, especially with a metallic-pearl composite. After discussions with the painter and OR, my Zcar was moved and moved twice more. Don’t ask me why; however, the 4th move was good. And I moved too. My residence is now in Denison (TX) and I am pleased to be working at Grayson County College (teaching biology). My Zcar is still in Paragould (AR) with a new coat-of-paint (PPG ‘Deltron D5733’) purchased at OR’s in Jonesboro (AR). The black interior has been incorporated into the car and “many thanks†goes to Chris (ckelly78z) who provided nearly all of these parts and many back-up parts that I know will be needed down the road. Currently, Chris has another 1982 280zx in ‘parts for sale’ (HZ). AND an on-going “many thanks†goes to Rick and company (Jim’s Auto & Machine Shop) for installing the black interior and other assorted parts to be noted later. Hope you’ll have a Merry Christmas and a Happy New Year!! Thanks for looking in! john Reference: Bob Story’s Automotive Paint Frequently-Asked Questions. digitalweb.net Drew Hardin. Hot Rod’s Ultimate Guide to Paint & Body – Part 1. http://www.hotrod.com/howto/hdrp_0605_paint_body_1/index.html Drew Hardin. Ultimate Paint and Body Guide Part 7 – Under The Gun. http://www.hotrod.com/techarticles/body/hrdp_0611_car_paint_techniques/index.html -
How cool is it for your FIRST ride to be in a Twin Turbo Z???
jkh280zx replied to 1 fast z's topic in Non Tech Board
Hey Jocelyn & Bryan, What good news and what a memory for young Ethan. Glad that mother and child are in good health. How about you? Now tell me what one of your rides will be his FIRST ride??? john -
madkaw, As a follow-up of what Chris just posted, here are pictures that illustrate the repair of the bubbles on the roof of my 83ZXT and some rust under the windshield (both corners). Not pretty but you all have seen rust before. I did not believe that it was this bad. There were other areas on the body of the car that were repaired. Note the damage to the underside of the roof as seen above. These are the component parts needed from Nissan or others. I purchased 3 of the four parts needed (Nissan). The chrome plate came off ok; the clips were broken (Nissan) and the plastic part as mentioned in a previous post was broken (Nissan) when removed. The glass came out ok but I plan to replace it with a new one (had my dd repaired recently - the man just cut around the edges with a tool and then two individuals pushed it out), which can be order from a dealer in Memphis. Hope this helps. john Edited: the rust under the windshield.
Hey, The journey is not complete yet, but this is my first selection for my 83ZXT (5733 paint code). The paint source is ppg at O'Reillys; many domestic and import notebooks can be found. Make sure that you get the Deltron brand and look at the component parts to be sure about matching the clip. Also make sure that the temp reducer is within the ambient temperature when you spray paint your car. Always talk to the head paint guy; OMNI mixing grade will not get you the same quality color as seen in the clip. This is the final results as noted below (the journey not complete yet). Now, make sure you ask for a sprayed sample; usually 4 oz will be enough. AND, I suggest that you evaluate whether the pearl and metalic components are what you want. There are many variables in the art of spraying that will make your final color lighter or darker than what the clip reveals to you. If you want to change any of the individual components, this is possible upon mixing the selected paint code. The current status: my Zcar has been moved to another shop because of the various problems that I have mentioned above AND other lack of attention-to-details. Now, I have selected the following: D5733. This is an alternative to the 5733. Components of both are noted below: The D component (urethane flattening agent) will affect what you see; straight-on view will be the clip and looking from the side will make it darker (according to the head paint guy at O'Reillys - Jonesboro). Therefore, she will be almost black at night and D5733 during the daylight hours. Good luck with your journey. john
