So I'm swapping an 83 turbo l28 into my 73 240z for the past year, and have been having this problem ever since I started this swap a year ago.  My harness does not have the Fuel Pump Relay Harness (FPRH) that has the relay and plugs into the EFI Harness.
I've posted on here several times on the WTB for this piece and have bought 3 seperate harness packages thta failed to include this so I'm no longer going to take the chance of purchasing another harness on here.
My problem is I have the B/W wire that comes from the FPRH goin to 12v switched and nothing else from that piece going elsewhere.  I notice on the FSM the L/R wire goes to the relay as well as the G wire, now these two on my car are not connected to anything as I do not have a relay to the fuel pump.  For now for diagnostic purposes I'm not going to put a relay in until I can figure out what the issue is:
Now I have spark coming from the coil, and to the plugs, I have Fuel Pressure, however I have no Injector Pulse, this is my 3rd ECU to have this issue, which leads me to believe I have something not wired.  I've combed through the EFI Harness maticulously and the only thing I see absent from being pluged into either 12v, ground, or anything else is the wires coming from the FPRH w/ the exception of the B/W wire which is going to 12v switched.
When I previously set up this swap with the FPRit would either leave the Fuel pump running after turning the IGN off, or the last time I set it up (ACCORDING TO ALL AVAILBLE DIAGRAMS HERE AND FSM) it melted the relay, several connectors, as well as fried the ECU. So I have decided that there has to be some way to not include the Fuel Pump Relay with the EFI harness and make the appropriate connections to the wires that connected to the relay.
Does anyone know how to set up the efi harness independent of the Fuel Pump Relay Harness???
