djwarner
Location
Central Florida
Recent Profile Visitors
djwarner's Achievements
0
Planning on a 2012 Chevy LFX engine transplant-need help
djwarner replied to djwarner's topic in Other Engines
Hi Dennis, The OEM BCM anti theft system is horrendous cannot be defeated without the GM hardware. I found a third party BCM replacement because the firmware in the TCM only recognized the Paddle Inputs that came through the GMLAN. I had also hoped to get the GM cruise control working but the design of the BCM was originally designed for LS engines. It does have the charging control you are looking for. http://oecontrols.com/ Bob Valentine there can give you the details. As for the AC Compressor, I mounted a small Sanden compressor where the OEM PS pump was located. I had room to mount the PS pump below it. Had to design a bracket that mounted on the front of the crankcase. I got away with the smaller compressor because the cabin of the Miata was so small. I made samples out of hardwood before having a local machine shop cutting one out of 1" aluminum plate. Of course I ran into problems clearing the steering rack with the first attempt and had them make version 2.0. The problem with using a local machine shop is that one off pieces have zero priority and long delays for production work extended my build time. If I were to do it again, I would use two pieces of 1/2" aluminum plate. I did have to get a slightly longer drive belt to adjust for the changed locations. The Helmholtz exhaust system was designed to fit on a 350Z. At lower rpms it is fairly quite. At 2000 RPM and above, it pretty much sounds like a straight pipe. I would caution to keep the X pipe or H pipe in the exhaust. -
Nice Work 67LS1, You must have some unique experience and knowledge. As for my project, after not finding a suitable roller Zcar and considering the modern design features of a Miata such as airbags and antilock brakes, etc, I decided to swap the LFX/6L50 into a 2011 NC Miata Touring edition. While others had swapped in LFXs with 6sp MT for racing, I decided I wanted a true daily driver with functioning AC, antilock brakes, power steering and a full functioning instrument panel. My swap was the first 6L50 swap into a Miata. As such, the project took 13 months to get back on the road. Another 12 months to refine the project - get the paddle shifters to work and tuning the engine and transmission. I've put some 6000+ miles on the car since the swap, driving it daily. The 2 major issues in the swap was relocating the AC compressor and power steering pump with a custom bracket, and learning enough of the wiring harness and GMLAN system to integrate into the Mazda electrics and CANBUS. Very little body work was required. Back then there were no 3rd party wiring harnesses or other kits to support the swap. I named my car GRIFFIN, a chimera, half lion and half eagle. With larger intakes and exhausts and tuning, I am putting something over 300 hp at the wheels. Torque scheduling at low rpms has proved to be something of a problem as anything approaching available torque below 2800 rpm results in unintended burnouts. Fortunately, the LFX engine management system is based on a virtual torque model (actually a 6 dimensional table predicting available torque at various operating regimes). Manipulating this table tells the ECU at low rpms, that actual torque available is lower than what the engine can actually produce. Once the virtual torque value is achieved, the drive by wire throttle closes somewhat to maintain what the model says. As the rpm climbs or a higher gear is selected, higher torque limits allow for full throttle operation. Someone asked me about gas mileage and I honestly had to admit I can't stay off the gas long enough to get a good estimate. Even with thrashing it, I do get 25MPG on premium. Smiles per mile has yet to be determined. 0-60 times are sub 5 seconds. I haven't taken it to the drag strip yet. -
Haven't seen this posted but worth a look.
These moldings are still available from CustomAutoTrim.com But they are expensive.
Saturn Electric Power Steering In A Datsun 280Z
djwarner replied to socorob's topic in Fabrication / Welding
I have a Saturn electric power steering unit and the electronic interface available for anyone who would like to do this conversion. I was going to use this on a Miata engine swap, but decided to engineer a new engine bracket and retain the hydraulic PS system. PM if interested. -
Silver is a non-color, and the original Datsun blue/green being darker is almost a negative color. Some of the prettiest engines I've seen on this forum are lipstick red accented with the natural aluminum color on the raised letters and ribs on the valve cover.