Last Thursday, my 280zxt went in for a body make-over. She will come home with a burgundy covering and black interior. I thank Chris (ckelly78z) and those who have provided the black interior parts. Afterwards, I will be selling the tan/brown interior parts that have been taken out of my Zcar. This time, I have purchased a red ‘93 Amigo as my dd and my fishing ride (sure is fun to just get up and go). Yesterday, I went to see the patient; a few photos taken. She was gutted as the body doc stated. Well the task is progressing nicely. I continue to buy new weather strip pieces. Currently, I have purchased the following: t-top weather strips (MSA), window/t-top strips, weather gaskets for the rear lights, gold emblems from MSA, BD and ebay, and 3 of 4 strips that are lined with the top and bottom windshield (Nissan) and many of the rubber stoppers around the doors, hood and hatch that keep the rattles down. Will need the door weather strips and the clips that aid in aligning the top portion of the windshield with its respective parts. The latter will be more difficult. Purchased the airdam that is available in MSA’s spring sale. Copied VinhZXT’s statement about aligning the glass by using the glass regulator that is inside the door (HZ via Weather Stripping). The main leak in my Zcar came from the back part of the glass door as it aligned itself with the t-top rubber strip and the t-top seal door strip. Thanks VinhZXT. I have been getting a lot of flack from the guys at The Shop because I am ordering similar body-side molding for my Zcar; however, I have not found the style that I like as yet. Well, I am pleased with the work being done by the boss man. Will keep you informed. By the way the engine bay was not touched. Thank goodness. Enjoying my Amigo now. She will be a big help in organizing my fishing trips when they become more numerous. Thanks for stopping by. john -
Hey, Many changes have happened to date and, so far, they have been accomplished with a balance of component parts. These changes are addressed in my MsPs thread in HybridZ given below. However, a few problems still exist like an oil leak from the power steering assembly (direct source unknown). Still, planning must guide the next stage of improvements; addressing them together is the challenging part. So I have summarized below what I have been thinking about as being the best combination (Stage2) for my Zcar with a target of drive-ability and 300 HP. My focused question is what can be changed without affecting the balance of the existing parts? I am not interested in programming a standalone. This will be my fun car; my next dd is being re-furbished as we speak via James and Rick at The Shop. What do you think? …any alternatives? …compatibility and efficiency of parts? How should these changes be grouped together when upgraded?? In advance, thanks for your input. References: Todd Ryden. 2004. How to Build High-Performance Ignition Systems. Crane’s Coils: Performance Ignition Coils. http://cranecams.org/pdf/Page105.pdf Crane’s XR700 & XR3000 Installation: http://www.bmw2002faq.com/images/stories/faqs/crane_install/crane_install.pdf Crane’s XR3000 & PS-91: http://www.bmw2002faq.com/content/view/70/32/#section3 Afshin via HybridZ: Z31/300zx ECU/MAF to 280ZXT swap guide. http://forums.hybridz.org/showthread.php?t=91250 Thanks for stopping by. john
Recently, purchased the door weatherstrips (34-1082 & 1083) for $299 each side from MSA, not as listed in catalogue. Also, recently, purchased 3 of the four WS for the front windshield for $149 from Gary at Jonesboro Nissan. Purchased extras from Chris (ckelly78z) who currently has two ZXTs in parts-for-sale. Hope this helps.
References: Wayne Monteath via zcar. See: http://www.zcar.com/forums/read/1/702395/702457 Nissan ECU core identification list. See: http://jimwolftechnology.com/wolfpdf/ECU-ID.PDF Blue via zcar. See: http://www.atlanticz.ca/zclub/techtips/ http://www.hammondsplains.com/newtechtips/ECU/NTB94-097%20(Nissan%20ECU%20Guide).pdf
Found this in zcar.com a while back. Hope this helps. My car fits the 83 highlite.
