74
Everything posted by Tony D
Optimal port diameter is 35mm and it will flow 200+ CFM. If you make a hole bigger than 35mm, you screwed up if you're using stock-sized valves! The "restriction" in the stock manifold comes from it's bends, shorten it and a stub stack at 35mm will flow enough to surprise you. Bigger is not necessarily better.
There are more area codes than 213. LA OC IE ... They are there under $1,000. I wouldn't say that's expensive. Which is cheaper? The $700 car that doesn't run, is complete, and costs a weeks time in prep to drive back home. Or the local car for 3X that a mount that requires $1,000 per side to have floor pans replaced? OR an "expensive" $3,500-5,000 rust-free Desert Car the runs, and that you drive back without spending a week prepping mechanicals? The question simply becomes WHEN you throw the money in the hole. My European buyers PREFER an UNTOUCHED car dragged in on a trailer. They know what they get...no shiny paint muddling the issues. Pone of the first cars I sent to The Netherlands was a complete rolling shell that was GIVEN to me after the PO. Salvaged it for the driveline. When acid dipped in Europe before chassis prepping...I got a call "this car has less rust on it than most Late-model BMW's I prep from local sources." Think about that comment, from a professional,chassis prep shop who is FIA certified for Roll Cage Design and Installation. Old desert faded paint may not be attractive, but it doesn't hide anything, either. Not how much you dump, but WHEN you dump it. The less you spend on "rust repair" the more you have for other things.
Something about acid-dipping the body when initially prepped for BSP? SoCal,Desert Cars can likely still have that done to remove trace surface rust and retain integrity. Not something you want to do with a car from Back East...
Mmmmm stiffness...
What size triples should I get?
Tony D replied to Nate SERE's topic in S30 Series - 240z, 260z, 280z
Not 50's. Not 50's; Not 50's. -
More like 350,000 cents in my friend's case Chris! LOL
In my testing actual CV's in the rear gave me 2-3% more HP on the chassis Dyno compared to Cardan-Type four-post U-Joints, so I doubt that hurt unless you installed them dry or packed with sand!
Twin cam head for the L6 from Derek at Datsunworks
Tony D replied to Derek's topic in Nissan L6 Forum
There's a reason K20 was chosen... -
Back in 1979, my friend bought a 1969 Corvair Monza for a price I forget... He then spent $3500 doing 'rust restoration' adding fiberglass replacement panels, etc.... Extensive work that would be considerably more now, plus paint. In 1989 I landed in SoCal, and for $1,600 I bought a 1966 Corvair Corsa Turbo. No rust. It was the first Corvair I ever saw with all the original panels underneath it, where the cables and linkages weren't rusted to nothing...where GM Part Tags and grease pencil markings were still on it. Yeah, I was a stupid kid back then. There wasn't this thing called the internet where old dudes could tell me "Take that repair panel money, fly out to LA, spend a week with a bus pass and the classifieds because they are RUST FREE out there, and selling for $500!" All I had was the local Michigan paradigm that rust was inevitable, inescapable, and cost money to fix. Of COURSE they will tell you that, it's paying them to do so! My advice: Get on Craigslist, line up a dozen prospects, fly into LA on a cheap one-way, spend a few days looking around for a rust free driver....and drive it back. You will be money ahead. Rust repair on a car that is readily available WITHOUT the rust for a reasonable/comparable expenditure---with the lack of provenance or sentimental attachment to the chassis is a disease of the mind. There is no logic for that. My friend could not BELIEVE the condition of my 66 when I showed him. Frank280ZX didn't believe my stories, either until he bought a 1979 ZXR out of a garage in Garden Grove for $500 (off a Craigslist ad he saw in Amsterdam cruising the internet. Made a call "go buy it" and it was done. He shipped it to Amsterdam before really looking closely at it. When he started tearing it down (you know, "doing it right" in the rust-belt tradition of total disassembly because SOMETHING is bound to be at the failure point at this time!) he actually called me on the phone "THE SCREWS ARE STILL YELLOW! (cad plating intact) WE DON'T NEED TO USE PENETRATING OIL ON THE SCREWS! I WILL NEVER BUY A Z IN EUROPE AGAIN! (His prior purchase of a stateside Z was one from WISCONSIN which was exactly the paradigm he was expecting. It's not that way everywhere, and it's not more than what you would spend making it structurally sound and proper to go there and buy one and simply drive it back. Those who have heeded that advice, to a man, have not regretted it!
A car is a hole in the air, suspended there by four rubber doughnuts which you can not eat. Into this hole, you throw money, which you will never see again.
I'm good for that...
"Oh no, I'm a dog lover" Punctuation is everything... "Dog Lover" or Dog "Lover" ??? At least you aren't showering with it... I get a vision of Jeff Lebowski and The Marmot in the Tub when I read that.... Introducing KagKag D'Azkal... he hangs around the house area.