The oil pressure sensors available today are designed to work with gauges and/or idiot lights. When the oil pressure is above 8 psi or so, the sensor connects a potentiometer and reads a resistance. This resistor is in series with the meter in the gauge. As the resistor varies, the meter varies. When pressure is below 8 psi, the sensor disconnects the potentiometer leaving an open circuit. For idiot lights this forces all the electric current to flow through the bulb, lighting it. For gauges an open circuit causes zero current flow and the spring in the meter forces the needle to the left extreme position, just as it does when the ignition is turned off. The oil in our early Z engines gets thin when the engine is hot as when driving at highway speeds. Idling after pulling up to a stop sign after a highway speed drive will often have oil pressure below the 8 psi limit. The pressure will increase once the revs go above idle. I was told by an old timer not to worry about it. Its a gauging problem, not an engine problem.
Cursive Handwriting - What name is this?
djwarner replied to ~KnuckleDuster~'s topic in Non Tech Board
Not a final answer, but interesting: http://www.moonzstuff.com/articles/oldhandwriting.html My vote is for "Lieut". Name spellings and abbreviations were far less standardized back then. -
BTW the link you posted tried to hijack my browser. Don't click on the link.
There is a minimum warm coolant temperature you should strive for - 185 degrees F. Due to radiational cooling overnight, water vapor can condense in the interior walls of the engine. And despite common knowledge, oil and water can mix to a slight degree. Oil can absorb up 1% water by volume. This water can drastically reduce oil lubricating ability and must be removed. Raising the temperature to 185 degrees is high enough to drive off the water.
I use Grundy after Hagerty said I drove the car too much. Been happy with Grundy and also use them to cover my daily drivers at a very competitive rate. I saw an TV ad recently where Hagerty says they no longer restrict mileage. This maybe why your rates jumped so much this renewal. One difference with Grundy is that they write stated value policies for many cars when they identify them as future collectibles. My wife bought a 2 year old Camaro Convertible a couple of years ago. They came up with a stated value higher than what she paid for it. When it got totaled 6 weeks later (not at fault), Grundy ( through AIG) sent us a check no questions asked. Said they would go after the at fault driver's insurance.
CAN BUS question for the Gurus out there
djwarner replied to djwarner's topic in Gen III & IV Chevy V8Z Tech Board
Fitting for as simple a vehicle as a Miata, the CAN BUS is a fairly simple single high speed bus. Since my transplant vehicle does not have Dynamic Stability Control or Advanced Key Locks, The only control modules are: the Engine Control, Transmission Control, Instrument Cluster, ABS Brake Control and Hard Top Control. The Instrument Cluster receives Vehicle Speed, RPM, Engine Coolant Temp, Odometer, Fuel Injection Amount from the ECU. It Receives Transmssion Gear Selection info from the TCU. It also receives indicator status for MIL, Generator Warning, Cruise Control Status, Brake System Warning, ABS Warning, Power Retractable Hard Top Warning, AT Malfunction Warning, It outputs Fuel Level to the ECU. It exchanges Immobilizer signals with the ECU. -
The only physical connections required are a CAN BUS High, CAN BUS Low, CAN BUS Ground. The voltages on the CAN BUS are all standardized. -
For those familiar with the J1979 standard. I am transplanting a 2012 Chevy LFX engine into a 2011 Miata. (could find a reasonable Z transplant candidate). Since I have a post 2008 CAN BUS devices, I am wondering if I could connect the ECU CAN BUS signals into the Mazda CAN BUS to drive the instrument cluster? From what I know about CAN BUS the basic performance parameters are polled using a standard prefix and a standard bus protocol. Other manufacturer specific data points would not be polled, but they shouldn't be needed to run the instrument cluster gauges. There would be several advantages in using the Mazda Cluster rather than replacing it with Speed Hut CAN BUS gauges. Besides limited space available in the Miata, there are some 12 indicator lights for non engine functions that would have to be replaced with the Speed Hut Gauge package. The Camaro gauges can't be used because the Body Control Module converts the high speed bus from the ECU into a medium speed bus that feeds the Instrument Clusters. The Miata however, drives the instrument cluster directly from the CAN BUS. How feasible is this?
It looks like some bezel rings are in your future. Good job otherwise. I found an unusual source for 2 1/16" bezel rings. Holley Carbs now sells instruments for their EFI setups and includes a variety of black and Chrome rings. My hub ring option is cheaper though.