http://video.google.com/videosearch?hl=en&q=External+Wastegate&um=1&ie=UTF-8&sa=X&oi=video_result_group&resnum=7&ct=title# Yesterday, on the second test-run to determine if the POV was truly fixed, I accelerated in third gear to boost conditions and the results were very interesting; no “hissing†sound but a major sound of “angry bees†or “chainsaw†thunder was evident. In fourth gear and under boost conditions, again the same sound. A new problem or is this normal… Came home and searched within HZ’s Google and found several bits of information that help me understand the functionality of what I had heard, a EWG for the first time. The following references were very informative. WASTE GATE Definition: A trap door-like device on the exhaust side of a turbocharger that limits the amount of boost a turbo can produce. The waste gate consists of a spring-loaded diaphragm. A vacuum hose connects the diaphragm to the intake manifold. When boost pressure starts to exceed the rating of the waste gate, the diaphragm pulls open a bypass flap in the turbo housing. This allows some of the exhaust to go around the turbo impeller which slows it down. Source: unknown. A wastegate is a valve that diverts exhaust gases away from the turbine wheel in a turbocharged engine system. Diversion of exhaust gases regulates the turbine speed, which in turn regulates the rotating speed of the compressor. The primary function of the wastegate is to regulate the maximum boost pressure in turbocharger systems, to protect the engine and the turbocharger. Source: Wikipedia. Wastegate sizing: One of the more popular misconceptions about wastegate sizing is; the more powerful the engine, the bigger the wastegate is needed. This guide indicates the right size of wastegate:[1] big turbo/low boost = bigger wastegate big turbo/high boost = smaller wastegate small turbo/high boost = smaller wastegate small turbo/low boost = bigger wastegate Source: Wastegate. Wikipedia & [1]Turbosmart Direct.com. Also: Nigel via HybridZ: Wastegate Sizing. See: Post #73 ……... http://forums.hybridz.org/showthread.php?t=132994&page=4 And: http://forums.performancecar.co.nz/v...?f=37&p=455903 Thumper via HybridZ: External wastegate open or re-route into exhaust. …….http://forums.hybridz.org/showthread.php?t=105132 From this thread, it became evident that the sound of “angry bees†was the result of the EWG on my Zcar that runs open (Photo1) and was talking to me. HZ members using a EWG to control boost pressure have different set-ups/likes, which is one’s preference for sound and/or performance. Since efficiency is my motivator behind this rebuild, I most likely will follow Brad-ManQ45’s suggestion (post5); however, this modification is down-the-road. Several other members have done this mod as well. Also, the EWG shown here (Photo1) has the e-bay provider’s stock spring (7 psi) within it, I think. Therefore, as thehelix112 indicated, an 11 psi spring might be better for my Zcar and my preference. As indicated in Photo1, the dump pipe shown here is shorter in comparison to some of the set-ups seen in HZ; according to Scottie-GNZ the shorter, the louder the sound when one runs the EWG open. “However, it should only be dumping at full boost when the w/g is diverting exhaust from the turbine housing/wheel. If it is loud any other time, then there is something wrong with it.†Based on what Clifton stated via PM, the set-up (IC) on my Zcar should be good to at least 12 psi. So a new spring (~10 psi) is in the future for this zx as well as a pressure regulator. See: TiAL spring pressure chart below. shauno via HybridZ: External wastegate and boost controller adjusting. ……..http://forums.hybridz.org/showthread.php?t=92851 Post #2 (yo2001) in this thread, indicates the following: “the WG should stay close(d) until it get close to the peak boost. You want it to hold close(d) as long as possible without spiking the boost. If you have a weak spring in a WG like 4.5psi spring, it can get blown open under boost.†NASIOC Technical: Internal or External Wastegate? ………http://forms.nasioc.com/forums/archive/index.php/t-59271.html Boostup! I think an external wastegate is better no matter what boost level you plan to run, good boost control is always desirable. It's just like the head lights of a car. It doesn't matter if you are driving at 200 mph or 20 mph, the brighter they are the better you see the road. If you are on a budget, then it's a different story. 