drift_inertia
About drift_inertia
- Birthday 03/11/1983
Contact Methods
Website URL
http://www.myspace.com/driftfc3s
Yahoo
drift_inertia
drift_inertia's Achievements
10
As long as it's electric, is SOLELY for powder coat and no foodwill be prepared in it, and has enough space for the parts it is easy to make custom racks and would work fine.
My 240 got carjacked friday
drift_inertia replied to icewtr's topic in Gen I & II Chevy V8 Tech Board
I'm in modesto in nor-cal, If you don't mind driving up I have a clean 260z fron end i'd sell you for $150 o.b.o, clean hood, fenders, headlight buckets, clean oem lower valance corners and blinkers. Lemme know if you wanna see pics -
I am parting out a 74 2+2 lemme know if you need anything. -
I have a set if your interested, I am located in modesto ca so i'd have to ship. I'll take some pics and mail them to you. I can either sell to you through here or I can put them on my ebay store. My ebay store is www.treasurefromtheattic.com I am not sure what they are worth, what kind of price are you thinking?
the hard shell back makes me believe it is out of a roadster of sorts
I heard he was taken out by the ShAmWoW guy............... o_O
Not true on an N/A car, you need some back pressure in your exhaust system, on a TURBO car you want the minimum amount of backpressure after the turbo for higher hp, but the the exhaust manifold to turbo gives you enough back pressure to keep your motor happy. so N/A needs some backpressure TURBO you want the least backpressure possible after the turbo as possible. at least in all my years thats the way it's been.
before you have the manifold machined flat, you can always lay a flat metal file acrocss the manifold and run it back until you see fresh clean metal to get it flater then it is in an attempt to get it to seal better. I had to do it on both of my intake manifolds because they woerent sealing right.
happy fathers day, today is my first my daughter was born 4/26/09. So I am still a total noob at being a father but it comes pretty naturaly to me which is a definente good thing. have a fun and safe day fella's Matt
Autometer Pyrometer bung---Where can i get one?
drift_inertia replied to streeteg's topic in Exhaust
Sorry if i described it wrong, my sensor didnt, have threads either. It was an autometer c2 egt gause the probe was about a 1/4 inch? thick of round stock that was bent into a 90 degree, i didnt have the fittings that came with it except for the the piece the sensor slid into. the piece the sensor slid into looked like a nut with a setsrec drilled into the side of it and abou 4 threads at the end. i found a nut that fit the threads and drilled hole in my exhaust spot welded the nut to the exhuast and installed the senor and piece i had. BUT I have also seen people take a drill bit the same size as the sensor,find a nut the right size to drill through and then weld the nut to the exhuast, drill hole through the nut and piping ,insert the sensor and the use a hose clamp to clamp it down by wrapping around the exhaust pipe and sensor. I only have experience with autometer egt's and sensors so i'm not sure if they are all 90 degree bend or not. -
lol
its the disclaimer from the betamotorsports "ultralight suspension" in the bench racing section. " This product is meant for educational purposes only. Any resemblance to real persons, living or dead is purely coincidental. Void where prohibited. Some assembly required. List each check separately by bank number. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Postage will be paid by addressee. Subject to CAB approval. This is not an offer to sell securities. Apply only to affected area. May be too intense for some viewers. Do not stamp. Use other side for additional listings. For recreational use only. Do not disturb. All models over 18 years of age. If condition persists, consult your physician. No user-serviceable parts inside. Freshest if eaten before date on carton. Subject to change without notice. Times approximate. Simulated picture. No postage necessary if mailed in the United States. Breaking seal constitutes acceptance of agreement. For off-road use only. As seen on TV. One size fits all. Many suitcases look alike. Contains a substantial amount of non-tobacco ingredients. Colors may, in time, fade. We have sent the forms which seem right for you. Slippery when wet. For office use only. Not affiliated with the American Red Cross. Drop in any mailbox. Edited for television. Keep cool. process promptly. Post office will not deliver without postage. List was current at time of printing. Return to sender, no forwarding order on file, unable to forward. Not responsible for direct, indirect, incidental or consequential damages resulting from any defect, error or failure to perform. At participating locations only. Not the Beatles. Penalty for private use. See label for sequence. Substantial penalty for early withdrawal. Do not write below this line. Falling rock. Lost ticket pays maximum rate. Your canceled check is your receipt. Add toner. Place stamp here. Avoid contact with skin. Sanitized for your protection. Be sure each item is properly endorsed. Sign here without admitting guilt. Slightly higher west of the Mississippi. Employees and their families are not eligible. Beware of dog. Contestants have been briefed on some questions before the show. Limited time offer, call now to ensure prompt delivery. You must be present to win. No passes accepted for this engagement. No purchase necessary. Processed at location stamped in code at top of carton. Shading within a garment may occur. Use only in a well-ventilated are. Keep away from fire or flames. Replace with same type. Approved for veterans. Booths for two or more. Check here if tax deductible. Some equipment shown is optional. Price does not include taxes. No Canadian coins. Not recommended for children. Prerecorded for this time zone. Reproduction strictly prohibited. No solicitors. No alcohol, dogs or horses. No anchovies unless otherwise specified. Restaurant package, not for resale. List at least two alternate dates. First pull up, then pull down. Call toll free before digging. Driver does not carry cash. Some of the trademarks mentioned in this product appear for identification purposes only. Record additional transactions on back