68
I never broke a stub axle, and I autoxed every month for 8 years and almost never ran less than 3/16" toe in. I also did ~10 track days in that time. Once I had a "bad zero" on the alignment rack and ran closer to 1/2" toe in on the back for a couple weeks, including an autocross. Figured it out when my brand new tires were corded. On the other hand, there was a guy just the other day on www.classiczcars.com who broke a stub axle just tightening the nut after changing bearings. With a 40 year old car and suspect axles, you really never can tell. If you're putting a lot of power down, replace them. Toe in will drive the loaded outside rear tire back towards the centerline. It helps a lot with lift throttle oversteer.
Toe in the rear tires. Run 1/8 or 3/16 inch total, and then don't drop the throttle in the middle of corners.
My Dream LS7GTZ.......project underway
JMortensen replied to cobramatt's topic in S30 Series - 240z, 260z, 280z
2248... That's just a bit heavier than I would have thought. Means that I'll have to pull out all the stops to hit my 2260 goal for X Prepared. Do you have the corner weights? Awesome car, just awesome. -
Exactly. The guy who bent my main hoop had the JD squared bender. He does rally cages for a living, and he had basically a bay in his shop with the bender on a stand bolted to the floor right in the middle. I don't doubt that it is a better bender, but if you don't have the hydraulic ram you need it BOLTED TO CONCRETE (or something else very substantial). You can unbolt it from the floor if you need that space, but I hope you don't need to get under the car where the studs are sticking up out of the floor then. It is true that if you have the hydraulic ram you don't need it bolted down, but then you're adding more money. And it does bend horizontally which means the tubing swings around the space. One could conceivably bend a main hoop with the Speedway type bender in a 3' by 12' space.
Actually, I should keep my mouth shut. I'm realizing that I don't know if he was using MM adapters or if he did the 280ZXT companion flanges like Pete Paraska described years ago. Regardless, the 280ZXT is a different chassis with totally different suspension, so the idea that something fits on that chassis doesn't mean that it will fit on an S30.
I appreciate the plug. That said, I haven't actually checked the 280ZXT shafts for bind. Dave Irwin told me that he had to disconnect his LCA to get the shaft installed which isn't a good sign, but it would still need to be checked to be sure that there is a problem. If they don't bind, then there wouldn't be much difference in those vs the 300ZXT shafts. The 300ZXT shafts are stronger, but broken 280ZXT shafts are not very common. As long as this isn't a drag car, he'll probably be OK. I do believe that Joe can get the 280ZXT adapters, and given the threads about how hard it is to get a hold of MM, buying adapters from Joe would be a good idea.
More elbow grease and a place to mount it. I don't think it comes with dies either.
I've got the $400 hydraulic bender from www.speedwaymotors.com. It has relatively large radius dies (7" I think) and it can't do really sharp bends one after the other. For the price I think it's a good bargain and I am not going to be building a lot of roll cages, so it was well worth it to me. http://www.speedwaymotors.com/3rd-Generation-Hydraulic-Round-Tubing-Bender,6614.html
Amazingly, if the title is to be believed, this resulted in only a broken collarbone:
There was an old rotary manifold that used a single 44 Mikuni (worked pretty good too). You might look on Mazda sites and see if you can find a single carb there. Or check with Todd at Wolf Creek Racing. He might have a single lying around, and he's a good guy to deal with.
Need help with dragging rear disc brakes.
JMortensen replied to RebekahsZ's topic in Brakes, Wheels, Suspension and Chassis
Because you have less weight transfer when it is wet, you can actually use more rear braking. So set it for dry and then up it for wet if you want. I like the way Neil Roberts suggests setting bias, some others here have taken issue with it, but as I said in that thread I kinda lucked into his setting and it worked fine for me. http://forums.hybridz.org/index.php/topic/99500-tail-wagging-under-hard-braking/page__p__932930__hl__%2Bbrake+%2Bbias+%2Broberts__fromsearch__1#entry932930 -
Just get some ATE Super Blue fluid. It's good fluid and it's blue. -
Either way, I'd go with the 3.54. I've run the 3.70 with the late ZX 5 speed and it isn't too tall for a NA car. I have the feeling your turbo would like it a lot.
You guys ever consider launching in 2nd?
There are two KYB's. The GR2's (which I think have been renamed) are the comfy shocks. The gas-a-just are the really stiff ones. The GR2's are much smoother riding than the Tokico Blues.
Don't know the price but the KYB GR2 seems to be the best "cruiser" shock.