10-23-2000, 05:57 PM Tim Prudence. The main benefit of running an external wastegate is to give waste gases there own flow path. They meet up with main exhaust further downstream so there isn't a huge amount of turbulence just behind the turbo (which deprives the turbo of power). 10-23-2000, 06:22 PM Boostup! Tim, what does an aftermarket boost controller control? Yes! the wastegate, internal or external. How else can you control boost if not via a wastegate? Am I missing something here? All an aftermarket boost controller does is (to) vary the amount of vacuum that the wastegate diaphragm sees, therefore giving you boost control. And for your information, you can still make the wastegate gases meet up further down stream of the exhaust (to reduce turbulence) for a turbocharger with an internal wastegate setup. You just have to make a new flange where the turbo meets the downpipe. The new flange will have two holes with two pipes connected to them, one being the main exhaust pipe and the other for the wastegate. 10-23-2000, 06:54 PM Boostup! For a high compression engine, 10 psi is not that low actually. Most of the turbo ej25 guys here run around the 10 psi range +/- several psi. I think 5 to 6 psi would generally be agreed upon as low boost. 10-23-2000, 07:24 PM Shik. Boostup, you are correct in saying all an aftermarket boost controller does is varies the amount of vacuum (boost) a wastegate sees. That's exactly the point in getting one! With an EBC or even a good MBC like the Hallman or Joe P controllers, they do not let the wastegate see any boost until the actual boost level has been met at the controller, then the controller lets the wastegate see it. If you are simply relying on the wastegate to control your boost, the wastegate is ALWAYS having boost trying to push it open, and in some cases, it BEGINS to open before the actual boost setting is met, resulting in slow, lagging spool up time. Not to mention the fact that you have no back-up if the wastegate should ever fail. You should always use a good boost controller. 10-24-2000, 04:01 AM The wastegate set-up on my Zcar (Photos 1&2) is as follows: a 2.5†down-pipe with a short dump pipe to a TiAL 38mm wastegate. The EWG was originally set-up to run open and still runs open at this time (Photo1). These photos also bring to mind several questions related to efficiency of a EWG design when the wastegate assemble is attached to the down-pipe; location/length of the dump pipe, its angle and size. jgkurz via HybridZ: Wastegate pipe length??? ………..http://forums.hybridz.org/showthread.php?p=773902 And, other than HP goals, how does this basic design described above compare with the EWG being attached to the exhaust manifold? 240hoke published an excellent write-up of how to attach a EWG to a turbo exhaust manifold. (See reference below) Also: slownrusty showed another way by using an adapter. (See reference below) & kcambron other examples by HZ members. (See reference below) Anyone seen a publication(s) that discusses how one can compare the efficiency of these two methods (EWG associated with a DP or an EM) to control boost pressure in a L28ET? (Maybe below, my books are still packed in Jonesboro, AR). Literature. 240hoke via HybridZ: TiAL External Gate Install on OEM Manifold *PICS* …….http://forums.hybridz.org/showthread.php?t=108785 slownrusty via HybridZ: Want To Run An Ext. Wastegate. This Is A Neat Solution? Pics …….http://forums.hybridz.org/showthread.php?p=685139 kcambron via HybridZ: Pictures of waste gate mockup. ……. http://forums.hybridz.org/showthread.php?p=976801 shauno via HybridZ: External wastegate with muffler? ……..http://forums.hybridz.org/showthread.php?p=608537 ZR8ED via HybridZ: Stock wastegate hybrid turbo no more boost. …….http://forums.hybridz.org/showthread.php?t=104816 Syclone Typhoon Archives: External Wastegate. …….http://www.sytyarchives.com/howto/viewarticle.php?article_name=external_wastegate.php&dir=engine NASIOC Technical: Internal or External Wastegate? ………http://forms.nasioc.com/forums/archive/index.php/t-59271.html HKS EVC I Instructions – External Wastegate ………http://www.hksusa.com/info/download.asp?id=1740# Mark Warner, P.E. 2006. Street Turbocharging. Design, Fabrication, Installation, and Tuning of High-Performance Turbocharger Systems. HPBooks. Corky Bell. 1997. Maximum Boost. Designing, Testing and Installing Turbocharger Systems. Bentley Publishers. Thanks for stopping by… john -
