HowlerMonkey
Posts posted by HowlerMonkey
  1. L28et into M30 back on track for pic posting in a week or so.
    Made oil pick-up, dipstick, and used front dump from l24e first generation maxima as well as engine mounts from same car. Test fitted fine but am using built 3n71b and will be switching out m30 diff (w inch longer than other long snouts) for one with a more common length before solidifying driveshaft length.
    That means some tranny crossmember work.
  2. I'm working on a flattop f54 with p90 that will be boosted to the point of encountering this problem.
    Since this engine is full of old and high mileage parts, I may substitute one or two dished pistons in 5 and/or 6 for kicks and post dyno and damage results..........might take a month or so though.
    It's not the solution but more of a workaround if it works and doesn't kill power/balance.......etc.
    You guys doing the research on this thread are heros and should get mucho credit (and money) if you find the fix.
  3. A co-worker put a kenne bell supercharger on his jeep and it came as a kit with much larger injectors.
    I figured he would be belching smoke and he did..........for a couple of drive cycles and then the car ran just fine with zero ecu tweeks and continues to be a daily driver six months later.
    The Jeep ecu is not to be underestimated in it's abilities......regardless of the fact that they were made with not so good components.
    I've been really busy trying to hire on another technical support guy at our ecu rebuilding facility but this needs more looking into.
    What I am finding is that chrysler and GM ecus are a whole lot more than most people think function wise.
    That said..............anybody have a 401 steel crank?
  4. A lot of toyotas come with them and I replaced them every time I did a clutch as most won't last two clutches worth of usage.
    If you look closely at the nissan bushing parts bag, it says "oil impregnated bearing" meaning that any wear will cause the oil that is impregnated within the bushing to lubricate whatever "liberated" it.
    I've never had a factory bushing fail but once did see one that was visibly worn after 280,000 miles of usage.
  5. I never knew why guys would shut off the alternator on a run when you can just make sure the battery is fully charged before the run.
    If battery is fully charged, you won't be using hp to keep it that way.
    This allows your ignition coil to start with 13.8. to 14.1 volts rather than 12.6 volts it would see with no alternator.
    That 1.2 volts can mean a lot to people with certain configurations.
  6. Many years ago we experimented with a car to use for track days (car guys back in the 80s) and we boxed an a/c evaporator and pushed boost through it.
    You have to be careful of the design you use as some will sound like 50 kids blowing through grass blades when you push high velocity air through them and others are weak enough that the fins flop over and stop most airflow.
    Ours only energized the compressor when the brake pedal was pressed.
    Since this happens much of the time on a road course, we also gained engine braking............but...........compressors don't like to be suddenly accelerated to 6500 or more rpms so it was just an experiment that would be good for a single race (maybe) but you would be hard pressed to find any sanctioning body or tech. who would pass off your car as "ok for the track".
  7. I'm running a stock L24 with the turbo stuff bolted on from a 280zx turbo engine.
    Running stock non-turbo injectors, stock boost level and have been for 45,000 miles on an engine that now has 270,000 miles.
    I saw you on another thread asking about gasket choice but I couldn't find if the valves of the p90 hit the bores of the l24 and the only talk I see of it concerns unshrouding.
    I only want to know if the valves of a p90 hit the bore.
  8. If this is a maximum effort ITS nissan engine, you will certainly be taking a bit off the head to bring the chambers down to as small as allowed by the rules or you will end up a moving chicane for all the sunbelt, B.C. Gerolomy, and Rebello drivers.
    Knowing that, you will most likely be using head saver shims anyway so machining the face that meets the rocker pivots and cam towers shouldn't hurt if it turns out you have warpage of the entire head.
    Talk the guys here since you will be racing them and meeting them anyway.
    http://www.improvedtouring.com/forums/index.php
    Make sure to check your options such that you can view posts that are older than 30 days old or you won't find what you are looking for.