of previous stub. Unix is a registeredtrademark of AT&T. Do not fold, spindle or mutilate. No transfers issued until the bus comes to a complete stop. Package sold by weight, not volume. Your mileage may vary. This article does not reflect the thoughts or opinions of either myself, my company, my friends, or my cat. Don't quote me on that. Don't quote me on anything. All rights reserved. You may distribute this article freely but you may not make a profit from it. Terms are subject to change without notice. Illustrations are slightly enlarged to show detail. Any resemblance to actual persons, living or dead, is unintentional and purely coincidental. Do not remove this disclaimer under penalty of law. Hand wash only, tumble dry on low heat. Do not bend, fold, mutilate, or spindle. No substitutions allowed. For a limited time only. This article is void where prohibited, taxed, or otherwise restricted. Caveat emptor. Article is provided "as is" without any warranties. Reader assumes full responsibility. An equal opportunity article. No shoes, no shirt, no articles. quantities are limited while supplies last. If any defects are discovered, do not attempt to read them yourself, but return to an authorized service center. Read at your own risk. Parental advisory - explicit lyrics. Text may contain explicit materials some readers may find objectionable, parental guidance is advised. Keep away from sunlight. Keep away from pets and small children. Limit one-per-family please. No money down. No purchase necessary. You need not be present to win. Some assembly required. Batteries not included. Instructions are included. Action figures sold separately. No preservatives added. Slippery when wet. Safety goggles may be required during use. Sealed for your protection, do not read if safety seal is broken. Call before you dig. Not liable for damages arising from use or misuse. For external use only. If rash, irritation, redness, or swelling develops, discontinue reading. Read only with proper ventilation. Avoid extreme temperatures and store in a cool dry place. Keep away from open flames. Avoid contact with eyes and skin and avoid inhaling fumes. Do not puncture, incinerate, or store above 120 degrees Fahrenheit. Do not place near a flammable or magnetic source. Smoking this article could be hazardous to your health. The best safeguard, second only to abstinence, is the use of a condom. No salt, MSG, artificial color or flavoring added. If ingested, do not induce vomiting, and if symptoms persist, consult a physician. Warning: Pregnant women, the elderly, and children should avoid prolonged exposure to Happy Fun Ball. Caution: Happy Fun Ball may suddenly accelerate to dangerous speeds. Happy Fun Ball contains a liquid core, which if exposed due to rupture should not be touched, inhaled, or looked at. Do not use Happy Fun Ball on concrete. Discontinute use of Happy Fun Ball if any of the following occurs: Itching, Vertigo, Dizziness, Tingling in extremities, Loss of balance or coordination, Slurred speech, Temporary blindness, Profuse Sweating, or Heart palpitations. If Happy Fun Ball begins to smoke, get away immediately. Seek shelter and cover head. Happy Fun Ball may stick to certain types of skin. When not in use, Happy Fun Ball should be returned to its special container and kept under refrigeration. Failure to do so relieves the makers of Happy Fun Ball, Wacky Products Incorporated, and it's parent company, Global Chemical Unlimited, of any and all liability. Ingredients of Happy Fun Ball include an unknown glowing substance which fell to Earth, presumably from outer space. Happy Fun Ball has been shipped to our troops in Saudi Arabia and is also being dropped by our warplanes on Iraq. Do not taunt Happy Fun Ball. May cause any of the aforementioned effects and/or death. Articles are ribbed for your pleasure. Possible penalties for early withdrawal. Offer valid only at participating sites. Slightly higher west of the Rockies. Allow four to six weeks for delivery. Must be 18 to read. Disclaimer does not cover misuse, accident, lightning, flood, tornado, tsunami, volcanic eruption, earthquake, hurricanes and other Acts of God, neglect, damage from improper reading, incorrect line voltage, improper or unauthorized reading, broken antenna or marred cabinet, missing or altered serial numbers, electromagnetic radiation from nuclear blasts, sonic boom vibrations, customer adjustments that are not covered in this list, and incidents owing to an airplane crash, ship sinking or taking on water, motor vehicle crashing, dropping the item, falling rocks, leaky roof, broken glass, mud slides, forest fire, or projectile (which can include, but not be limited to, arrows, bullets, shot, BB's, shrapnel, lasers, napalm, torpedoes, or emissions of X-rays, Alpha, Beta and Gamma rays, knives, stones, etc.). Other restrictions may apply. This supersedes all previous notices. It is understood that you have read and agreed with the terms stated in this disclaimer." lol i spent 10 minutes reading that, whoever wrote it must have had alottttt of caffeine that day. amazingly the only repated prt was "slippery when wet " the rest are used only once. lol
Need Wheel BS OS info
drift_inertia replied to hapoholi's topic in Brakes, Wheels, Suspension and Chassis
the offset seems real shallow if you are planning on running the wheels with no spacer behind them. i have a set of 16x8 f 16x9 r watanabes with 0 offset all the way around and they barely meet the stock lip of my 260. i would get a better offset especially for flares, other then that yes the dimensions will fit -
WOW o_O that was an insane crash, i'm glad to see they made it out in tact!
if you truly are boosting 15 psi, then yes your probably are running on the lean side, but being lean doesnt always mean you will detonate. timing, and heat come into play with detonation also. you may just be ( safely lean ) where you haven't started to ping yet. maybe you have really good octane gas in the car or just havent hit a real hot day where you live and you've lucked out to this point. do you know anyone with a spare boost gauge to hook up and see if yours is reading right? 15 psi of boost is hi for stock injectors and stock fpr, with an aftermaarket fpr you may be able to squeeze it out though? just my 2 cents
