Everything posted by sq_creations
Very nice. I'd love to see some more pictures.
So what are the details on the swap. Did you use the truck headers? single or twins? Looks good from what I can see.
Turbo LS1 240z Build
sq_creations replied to sq_creations's topic in Gen III & IV Chevy V8Z Tech Board
No sure, soon I hope. I started building the intercooler piping for the car. I picked up 5 feet of straight 3 inch aluminum pipe and 2 slivers of solid 3 inch to cap the original intercooler inlets. I'm routing the pipe into the back of each end tank. I primarily used 15 degree cuts so that 2 put together the would equal 30 degrees. I did this in an attempt to keep the bends smoother. The u bend coming off of the turbo on the hot side of the intercooler is mild steel to accommodate the blow off valve flange that is steel. You will also notice in the pictures I got the rest off the exhaust installed. I also got the bumper cut and remounted. -
I made a bracket to hold the intercooler and it is in its new home. Now I can start planing the piping. I'm going modify to end tanks for sure. -
Nice, I'll PM you my number. -
I laid the hood back on and it does look like it will clear. I have a hole in my hood so its really easy to see. I have to track down a stock hood now. My Infinity Q45 90mm Throttle body came in on Saturday. The OEM Camaro (76mm) would not fit on the Edelbrock elbow. There was a gap at the bottom. This was one of the cases were things cascaded. I bought the stock throttle body for the Weiand manifold I decide not to use after reading some reviews. Then bought the elbow to match the stock throttle body but it didn't fit. Finally I ended up back at the Q45 throttle body I wanted. What a mess right? So now that I have the Q45 T-body I have to make it fit the Edelbrock elbow. Here is how I did it. I put the intake manifold on and hooked up and tucked the injector and coil wires out of sight. The fuel lines are all hooked up. I got the turbo mounted and the driver side header on. I'm still doing wiring on the passenger side. I also have to come up with a plan on how I'm going to run the intercooler piping. -
The car is looking amazing.
Very nice set up. I hope to have mine done in the next couple weeks.
I got my GMPP single plane intake manifold and edelbrock elbow in. I put them together and came up with a mount for the fuel rails. I still need the IM gaskets. It didn't come with any and they are not the standard ls gasket. I also got a 1/4X6X18 3/8 aluminum plate and redid the valley tray with a fitting I will run to a breather style catch can. -
I have the custom engine harness pretty much done now. I just need to put it in. I got my fuel rails in the mail. They are the professional products rails. I was concerned with the internal diameter but the bore is much larger than the -8AN fittings I'm using so it should be fine. I also got the coil brackets tapped for the coil bolts. The Comp 3.75 push rods and stock rocker arms are now installed under the valve covers. I also ordered my 4inch thick 1000hp intercooler. Hopefully that is the last big purchase I need to get this thing going. -
Get them while they last... LS1 carb intake.
sq_creations replied to dustin280zx's topic in Gen III & IV Chevy V8Z Tech Board
I ordered the efi version. It should be here sometime this week. -
My setup has the water pump attached to the radiator. you can see the 2 feed ports at the bottom and the 2 return ports in the opposite upper corner along with the upper vent tube port. Now for an update: I got the coil brackets in and painted them along with the valve covers. I need to tap the holes for the coil bolts. I had to come up with a solution to the water crossover pipe that had been cut off. I ground flat the area, then drilled and taped for a fitting. I'm very happy with how it came out. As a last note for this entry I finally got the lifters in. Now I can put the heads on. skip forward The moment I have been waiting for. I got the engine in the car. I installed the lifters and put the heads on. I got the flexplate on and now the motor is on the motor mounts. I still need to attach the torque converter. I also measured the push rods with a write up that TR posted and figured out I need 3.75 push rods. So I got those ordered. I also got the weiand intake and figured out that it wasn't going to work with my oil pressure sensor along with some negative reviews and resold it. I now have on order a GMPP single plane manifold and edelbrock elbow coming. It is similar to what the previous owner ran. I also read in gmhtp that a car gained 90hp on same boost (19psi) by switching from stock manifold. -
I guess they are on the heavier side. I looked up some comparisons after I saw this. I have had good luck with wiseco pistons in the past with other cars I've had. Hopefully the added weight will take the abuse better? wiseco lists as 502grams Arias 413grams JE 395grams A small update. The epic quest for lifters has come to an end. It only to 6 weeks and 2 companies to get them here but they arrived last night. I also got my intake manifold in. I hope to have a good update for you guys in day or two. -