A major issue has existed since the new exhaust system has been installed. Up to that time, I had not pushed my Zcar for a long time. However, afterwards, I have heard “hissing” sounds during acceleration coming from the engine bay. One day and from a slight rolling start (first gear), I pushed the petal-to-the-metal. At the start, she bounced four times (GT IVs) and then off we went under WOT conditions; major “hissing” was heard from under the hood; it was much louder than what I had hear before; and then shifting into second resulted in another major “hissing” sound. Well, with regards to the BOV, the second noise is normal but not the first. At that time, I suspected the BOV; more specifically, the o-ring and/or the 7 psi spring. A new o-ring and an 11 psi spring were purchased from Lightning Motorsports (Grand Prairie, TX). Then I sent a message to Clifton via PM about the Walbro pump that he had purchased; eventually, the conversation went to the “hissing” noise from the engine bay. Clifton pointed out that POVs eventually will start to leak; he took the POV off of his Z31 with a pipe wrench and welded a bead around it. Well, the removal of POV and the installation of a Walbro pump became a dual purpose for my Zcar’s visit to The Shop last Monday (5th). The series of photos illustrate the procedure that Rick took to take off the POV from the stock turbo intake manifold of this L28ET (‘83 280zxt). The POV valve itself was taken off by hand; the spring caught Rick’s thumb. Ouch! The first photo shows the valve in the background of the former EGR valve attachment and the remaining shell of the POV in the foreground. Photo2 shows what a hammer and a cold chisel will do to this shell (The POV is in the foreground in this photo). Note: Both of the vacuum lines to the brake booster (L) and to the AEM 1:1 adjustable fuel pressure regulator ® were removed. Next, the loose ends of the shell’s base were bent toward the center of the remnant POV (Photo3). This exposed the bolt base of the POV, which was then removed with a pipe wrench as shown here (Photo4). Next, the opened hole in the intake manifold was revealed (Photo5) and then it was closed with a plug (Photo 6). The vacuum lines to the brake booster (L) and the adjustable fuel pressure regulator ® were returned to their respective positions (Photo6). How sweet it is!!! Results: no “hissssing” from under the hood. Next day, on a county road, she passed the test. In third gear, I accelerated but not under WOT conditions; the major sound was the turbo pumping air with its characteristic sound. No need to change anything with the BOV; o-ring and 11 psi spring will be stored. Thanks again Clifton, the problem solved. Someday, an after-market intake manifold will be installed; this should help to clean up the engine bay some more and to increase the inner diameter of the runners. Now, those 18-wheelers will not interfere with interstate driving…. No literature needed..… She is as she is… john -
This GSL-392 pump was installed in my ‘83 280zxt today (Jan. 5th). Purchased this item from TRE_Performance-Parts via ebay. The instructions were good and the universal kit 400-939 provided the necessary parts, which included an “isolator sleeve”. This was not seen in the promo for this pump; excellent addition, which meant that my trip to Lowes was in vain. As indicated below, both the original sleeve and this new one were used. Rick at The Shop installed this pump. The stock pump and fuel damper were located in the back/passenger side just up from the fuel tank. See: Blue’s reference below. Old stock pump (95 psi) with 300K miles of operation and road conditions… Note: the stock sleeve was left within the assemble and the old dog was removed. Old vs New… Note: the L-shaped fitting (banjo-hosebar) on the old pump while the universal kit had a straight fitting (hosebar). Subsequently, a longer high-pressure tubing (Dayco fuel injection hose) was needed, purchased and assembled. I forgot to photograph the installed and functional