        9rider
                Posts146
Everything posted by 9rider
	Anybody has a busted 5 speeds trans for sale ( wide ratio ) . Local pick up prefer in solcal ( 626 - 714 and Victorville area) I need some parts from the counter shaft to rebuild mine. The best is if you busted just the gear itself then it will be great. If you have one already opened up, please show me some pic to be sure the part i want not busted or I end up with another 100 lbs junk in my garage. Thanks . PS: if you have one good use 5 speeds for cheap ( around 300) I will take it. Thanks again.
	Cheap and Fast front Grille Mod.9rider replied to 88dangerdan's topic in S30 Series - 240z, 260z, 280z Nicely done.
	More likely alternator is dying. Mine was doing that before I replace alternator with 240sx alternator.
	Found a 75Z in the heart of San Gabriel city, Los Angeles Area $1K9rider replied to 9rider's topic in Non Tech Board Frame rail looked intact. Collision on rear driver side. Doors, hatch, hood open close no problem with consistence gap distance. Sound like i am a sale man but owner willing to lower but my wife didnt allow me to have another Z. And also i dont have parking in my condo to park all my toys.
	Just recently found a 75 280z car on CL locates in San Gabriel. I came in person to check it out. Paint is not in good condition. However, car have all stock and comes with a 5 speeds. I wouldn't let it go if I can find out a way to stack all my toys. Owner said he want to part out, but car have no rust, battery tray, rocker panel rear and front, rear wheel well, frame all in good condition ( tap with screw drive). Just a dent in the rear driver side. Car come with top G nose but lower haft no where to be found. has G nose HL pocket. Owner is nice guy and he said he can help with the tow too. Price = 1k and negotiable . Don't want this rare thing go to junk yard or part out . It is very rare to see a Z in this condition in San Gabriel area. Admin: if i post in wrong place please move my post. Thank you. PS: Car locates in Commercial ave, San Gabriel CA. Owner number : 661 877 8752.
	ZG Flares in stamped steel or injection molded plastic9rider replied to RebekahsZ's topic in Body Kits & Paint I would buy them in stamped steel. I have to always tell friends do not lean on my flare ( Fiber glass) , or it will crack.
	I could be wrong, how about antenna switch? Mine has a switch on pass side to control antenna up and down, and could drain battery if it shorted.
	76 280z Alternator upgrade HELP!!9rider replied to Abdalla's topic in S30 Series - 240z, 260z, 280z I did check my ground. My alternator is dying. I can hear whining sound, using stethoscope I know it from the alternator not the engine.
	76 280z Alternator upgrade HELP!!9rider replied to Abdalla's topic in S30 Series - 240z, 260z, 280z My 1975 have the same problems as yours. I could hear my pump change flow with the blinker , and died at stop light if I didn't rev the engine up enough.I have the 240sx 90 Amp alternator ready to swap in but my car is away from me at this moment, I will get it back next week and doing the swap and see if swapping new alternator will cure the problems.
	I turned key to all the way off position and still hear my fuel pump humming, verified , FPG went all way to 42psi. Check afm flap all good. Limitted internet cant aearch more. Nothing swap or done recently beside a bad alternator , wont charge below 1500 rpm. Everything run good till now , have to take off battery post . pressure cause leak in my fuel line . Thanks
	I will swap the alternator this weekend. Here is the link if any members choose to go that route. http://www.classiczcars.com/forums/electrical-s30/24161-240sx-alternator-swap.html I bought my 240sx alternator for $40 at junk yard and brought it to autozone to test = passed. Ola and see if I can mod the pulley.
	My stock 280z alternator gave out soon since I heard all the noise and wouldn't charge if RPM below 1500. Found a thread about 1995 240sx alternator would fit in the z with some wiring modification. However, I couldn't find where I can find the pulley to swap it. Can someone tell me where I can find a pulley shop or auto shop that have pulley. I live in SoCal Los Angeles area but I always travel all the time from Santa Monica to Fontana. Thanks guy.
	My friend at YLM junk yard has 1 . YLM located at next to Irwindale speed way. You can google it and give him a call.
- 3 replies
		- WTB
- Datsun 240z
- (and 7 more)
	AFM , or idle screw or , brake hose leak. Wires problems? AFM problem? All that can cause from a swap. I swap couple cars in life to now. Common problems is wire , when you putting new wire in your car . Should have keep the old one even it is rusty.
	76 Ca 280z no sensor. Cat light on dash..where is it? Never seen it in my life even newer cars.
	^ good post.
	This is weird, the blinker in my driver side is for the blinker and hazard light. My Z is 76 280z. I wonder if there is a difference. Edited: My mistake, I mistake with ignition control unit which is on the pass side. Yes, the dual relay on the driver side for the fuel pump.
	The dual relay on driver side control the blinker and hazard light.
