I am currently building my own "O" ring fuel rail using the standard billet rail you can get from Electomotive or Arizona Speed and Marine. The rail usually runs about $12.00 per foot. You will need to either weld or thread fittings on the end of the rail for hoses and the fuel pressure regulator. I'm using a Paxton universal type and screwing it directly to the end of the rail. It looks just like the Aeromotive style. Next you will need to drill and ream the rail to fit the "O" ring injectors. The key here is to get the injector spacing correct when drilling the rail. Once the drilling is complete you will need to use a reamer to clean up the surface so the rings don't leak. The final hole should be about .020 smaller than the diameter of the o-ring. This is according SDS's tech notes. For mounting the rail I'm bending some aluminum strips then welding to the rail. I am using the same three mounting points as the stock rail. To go from a completely stock L28ET rail and injectors to the new rail, rebuilt 450cc injectors, New FPR, New fuel filter, AN fittings and hose cost me about $500.00. I'm using DSM style injectors with pintle caps self modified for my Datsun intake. The next step will be to go to 680cc injectors when I want to start making big HP.
http://store.yahoo.com/azspeed/fuinco1.html
http://www.getfuelinjected.com/efi_parts.html
