PR280z
Everything posted by PR280z
  1. Just ordered from TTT, Looking forward to more stopping power.
  2. I'm running the early79 caliper. Don't think the 300zx caliper fits this bracket.
  3. I have the Zx rears and the toyo fronts.I`m just tiered of the leaking pistons and also want more stopping power. I`m looking at 200. 300.for remanf calipers and continue with less breaking power or go big with the TTT and no worries for some time. I`ll get in contact with them tomorrow.
  4. Loy, your right. The other is just a bracket kit and you sort out your own brakes. Whats going on with the EBrakes with TTT?
  5. Its this kit or the JAG/LINCOLN kit for E-BRAKE option. I need brakes ASAP!
  6. Shopping for a brake upgrade at this moment. Are you still in the run??
  7. Something has to give, i prefer the halfshaft to go before the differential .
  8. PR280z
    halfshaft
    Man Its good to hear that.thanks!
  9. PR280z
    halfshaft
    The right side ujoint on my 280z needs to be replaced. I found a complete LEFT HAND side halfshaft and was wondering if there would be a problem using the LEFT- SIDE 280z halfshaft over on to the RIGHT SIDE?
  10. there`s two types of WHALETAILS. I dont think that is the TURBO-STYLE your looking for??
  11. Anybody have the SPICER U-JOINT PART # FOR THE 280Z HALFSHAFT/AXLES??
  12. Would the your Lbraces work with the regular headlight cover? if so how much for the Lbraces ??
  13. I`ll get to it this weekend .thanks!
  14. Thanks, and yes L28et inside: [/img] Uploaded with ImageShack.us
  15. sleeperZ, what would be the ideal psi on the regulator ? i`m at 12psi of boost.
  16. my pump:[/img] Uploaded with ImageShack.us
  17. C:\Documents and Settings\adelberto medina\My Documents\My Pictures\2011-11-09 001 this is what im using
  18. Thanks dou wing for the reply. i need to do an overall check on my set up.
  19. ok Domz., I need to check on that, but would a 60 amp relay cause any harm or would they last a little more? Thanks.
  20. If not the injectors the fuel pump stop working . Once i replace with new 30amps relays they start working again until they give out again.
  21. Running electromotive fuel pump and 750cc injectors with 30amps relays that are just not cutting it. They keep dying out. Can i run some 60- 80 amps relays??
  22. My first attempt i took gas pump rely off, but i did not wot when cranking. That`s why the low reading. On my second attempt, crank and WOT gave 145 all except piston #3 -140. 140 on all six for a turbo L28ET is good.
