Everything posted by rwwisnesky
Update to my emission problem. Met with the air program vehicle evaluation tech center today. Technically my 1978 with a 2000 LS1 would require: 2 cats; 4 O2 sensors; egr; check engine light; fuel tank sensor, obd output; and god knows what else. I have a single cat; charcoal canister and 2 O2 sensors. The tech said what I did is what he would have done and filled out a DR 2365 form stating the car would be tested as follows: "engine has been replaced with a 5.7L V-8. required equipment for this vehicle is an oxy sensor (2) and a cat converter. air system is to be marked N/A. test as a 1978 (tailpipe). I could have kissed him !!!!! My cat is gutted, engine blew insides of cat out the tail pipe, but i passed my HC PPM was 68 against a limit of 400. Those LS1's are just incrediable.
Last year my 1978 Datsun passed emissions because it was tested as a 78 Datsun. This year in Colorado they are testing as the year of the car or the engine which ever is newer. Therefore mine is a 2000 LS1 from a Trans Am. If I have to put the egr etc back on, has anyone ever had to deal with that. The computer has all that stuff removed, so i assume if its on it doesnt have to work. But without it, can it pass the test. Any pearls of wisdom???? P.S. the header wont accomodate the egr plumbing. Thank God for the government, they are here to help !!!!
JTR LSx Header Installation Questions...
rwwisnesky replied to Cable's topic in Gen III & IV Chevy V8Z Tech Board
I used the Sanderson headers and put the engine in with them on. Not much room to work on them after the engine is on. -
Stock 240Z clutch MC not adaptable to LS1?
rwwisnesky replied to auxilary's topic in Gen III & IV Chevy V8Z Tech Board
If you use a Tilton, make sure you get the short one unless the washer bottle is not the same as the 280z. The long one would not clear the washer bottle so I had to get the shorter one. Also, if you take the push rod out of the Z master cylinder, you can swap it with the Tilton and will not have to tap the end on the peddle. -
Using stock tach w/LS1 motor/harness...
rwwisnesky replied to 240zprace's topic in Gen III & IV Chevy V8Z Tech Board
Since my last comment, I gave up on the xbox I got from JCI and put a autometer speedometer into my 1978 280z. I removed the gauge from its case and put in into the 280z case so its fits and looks original. I moved the hi-beam, and brake warning light to the tach opening. I used a small auto meter tach and put leds around it and used the existing case also. The jci modified tach was never reliable. Soooo, I preserved most of the original look. Wish I had used the full size tach, and dealt with moving the warning lamps and turn indicators somewhere else, or even put them into the autometer. Should finish putting the dash back in this week. -
Ls1 master cylinder question
rwwisnesky replied to unofootball43's topic in Gen III & IV Chevy V8Z Tech Board
I replaced my brake master cylinder with a 280Z original. No problems and it FITS !!! -
Starting my S30/LSX swap what suspension?
rwwisnesky replied to carbon240's topic in Gen III & IV Chevy V8Z Tech Board
I guess it comes down to how you want to spend your money. I added KYB gas shocks and new bushings, nothing else. Since the weight is about the same, you really dont need to change anything except worn parts. The original Z's handled just fine, now it can go fast too! Unless you live at the track, it seems like money better spent else where. -
The sensor in the pan. I want to hook it up to a warning light when the oil level is low. Think I can rig it up thru a relay so it will work.
What did everyone do with the engine oil sensor on the LS1 when putting in a 280Z. My harness came back with no sensor connector on it. I am thinking of a way to set it back up to turn on a warning light on the dash when oil is low, but not run it thru the PCM. Any ideas???
Well you are off to the project of your lifetime, and to do it right is timely and expensive. I owned my 78 Z since it was new and restored it with a LS1 with t56 six speed. Car had 58k miles and no rust and was all original. With parts and paint job (I cant paint) but I did all mechanicals, I probably put in $20k. That said, I bought a backup car in California that was stored for 20 years. Does not run, but all original, no rust and 82k miles on it. Im getting too old for another. Great shell if you are in need of one.
LS1 / 280Z Speedometer Question
rwwisnesky replied to rwwisnesky's topic in Gen III & IV Chevy V8Z Tech Board
Janaka, nice setup!! Do you recall the guages you used. Autometer has a bunch of them. Also, did you need a separate sinding unit on either guage. -
Little more detail on the x-box. It takes the LS1 transmission's digital input and converts it to a signal that drives a small electric motor. The electric motor in turn spins the seedometer cable allowing you to keep the original unit. It is programmable based on rear end ratio and tire size. Clever idea, works great. Lately mine has been "jumpy". -
Mike, thanks for the note. My first option is to fix it. I will fuss with it some more. I mounted the X box at the firewall just below the steering column, thought it a spot with almost no curves or kinks. Now I can kick the cable when it goes to sleep. I will keep trying. Thanks and it has been a while since we talked. -
I wanted to save my original gauges after the LS1 conversion, so I bought an X box converter. It has been about 2,000 miles and the speedometer has become "jumpy". For those of you that went with new speedometers, what did you buy, what diameter, did you perserve the brake light and high beam indicator and find a black face. Long question, thanks in advance.
Johns cars for almost everything. JTR for headers and radiator. Lots of pictures on my web site
I mounted mine on the passenger side up near the radiator. Had to drill holes thru the PCU case. Fit well. Lots of pics on my web site
Probably not much value add here, BUT I had the same problem. I had power to the PCM when the ignition was on, but went off when the starter was engaged. Make sure your power stays on when the starter is engaged. I dont remember the ignition wire I finally used. Good luck.
Well, I guess we can dream for now. Wonder how well the engine and drive components would hold up. In my younger days back in the sixies, I put a McCullough supercharger on my 1955 Plymouth. Didnt take long before the engingine gave out. But engines were very low tech in those days.
Has anyone researched or installed a Magnuson Magna charger on a Zcar LS1 converson. Not cheap, but a lot of power without tearing apart the engine. Also looks like it adds little to the engine height and would clear the original hood.
need some help deciding
rwwisnesky replied to mark.deady's topic in Gen III & IV Chevy V8Z Tech Board
Its hard to go wrong with the LS1 / T56 along with John's Cars mount kit. The LS1's seem to last forever from what I have seen. A friend at work has a LS1 Camero, 170,000 miles on it, stock. Still does around a 100 in the quarter at 5280 elevation. I only put a few thousand miles a year on my LS1 Z car, so it should be good for another 50 years. -
04 GTO LS1 Fuel plumbing
rwwisnesky replied to Kevinn Morgan's topic in Gen III & IV Chevy V8Z Tech Board
Z U L8R is correct. A C5 corvette filter with built in regulator is the answer. On line in, one line to your return, anthe the other line into the fuel rail. Works great, still have the original 280Z fuel pump. -
Stupid question time....
rwwisnesky replied to PanzerAce's topic in Gen III & IV Chevy V8Z Tech Board
Johns Cars in dallas sells a very good kit -
Mine is a cusco. See pics
Ls1 computer cpu location
rwwisnesky replied to zgeezer's topic in Gen III & IV Chevy V8Z Tech Board
put mine on the fender well where the fuel filter use to be. Fits fine, cables reached -
What I do know, which isnt much, it that there is a adjustment screw in the back of the tach. If you have the tack out, hooked up to the engine with a calibrated tach, you should be able to adjust the screw so they read the same. Dont think there is any internal change required.
