Everything posted by Oddmanout84
I recently sent out a set of L28ET pistons to Swaintech for ceramic dome coating and anti friction coatings for the skirt. Yes, they're stock replacement CAST pistons, make fun of me all you want for dumping more money for coatings than the actual cost of the pistons. Couldn't see going forged for a street engine, but I wanted some extra insurance. Anyway, I got a thought in my head the other day. Knowing that the ceramic coating not only insulates the piston from heat and in turn increases combustion chamber temps, could this be causing more unforeseen problems than it may solve? Namely, since my cylinder head and valves DO NOT have coatings, could the increased temps be increased and focused on my cylinder head, leading to higher coolant temps and possible detonation? I'm worrying that it was a bit dumb not to catch this before I sent my pistons out, but fortunately the engine is not back together yet and I still have time (though not the money at the moment) to get the chambers coated. I've seen threads on engines that have received these coatings and the advantages, but so far have not found much documentation on disadvantages (besides possible break-down and flaking). If anyone is willing to shed some light on this, I'd be interested. That and if the coating is going to increase my combustion temps so greatly as to it being enough to completely throw off my Haltech's current tune.
Is the fan that blows air onto the injectors necessary?
Oddmanout84 replied to Steveoen's topic in Nissan L6 Forum
My "mystery fan blower thing" was a useless non-working piece of junk ever since I first bought the car in Temecula CA. I had no idea what it was at the time. I ran my Z through the hot SoCal summer and then drove it home to CT before I went overseas, taking the southern route through the desert and the deep south. Never had a problem with vapor lock. Ever. -
Cracked crank pulley, worn woodruff keys, crank
Oddmanout84 replied to Oddmanout84's topic in Nissan L6 Forum
Working on it! Waiting on parts, then waiting on machining, then I get to put humpty dumpty back together again. In the meantime I'm improving other areas that would otherwise keep the car from moving (possible 240sx transmission swap, cleaning up ALL the engine bay wiring). The only thing I'm missing is a welder, otherwise I'd be fabricating a Ron Tyler diff mount and fixing my fenders under the flares. May remedy that this weekend. -
I still have further checks to do, but I guess I've essentially already tested this one when I put each piston/rod assembly on my bench. They're all flopping around nicely though not in any areas they shouldn't (that's I've seen thus far). I am worried about them being slightly bent though, with how much play was in the crank. -
I do the same. It bothers me to start my girlfriend's car because you're forced to depress it in order to start. I've actually yelled at her when I first noticed she was holding the clutch in while stopped in traffic. She doesn't do it anymore. -
Well, I finally have the block completely torn down. Here are my findings: Two of my cylinders have pitting in them like this (#3 and #4)from where some moisture presumably accumulated while the engine sat in my friends garage for the four years before I bought it. This was not visible until the head was removed. Hopefully a .020 overbore will fix it, and I have .020 oversized pistons on the way. The multi layer steel head gasket looks like it was leaking between a coolant passage and cylinder #2. Bought an OEM composite gasket to fix, hopefully the fact that it blocks off coolant passages isn't going to cause any issues (have seen varying opinions on the forums). I've now torn down 3 L28's within the past couple months. These are the crank pulley bolts. All are shown in the same condition as when they were pulled. On the far left is the bolt from my original L28E, its obviously shorter, never gave me any problems. The middle bolt is from my spare L28ET. The far right bolt is from my current L28ET, which I just pulled. Unlike the others, it has a lock washer installed. I've been informed that lock washers are actually detrimental in some situations, like on exhaust bolts, in which they act like springs and can actually loosen the fasteners they're meant to lock. In the case of this one, I'm willing to bet it also prevented the actual torque on the bolt from equaling the indicated torque on the wrench. And the crème de la crème was discovered when I removed the oil pan and began inspection and disassembly. My crank could be moved laterally in the block over 1mm. You can guess where this is going. Thrust bearing front face: Thrust bearing rear face: Crankshaft: I'm willing to bet the crank is toast. Its gouged pretty well. I don't think I'm even going to bother with a magnaflux, lol. I'll save that for one of my spares... This movement could very well explain the premature timing chain guide wear I posted in another thread in this section. Before someone says it, no, I'm not a clutch rider. I learned to put the box in neutral at every stop with my first car. The clutch that's in there now is a circular sprung RPS which isn't much stiffer than stock. I'd like to thank everyone who convinced me to be anal retentive on this one. If I had just gone with a quick fix based on outside appearances, it could have ended a lot worse. Luckily, it looks like I'm down and out the previous parts mentioned, a set of Clevite bearings, and everything else I have spares of. I'll be getting the conrods checked too to make sure they're not bent. I know this stuff isn't groundbreaking or anything new, but I figured I'd document it anyway for people to look at. More pictures available upon request. -
I'll be waiting with anticipation and a DVR recorder for the day they show your collection on that tv show.
