proxlamus©
Everything posted by proxlamus©
wow great looking plenum! very impressive!! did you mig those aluminum welds?!
Sweet.. i added everything up.. Spacers > .375" (280z hubs only) from SummitRacing.com $60.95 per pair Calipers > 1990 Toyota 4 Runner from RockAuto.com $50 each + $30 for a core Rotors > 1984 Nissan 300zx vented from RockAuto.com $30.79 each Pads > Hawk ~$120 Master Cylinder > 1981 Nissan 280zx 15/16" brake master from RockAuto.com $28.79 (without caps and reservoirs) Grand total of $371.95 plus shipping for the entire setup. Thats a $418 dollar savings! from Arizona Z car's setup. *note* I may also need to make my own brake lines.. but thats not too much *note* Seriously you can't go wrong
for the price im sure the new Genesis.. they will be everywhere.. just like 350z's, mustangs and subaru wrx's lol
you know for $27k for the premium Genesis.. and almost $23k for the base.. I think I would rather buy a low mileage used Nissan 350z for the money... whatcha guys think?
well that solves it... I have a street car I enjoy taking to the track like 2-3 times a year. thats it Why bother spending soooo much on Wilwoods! If they are good enough for VARA race cars.. its good enough for a street/play car. If I had a full blown track car that never touched the roads it makes sense that Wilwoods would be ideal.
its a throttle body as an exhaust cutout
So i've been heavily debating which brake setup I should go with on my baby.. Arizona Z car's Wilwood 4 pistons brake setup $789 + proportioning valve - or - Toyota 4x4 VENTED calipers and 300zx rotors $360 I am trying to justify the price.. I would like some more help! Toyota 4x4 vented setup Pros - Cheaper - Parts and rebuilds are cheap and over the counter - 4 pistons - Cheap and easy to find pads Cons - Cast iron?/steel? calipers >> added weight >> retains heat longer which is bad - smaller rotors - they dont look as cool Arizona Z car Wilwood setup Pros - Look amazing - Weight Savings with aluminum calipers - Better heat dissipation with aluminum calipers - Bigger rotors - 4 piston Cons - Expensive - NEED a proportioning valve - Replacement parts and rebuilds are order only and slightly higher costs - Pads are order only and also slightly higher in cost These are things I can think of off the top of my head and I'm sure there are plenty of other pro's and con's im hoping you guys can point out! I need help understanding that they are both 4 pistons.. with the same pad material and the same amount of braking force from the 280zx master cylinder.. shouldn't the car stop the same?!
lol funny story im about to fix the SAME spot on my Z tonight!!
impressive welds on that cage!! Tig or Mig on those bad boys?
New stuff, short shift, fidanza, zx trans, OBX, test drive.
proxlamus© replied to cygnusx1's topic in Miscellaneous Tech
roostmonkey just made a ton of R/t mounts.. $62 shipped is a great deal I thought you were converting to a Z32 transmission? I may be mistaken. The fidanza flywheel is soo weird to get used to .. but you'll fall in love with it soon! -
MODS - Not Sure Where This Should Go - CUSTOM TOW HOOKS
proxlamus© replied to 240Z2NV's topic in Fabrication / Welding
http://forums.hybridz.org/showthread.php?t=144819 One of our vendors currently sells them for a 240z and 280z.. very very moderately priced! -
Subaru and Suzuki dropped out of the WRC... The WRC now consists of.. Ford and Citroen. booorriinnngg I cant believe this.. seriously?
Constructing in-car computer for 78 280z
proxlamus© replied to themutt33's topic in Miscellaneous Tech
lol.. be nice! that was his first post! i wouldn't call him a 2 year old! just needs to do more research! -
CCD Cam for sideview mirror to reduce drag
proxlamus© replied to ZR8ED's topic in Windtunnel Test Results and Analysis
No offense.. but your driving a 30 year old sports car designed to be cheap and affordable... The car was not built for aerodynamics.. I severely doubt changing the mirrors would provide any beneficial effect to the performance of your car. In fact this would hinder the safety of your car. On top of that your spending money on something that can be truly beneficial. We all know what can be done cheaply to slightly improve the aerodynamics.. but I think the mirror idea is pointless. Sorry man -
Aww man! Remember i sent ya a PM saying you will need to do some slight tapping on the actual transmission tunnel to fit the adapter. Either that or cut off the corner of the bracket with an angle grinder or something. I didnt realize the bracket touched the tunnel untill I finally raised the unit in place. Like I mentioned the unit was a quick prototype... but works with a bit of massaging. The machine shop didn't charge you much did they?! I feel bad now
I love being cheap! I found this peg board in the scrap bin at home depot.. $1.01 and the peg hooks at harbor freight on sale for $2.99! The 1x2's in the back were $2.10. Its actually starting to look like a shop bench! yay!
Nice! I really would like to do this now!! Thank you for the write up and sharing the info! saweett!
I added some new cross beams for more support! now it's rock solid!! I was going to add a bar across the rear of the bench but its sooooo sturdy as it is! why bother! lol I also added a worklight, 5" vice and threw some crap under the bench... I know its a mess!! All she needs now is PAINT! oh well
Ken didn't you buy my relocator?! what additional work was required?!
Well I finally bit the bullet and decided to build a workbench!! I was pondering the idea of what the hell I could use to build the frame.. keep in mind im cheap.. very very cheap and I hate spending money. I currently work at Home Depot until I finish up my pilot ratings and hopefully get hired on someday from someone.. and one day.. it dawned on me. pallet racking! I'm standing in a warehouse full of it! I didn't want to steel the racking and get fired.. so I tried craigslist. Someone was closing out a warehouse and was selling 2x3 cross beams at 112" inches long. I figured I could grab 4 or 5 beams and start chopping them up. The guy only wanted $10 per beam! 5000 pounds capacity each.. it'll do. The next step was figuring out the table top.. i could grab some OSB.. but I want to weld.. so I found some 3/16" thick steel for $60 + $5 labor to cut it. I don't want to post my measurements because everyone is different.. we are all different heights and have different size workshops/garages. But my particular bench is 28"x60". Its perfect for me. Pallet racking laid out and i'm beginning to cut it all up Table top mock-up and supports Legs and plate steel to bolt onto a caster or keep free standing Table top and supports tack welded together somewhat. This is in the early stages. I had to grind off the powder coating The bench is not yet finished. It's a bit wobbly so I need to add some cross bracing or square it up some.. needs to be a bit stronger. Anyway... I need to do a little more cutting.. grind down all the paint and paint it black.. and weld on new cross bracing... then she should be complete! I'll add a tube for holding my MIG gun, attach a vise and some other random crap.. but here ya go.. $105.
