Everything posted by cheesepocket
That CX exhaust kit looks super nice and a good fit. No way a guy could do a custom setup for close to that price.
From the album: Cheesepocket
From the album: On the road again
I made one using the lower shifter boot from a Fox body 5.0 Mustang. Not too pretty, but it works.
Driveline vibration questions
cheesepocket replied to socorob's topic in Gen III & IV Chevy V8Z Tech Board
Tremec has a free app for your smartphone to help with finding the angle on both ends of the driveshaft. Make sure you are checking on machined surfaces, not as-cast. -
I'm still chasing my vibration issues. I found some pretty good stuff online regarding getting the angles right, here's one http://www.hotrodhotline.com/md/html/drive_shaft_harmonics.php though every article I've found assumes a live rear axle whose pinion angle naturally changes as a reaction to the tire torque. We can set our angles exactly as our diffs shouldn't rotate upward under torque like a live axle would. Some sites are adamant about measuring the angle directly at the U-joint caps to get a consistent machined surface, this can be done using the right size socket as a spacer. I found some slop in the front u-joints of my nearly new driveshaft, and also discovered the bolt head clearance notches in the forward diff crossmember were not made big enough so the bolt heads were directly transmitting noise to the crossmember. I'm really hoping these two things are my answer,and then the only other issue is excessive lash through the R200 and/or halfshafts. I'm also going back to factory style rubber mounts for the mustache bar and am testing a factory Camaro rubber mount for the front of the diff. MIne's a street car and the diff howling is maddening. I'll document here if this quiets things down well.