Mat's "Flat Black Z" Build Thread
Oddmanout84 replied to FlatBlack's topic in S30 Series - 240z, 260z, 280z
Lmfao! -
+1 The southwest is a land of plenty when it comes to junkyards, where they seem to hold onto things longer and not crush 20+ year old cars like here in the northeast. Better condition too. That being said, you'd be surprised what turns up if you poke around.
You guys are making this hard! Lol. My usual anal-retentive self is at war with my desire to get this thing back on the road so I can enjoy the summer driving. Tony- Yes, I'm new to the world of magnaflux but I understood that it required a magnet. I just thought maybe the kits came with a small electromagnet and the "dye" in the aerosol cans had some sort of ferrous particles in it. I was wrong. And you're right, I should just get it professionally inspected instead of trying to do it myself. Upon cleaning and further inspection with the block still in the car, I discovered the cylinder walls of especially #3 and #4 are pitted pretty bad near the top (but below top of stroke). Bad enough to catch a fingernail. Could be because the motor had sat for 4 years in a garage, but regardless the buildup of carbon and oil sludge looks like the rings have lost a lot of oil control. Perhaps I'm going to far in this respect but I figure now since I SHOULD be inspecting the crankshaft, maybe I should just get the whole block out and bore .020 over and get some matching ITM pistons. I wanted to do that at some point anyway. -
Thanks guys for all the info. I do know that the woodruff keys are only there for indexing the damper on the crank, and that the bolt/washer combo is whats really clamping it on there with friction. I'd LIKE to think that this engine was built correctly. The guy who made it around 2000(who's also a member of this site) seemed to know his stuff, and put most of his work on this engine into blueprinting the bottom end and using clevite bearings. He seemed to have really good attention to detail with what he did. But we're all human, and I should really pursue this further. Before the motor went into the car I DID crack open the oil pan and valve cover to inspect and check torques. However, that's not going to find possible spider cracks. I have two spare L28 cranks that I could theoretically use, but I'm not even sure that THOSE don't have hairline cracks either. I poked around the internet for magnaflux inspections and even found a few do-it-yourself kits that include the dye and sometimes a blacklite. Would it be worth it to do my own inspection or should I just find a machine shop that can professionally do it for me? Usually, I like to do things myself and can't see this as being over my head, but I could be wrong. Its certainly something important enough to make sure its done right. Otherwise, there's an airport nearby which should have some sort of A&P shop with capability for magnaflux inspection. -
Started out as an intermittent rattle. Found a crank pulley bolt that had backed off, cracked and worn crank pulley, worn woodruff keyway, timing chain guide worn to the metal, combustion chambers covered in hard and flaky deposits. I've had this motor for less than a year, and its a very low-time motor (>6000 miles). Life is pain.
I don't trust autozone to have the Japanese timing kit. So I got it from motorsport. Here's the guide:
The oil pump/dizzy drive gear didn't want to come out, had to file down the ridge that was formed on the crank. Other than that, it looks like a shim and a bit of JB weld may fix this for now... -
Dunno. From that link it looks like the 280z vinyl is cheaper. Why would you want the 240 set? The tranny tunnel? I have a 240 vinyl set that I got used for free, and it fit. Granted, I didn't use the tranny tunnel piece. Everything else worked just fine though with minor modifications (just had to cut 2 bolt holes for the 280z shock tower mounted seatbelts). Edit: I can't see why the tranny tunnel piece wouldn't fit as well, I just didn't use it because mine is freshly carpeted already.
Blowing up coil's like they are sparklers...
Oddmanout84 replied to Airjockie's topic in Trouble Shooting / General Engine
Hey dude. Guess who's still trying to connect the MSD to your old setup. -
I'd just as soon be anal retentive and add the 10 micron as a "last chance" filter just before the injectors.