Walbro pump. However, driving in all gears, no can hear…. Both sleeves were used. From the previous post, several after-market modifications will assist in drowning out the noise from the pump, if it is there…. Next, I did photograph the fuel damper, which was almost eliminated. However, it remains. It was located approximately 6” inline up from the pump. Might replace it down the road. Literature for the fuel damper & general fuel system articles… afbrian13 via HybridZ: Fuel Damper. …….http://forums.hybridz.org/showthread.php?p=638187 jayzrocket via HybridZ: Fuel Damper? …….http://forums.hybridz.org/showthread.php?t=139382 nismofan1 via zcar.com: FPR, fuel rail, and fuel damper questions. …….http://www.zcar.com/forums/read/3/1884656 pedroosan via my350Z.com: *Update* on engine knocking noise and fuel damper TSB. ……...http://my350z.com/forum/maintenance-and-repair/288412-update-on-engine-knocking-noise-and-fuel-damper-tsb.html FUEL RAIL DAMPER (WO/1999/061783) …….http://www.wipo.int/pctdb/en/wo.jsp?wo=1999061783 The 280z bible via Blue’s website: The Electronic Fuel Injection Notebook. …….http://www.atlanticz.ca/zclub/techtips/efisystem/280zfuelinjectionbook.pdf Toyota Motor Sales. Overview of the Fuel Delivery System. …….http://www.autoshop101.com/forms/h22.pdf john -
Purchased: Walbro 255lph-PH (GSL-392) inline, external fuel pump with universal kit 400-939, which includes all the hardware and mounting brackets needed, plus instructions. This high-pressure fuel pump is capable of supporting up to 500+ HP (at the crank) when supplied with 13.5V and under boosted applications as noted by TRE. According to the literature, Walbro fuel pumps should last between 10-20 years; each pump is fully tested before shipping; and all Walbro fuel pumps are manufactured in the USA. Also, it is highly recommended that a professionally licensed mechanic install your fuel pump. And that malfunctions due to improper installation such, as failure to prime the pump, may void the manufacturer’s warranty. Purchased from: TRE_Performance-Parts via ebay. Costa Mesa, CA92627 This pump can flow 0-115 psi, which will be regulated via AEM 1:1 fuel pressure regulator in my Zcar. This fuel system will consist of the following schematic: Walbro 255 fuel pump (GSL-392) > fuel filter > Peter’s fuel rail with gauge & stock intake manifold > excess fuel will recycle back to the stock tank by the fuel regulator, which is currently set at ~44 psi. Setting will be adjusted again following assembly. Injectors remain turbo-stock OEM Nissan at 265cc, which will be changed out in the near future.Thanks Clifton for information provided via PM correspondence. Addition information provided by the manufacturer of Walbro fuel pumps with regards to the spects of the GSL-392… Source: TI Group Automotive Systems. Aftermarket Division. Cass City, MI48726 Flow vs. Pressure Data vs. Amps Source: Lightning Motorsports: spects for Walbro inline pumps Is there an alternative?? Trevor via 3si.org. Fuel pumps: Walbro 255lph PH vs. Supra. …….http://www.3si.org/forum/f35/fuel-pumps-walbro-255lph-hp-vs-supra-130803/ Jeff Lucius. Fuel pump upgrade guide for the Mitsubishi 3000GT VR4 and Dodge Stealth R/T twin Turbo. .....http://www.stealth316.com/2-fuelpumpguide.htm Remember that the Walbro 341 is an in-tank fuel pump…. WizardBlack via HybridZ. “For a fuel pump, it all depends on what kind of power you expect to make. A general rule of thumb is less than two horsepower per litre-per-hour of pump. This is assuming forced induction. A common in-tank fuel pump upgrade (for modern cars) is the Walbro GSS342 (~$110) that flows 255 lph and is expected to be maxed out at 500 whp. There is an external (or in-line) version of it you can get (GSS347 IIRC). One step nicer than that is the Bosch 044 pump (~$175) that flows about 300 lph and can support 500+. The Aeromotive A1000, most Welden pumps, etc. are extremely loud and flow a lot but are very expensive. Whatever you do, be sure to insulate your mount point for those with a good chunk of rubber.” ……..http://forums.hybridz.org/showthread.php?t=136618 Is it really noisy??? When mine is installed (Jan. 5th), I will report… Until then, here are opinions of several. Nater via VWvortex Forums. “If you have a 2.5" or 3" exhaust with no cat or no resonator, it's