It will see some street action but alot of track action. The car is on drag radials. There is a local competition (that I hope is still around next season) That requires you to make a 30 mile drive to the track then race. I'll take it to work once and a while too. hehe. there is the newest update: I put the windage tray, crank sensor, and oil pan on. I was putting the flex plate on when I discovered the motor was hanging up on something internally. I have been checking as I go along so allot of cursing in sued. After rechecking the windage tray and disassembling it. I discovered that the crank sensor was hitting where the machine shop had welded in the weight when the crank was balanced. I ground it down and now everything is happy again. The first customizing hurtle has arrived. The bracket for the alternator I have was intended for an aluminum ls1 block and doesn't fit the 6.0 iron block. The iron block is missing the location for a bolt I have labeled 2 and a I needed to drill and tap location 1. I was able to modify the bracket I had by adding another arm going to a bolt location on the head. -
I got the Z06 cam, trick flow double timing set, melling oil pump installed. I had to grind a little on the front cover to get it to fit but its on now along with the water line fittings. I also started on the wiring harness. Resized to 98% (was 820 x 615) - Click image to enlarge -
Here's an update of whats been going on. I finished cleaning up the heads and put them together. My Cometic Head gaskets, TCI Flex plate, and oem damper came in too. Now the rotating assembly will get balanced. After mocking up the truck pan on the motor and measuring the bottom of the pan compared to the motor mounts I determined I only had 2 inches of ground clearance with out the weight of the motor in the car. This would probably rest the motor on the ground once installed. I picked up this corvette oil pan with the idea that I would have to cut off the wings and weld it up but I think I might be able to keep it as is. It is 5 inches deep compared to 9 inches of the truck pan. I do not plan on running the exhaust under the car and it looks like the wings will clear the frame. I started measuring my clearances and gapping my rings. Final putting it together. At this point I have the pistons in. I'm still waiting for my lifters to show up(3wks so far). GMPP/Galles (local dealer) are totally screwing me right now. Then I can put the heads on and measure for pushrods. -
Nice build. Its exciting to other z's in town.
Thanks for the comments guys. I got all the bearing clearances measured and 3 sets of the rings gap'd so far. I'll try to get pictures up soon. -
Thanks Lason I appreciate it. I'm trying to do her right. I'll hit you up with some questions when I get a little further along. I got to rotating stuff back from the machine shop so I'm hoping to get it the short block assembled this weekend. -
Congrates on the Article. Your car looks very nice. I like your paint scheme.
Thanks for the input. I dropped off the rotating assembly to get balanced today. I'll take the springs over and have them checked before I assemble the head. Hoping to put the short block together this weekend. Some of the other stuff going on. I have decided to pull my Aem Ems off of my integra and it is now back on a chipped ecu. So I am going to build a harness to run the ls1 on a 1040 box. I know alot of the mustang guys use ls1 coils on there ems' and my box is already modded for hall effect sensors. I'm drawing up the plans and will post them once I get it all sorted. Because of this I have a msd 6ls for sale if any one needs it. -
-6an Feed line Is good to 500hp on gas and about 450 on e85 from my experience.
ZR8ED Two Piece Belly pan project
sq_creations replied to ZR8ED's topic in Windtunnel Test Results and Analysis
Very interesting read. Your car came out very nice! -
I purchased this 240z from Lason on here. It has alot of stuff I was planing to do to a 240z once I found it. I got it for a reasonable price and have a great car to start my new project. The Borg Warner s480 The engine was in pieces when I got it. I have about 60% of the engine and I'm starting to get parts now. Below you see the bare block I am tring to piece together. Also the new Wiseco pistons, Manley rods, Melling Oil Pump, Trickflow timing set, and some used Comp Cams Valvesprings. I started working on the heads this week. I pulled the valvesprings out because I plan to upgrade them. The head wasn't as clean as I hoped after being hot-tanked so I pulled the valves out and started scrubing. Then I decided the casting need to be smoothed out a bit a the valve could stand to be lapped. I have one head cleaned up but still have the other to do.