The sad thing is, this motor only has about 5000 miles on it since its previous owner rebuilt it. -
Yeah, I've been looking to get a hoist for quite some time. But now was not supposed to be the time. Yeah, its really hard to see the slot in the crank. Its not absolutely terrible, but it seems widened a bit due to the wear. Thanks for the responses, guys. Its a bit early to tell, but I imagine I should be able to see it better when I remove the timing cover. Hopefully its as simple as putting in a shim or locktite... but I dunno... -
So it started with my last thread here about finding my timing chain guides worn. While taking the engine and everything around it apart, I found this: The crank pulley rotates several degrees independent of the crankshaft. So being upset already at finding other things, I pulled it off to see what was going on. This is what I found next: The crank pulley is visibly cracked, but it doesn't end there. On the crank the woodruff key was sitting loosely in its slot. It slid out easily with my fingers. As you can easily see, the woodruff key looks like its been wobbling back and forth for a long time. I have a spare L28ET crankshaft sitting on my workbench, so I pried off another key to see if the wear extended to the crankshaft slot. It did. The key fits easily into the slot and wobbles around. The slot is larger than what it should be. Not good. I don't know how this has happened, but the bolt was tightly on the crank when I installed the motor. Now its not. Is my crank screwed? Do I have to pull my crank and install another one? I'm already in the pit in terms of money that I didn't want to spend this month, but this looks to be yet another thing that's going to se me back. I don't even have an engine hoist here, as the nearest friend I have with one is 200 miles away and I have no means of getting it without a car to drive. If anyone has input, it'd sure be appreciated...
So for a while now (since about mid winter when I replaced my clutch is when I first noticed) I'd been hearing a strange rattling sound from within my motor. Usually it just did it while it was cold, then the sound lessened and went away once it heated up to running temps. Now since last Friday its been doing it at all temperatures. I went to a Car/Food/Beer meet over the weekend and started the motor up so I could get some others to lend their opinions. Even a Datsun vet with more experience than years in my life could not pinpoint the noise with my stethoscope, however someone remarked that it sort of sounded like timing chain noise. So when I got home I popped the valve cover to check everything. This is what I've found so far. Its difficult to see, but that guide on the left "tight" side of the motor looks to be worn all the way through the friction coating to the metal. This would explain the noise. What it doesn't quite explain is that this motor only has about 5000 miles on it since it was rebuilt. This seems quite excessive for that low amount of mileage. You also can't see it, but the tight side chain guide has a slight curve to it. Looking at the guide I recently pulled from another L28ET, I can see that its perfectly straight. Is there a difference between the timing chain guides over the years? Possibly this being the guide meant for and earlier L24 or L26? I wasn't the one who rebuilt the motor, I was lucky enough to get it from a friend who pulled it out of a car that used to frequent Limerock and Watkins Glen. I've talked to the guy who used to own the motor, but he doesn't remember everything about what he did to the motor since it was around 10 years ago. I've done minimal work to it, only checking torque on the essential bolts and studs before it was installed. Everything else I've done has been on exterior ancillary components. If anyone has any input about what could have caused this at such low mileage (incorrect timing, incorrect parts, etc.) I'd appreciate it. I'm currently taking the motor apart and trying to avoid removing the oil pan (if possible) since I recently put in new synthetic.
Janaka if I may ask, how did you connect the -10 line to the stock tank? Did you use a flaring tool on the stock pickup line out of the tank or did you just solder the stock lines shut and weld in some AN fittings? There seems to be waaay too much of a size disparity between the stock feed line and -10 line to safely clamp the hose down and keep it from leaking.
I painted my urethane airdam over a year ago, no stress cracks or anything yet. Used single stage urethane paint just the same as the rest of the car, but before I sprayed it I cleaned the airdam multiple times with denatured alcohol, then sprayed it with a few coats of adhesion promoter before primer. And yes, I've also removed the airdam a few times since then. I was careful, and tried not to flex it too much, but it still did a little. Still no cracks. Never mixed in any flex agent. Edit: If ONLY they made urethane ZG flares, I'd buy them in a heartbeat. I already have a rock chip out of my rear passenger side from the tire slinging a pebble.
Yep, its the regular blue. I went back and forth between it and cobalt but eventually went with this blue. I just wish I saw an example of the cobalt, I'm sure its still bright enough. Its not the GPS speedo, because that one doesn't have the turn signal and highbeam indicator. Without it, I was afraid that I would be a perpetual offender of blinding people.