DEF not "loud"... Like others have said, you can hear it from outside the car but it's just another noise that makes it sound mean IMO. From the inside, again as stated...exhaust and music drown it out. If you are one (like me) to just drive around listening to the sweet sound of your turbo/motor/exhaust then this won't be an issue.” .therealvrt via VWvortex Forums. “go to home depot and by their cheap rubber connector (some people use this instead of silicone on intercooler pipes) and cut them and wrap one around the pump. You won't even hear it i had mine wrapped for about 4 years.” .therealvrt via VWvortex Forums. “i used 2 around mine and bought new stainless clamps total cost about $10 CDN.” …….http://forums.vwvortex.com/zerothread?id=3085979&postid=36139847 Clifton via HybridZ & PM. Re: Fuel Pump, a Walbro for a L28ET!!! With the foam sock on the pump, I don't find it to be too noisy. At least not compared to the Paxton pump I was running: ......http://forums.hybridz.org/private.php?do=showpm&pmid=492447 Literature: HybridZ & others. slownrusty via HybridZ. My Turbo Fuel Pump Upgrade - Pics & Write Up: ……..http://forums.hybridz.org/showthread.php?t=89558 cygnusx1 via HybridZ. Fuel Pump Noise: …….http://forums.hybridz.org/showthread.php?t=142226 jgkurz via HybridZ. EFI Fuel Pump Flow Analysis: …….http://forums.hybridz.org/showthread.php?p=922632 cws1807 via HybridZ. Walbro GSL392 possibly bad: …….http://forums.hybridz.org/showthread.php?t=140833 Calgary280ZT via HybridZ.Walbro fuel pump...advice on which model to buy: …….http://forums.hybridz.org/showthread.php?t=135476 fuel-plumps.net. Basic Fuel Pump Concepts: .....http://www.fuel-pumps.net/fuelpumpsfaq3.html Monday (5th) the pump will be installed and photos will follow. john -
As naviathan stated: Z Specialties Inc. 206-363-3577 I purchased the 105 amp alternator for my 83 280zxt. Be sure that you use the belt that is suggested because if not, you could be stranded; the one that was used for my Zcar's engine rebuild broke and I was stranded. Helllllo!!! Called and found out that Napa #25-9345 was the belt that the company recommends. They ran tests and this one turned out to be the best. I carry a spare belt in my hatch area. john
Best angle for intercooler ducting?
jkh280zx replied to HeatRaveR's topic in Windtunnel Test Results and Analysis
Clarification, I have not read any threads within the Aerodynamics section. However, when designing the air intake and IC for my 83 280zxt, the copied photos below that came from my MsPs showed what I suggested to James, the engine builder. There is an electric auxiliary fan between the slanted IC and the radiator. I believe that adding an air dam and air channeling to the radiator would assist air movement and lessen air turbulence. The auxiliary fan is needed during the summer time; not so much now (AR). john -
As stated in my last post, I made plans to move to Middletown (PA) to work at PSH. The trip was uneventful; the campus and folks were great. However, finding a place to live, which was close to campus and a garage to park/store my car was not available. Most apartment managers were not pet-friendly. I did not want to commute from neighboring communities and high move-in expenses were not too appealing. My contract was for only 6 months with an extension possible depending on raising research funds. Therefore, when my transition money began to run out, I related to the PI that I was returning to AR. Currently, I am re-established in Paragould, AR. Computer is unpacked and the Internet is alive. This means that I will continue to search for a research position and to plan my Zcar rebuild project. Next Monday (5th), a new pump will be put into the fuel system and a new o-ring and a 11 psi spring for the TiAL BOV. john -
DW, As noted above, the inserts can be obtained from Timesert via www.timesert.com The part number is 18153 (M18X1.5x18.3INSERT). TIME-SERT 1 800 423-4070 1 775 829-1026 The solid lifters that went into my 83 zxt (p90a head) were obtained from a 79 p90 head. James suggested to convert during the engine rebuild because of the lack of availability of the hydraulic lifters (as you noted) and better performance with the solid lifters. All is well; adjustment is scheduled every 30K miles. I hope that timing is right. john