More duration, more lift. Playing with lash only affects duration and valve timing events. By selectively altering variables antagonistically or sympathetically you can deduce which direction to go for power, how to optimize torque in a given set of parts, etc.
z-spec's shop in Sint Odenrode Netherlands makes a beautiful replica in aluminum of the Nissan Factory Rally tank for the S30 (100L capacity)... I've seen it, it's a work of art. But you have no spare tire well, just like a factory Z432R model. You can buy that panel from a variety of vendors from Japan, or fab it yourself if you have access to a simple bead roller.
If it can go sideways...It will... A human story...
Tony D replied to Mikelly's topic in Non Tech Board
Remember that nobody is a perfect 10... I'm an 8 You're an 8 Let it flow. -
That's a standard methodology for actuating carbs used in Europe for years... That adjustable quadrant is nice touch. The firewall adapter is a nice piece as well, but I like the look of the stock 200SX Cable through the original hole!
- 10 replies
- Mangoletsi
- Manifold
(and 1 more)
Tagged with:
In-deed! Very nice manifold/head port template and dowel jig! VERY nice!
- 10 replies
- Mangoletsi
- Manifold
(and 1 more)
Tagged with:
If you spray meth, put it downstream of your I/C and BOV, with the IAT downstream of it all... Nearest the T/B As I said, ideally it would be in a runner to the intake port, but heat soak becomes an issue in low speed running with the non-cross flow head. The plenum isn't so bad, and a handy spacer between plenum and T/B makes for a handy multiple-point access-all point. Idle air bypass is integral in N/A T/B's of old, and then to simplify the casting in 82 they went external. Now the L28ET had a vacuum controlled idle speed air bypass, but in Europe, the L28ET had the exact same idle air bypass as the N/A cars did....it's connected before, and after the throttle plate (mine is in the J-Pipe, and goes in the old CSV hole.) this allows the throttle plate to be 100% closed at idle. This is the one I used: Now, modern cars use fancy IAC Valves that idle up, fast idle, speed control for high alternator or A/C loads, but really the simple fixed bypass is easy to do and works great. The stock N/A bypass screw used 10 or 12mm hoses, way overkill! I pulled those fittings out by heating the body with a propane torch (like hot melt glue on them) and then tapped them for 1/4" hose. I used FI. Hose since I run 20+ psi of boost now and then, so it won't blow...the 1/4" line is good for zero to 2200 rpm. If you REALLY want idle up for fast idle, and A/C put some 12v solenoids found on modern vacuum operated accessories like EGR, etc, and hook on the J-Pipe side of the hose and idle bypass screw...I used a carb jet to give me fast idle, run off a GPO output configured to open at below 150F, and another relay hooked into my A/C clutch circuit so when the compressor pumps, it idles up. You and use idle bypass screws on each one if you wish, then you can adjust the speed to suit. I find a fixed orifice once defined by trial and error works fine.
- 6 replies
- sds
- 240sx throttle bddy
(and 3 more)
Tagged with:
How proud of that were they? (¿Canto Cuesta, Señor? What cost?) Looks better than the Lynx-Produced manifold...
- 10 replies
- Mangoletsi
- Manifold
(and 1 more)
Tagged with:
Correction: on an N/A it can go anywhere from the back of the intake valve to the air cleaner--most OEM's place it in the air box. I used the IAT from a '91 240SX on my 510. On a TURBO car, though, the IAT MUST be from the intake valve to either the turbocharger discharge or the Intercooler outlet---ideally in the airstream with flowing air as close as practical near the intake valve for proper air density calculations of the air as used by the engine for combustion. If you place it in the air box on a turbo car you will never calibrate it properly for the temperature difference between on boost and off-boost operation...
- 6 replies
- sds
(and 3 more)
Tagged with:
"When I soldered my first ECU together off that B&G Group Buy in 2002..."
I've never seen the electric valve on an accusump ever used other than at starting and stopping time. The accumulator bladder pushes oil into the system when below the preset pressure, and recharges when oil pressure recovers. An electric valve operating only when low would totally defeat the purpose of the accusump by preventing it's recharging automatically in-use. Usually warning lights are set below the accusump charge level ( mine was 30 psi in the accumulator, with a red light on a Hobbs switch at 7psi) red light=TROUBLE The electric valve or manual ball valve operation is the same: on before you start while cranking to prelube/buffer the bearings, and close the valve before you shut down. I hold RPMs up to have 30psi on my gauge, close the accusump valve, then shut down. In a run to the store...I don't bother turning it on unless the car has been sitting forever. I close it while it's still at fast idle, and off I go. It only stays on while I'm on-track or getting frisky. If you have radical compression, prelube/cranking assist is a nice way to go!
My turbo swap IAT went in the spacer block behind the throttle shaft. The hole you show is cold start injector, and that's where my idle bypass was connected. It may be easier for you to put it in the IC tubing or J-Pipe. I'd use that big hole for idle air bypass...
- 6 replies
- sds
(and 3 more)
Tagged with:
limiting front differential mount movement
Tony D replied to whatnow123's topic in S30 Series - 240z, 260z, 280z
I saw the site, don't forget we are "minus GST" as well! Welcome to Union Rates! Hahaha... -
Define "way overpriced"...