300 ZX Turbo CV shaft disassembly and reassembly
JMortensen replied to JMortensen's topic in Drivetrain
16. This is the biggest "trick" to the reassembly. If you do not "tuck in" the circlip and try to hammer the shaft in, you will wreck the circlip. These following two pictures show what it SHOULD NOT look like as you begin hammering the CV shaft into the inner CV. 17. This picture shows HOW IT SHOULD LOOK. Apply a little pressure on the shaft into the inner race and tuck the circlip into the groove with a small screwdriver. Then without letting the pressure off, hit the end of the CV shaft with a dead blow hammer. It shouldn't take a lot of force to compress the circlip and get the shaft to slide into the inner race. If you find you're hitting it really hard and it's not going, the circlip has moved. Ease up, start over, tuck in the circlip, and hammer in the shaft. 18. Apply a very light coat of grease to the shaft, slide the inner CV boot onto the shaft and work it into position. You could have put the CV boot on the correct side earlier on, but I like to do it at this stage so that it doesn't get in the way. Even with the thicker M2 shafts, it shouldn't be difficult to slide the boots across the shaft. 19. Slide the second boot and the outer CV race onto the shaft. 20. Re-install the inner snap ring if you're using stock shafts, this step is unnecessary if using M2 shafts. 21. Re-install the cage onto the race and the ball bearings into the cage. 22. Re-install the inner race/cage/bearing assembly onto the CV shaft and install the snap ring. Now you can decide whether to flip the race for extra room. If you're using stock shafts on an S30 chassis, I don't think it does enough to alleviate the binding issue. If you're using M2 shafts, I don't think it is necessary to flip the race at all, but it probably won't hurt anything either. 23. Greasing the outer CV. Same principle as the inner here, you want the grease to really get into all the bearing surfaces, but there is no need to fill the entire 3" deep CV cup with grease. I would put maybe an inch and a half of grease in the bottom of the outer race housing and set it down on a workbench, and then plunge the bearing into the grease. This should pack the grease in much the same way that a bearing packer forces grease through a wheel bearing. The FSM again specifies 4.06 - 5.47 oz of grease. If you try to push the grease filled housing onto the shaft you will likely pop the sheetmetal cap off the end of the outer race. No big deal, it can be tapped back on with a small hammer. 24. Reinstall the large outer snap ring. 25. Reinstall the outer CV boot. Since the M2 shafts don't have provisions to locate the boots, the dimension listed in the FSM is 3.575" from one end of the boot to the other at rest. 26. Install CV boot clamps. 27. When installing the CV shafts into the diff, they need to clip in. If you cannot push by hand hard enough to get them to click into place, carefully tap with a dead blow hammer around the edge of the inner CV housing (careful not to tear the boot). 28. Bolt up the inside end of the CV to your companion flange. The bolt torque specified in the FSM is 51-58 ft/lbs. That's it. This is not a difficult job, but it is a greasy mess. Gloves, a roll of paper towels, and a can of brake cleaner are good to have on hand before you start in. -
CV shafts aren't particularly hard to disassemble, but there are a couple of tricks that it really helps to know ahead of time. This write up will give a step by step and hopefully make the process a little easier for first timers. 1. Remove the outer CV boot. I didn't take pictures of this, but the way I like to do it is to take a pair of dykes and shove one side of the cutter under the CV boot clamp (without cutting the boot). Then squeeze and twist the handle back and forth and the clamp will work harden and snap. 2. Remove the snap ring from the inside end of the CV housing with a screwdriver. This will allow the outer CV housing to slide off, exposing the inner race, ball bearings, and cage. 3. At the end of the shaft you will find an outside snap ring. Remove it with a pair of snap ring pliers. Side note: This picture shows the outer CV cage in the standard position. This is what it looks like when flipped per the Modern Motorsports instructions. You can see that flipping the cage doesn't buy much space because the axle protrudes nearly as far out as the cage does. 4. Once the snap ring is removed, the inner race with the cage and balls should all slide off as an assembly by hand. The balls are captured by the cage, so they can be gently pried out with a small screwdriver or a pick. 5. After the balls are removed from the cage, twist the cage 30 degrees, and it will pull straight off. This picture shows how the race lines up with the cage in such a way that it is prevented from coming apart without that 30 degrees of twist. The cage on the left will not come off, as twisted on the right, no problem. 6. Remove the inner snap ring that locates the CV inner race so that the boots don't tear while trying to pull them over the sharp edge of the snapring. With the snapring removed, you can slide the outer boot off of the shaft. 7. Take the inner CV boot clamps off and slide it off of the shaft as well. 8. It is time to remove the inner CV. I've done this job a number of times, and I've never had too much trouble. I clamp the CV shaft firmly in a vise, and then hit the inner CV housing with a dead blow hammer. I hold the splined end of the CV and usually 4 or 5 good whacks on the housing and the circlip will pop out of the CV and it slides right off. Others have reported that they just cannot get the CV joint off. One alternate method is to take a piece of square tubing that is 2" and 2' long and slide the CV shaft into it, and then throw it at the ground square tube first. I've never used that method, but people say that it works. 9. Once the inner CV is off the shaft, clamp the HOUSING (not the shaft itself) in a vise. In order to get the ball bearings out, you need to twist the race inside the housing. They are usually pretty stiff. You can put the CV shaft in to get the inner race twisted a bit, and I usually find that after I get it move it until the CV shaft hits the housing, I can move it the rest of the way by pushing down on the low side and pulling up on the high side with my fingers until the first ball comes out of the housing. Once it is out, use a small screwdriver or a pick to pop the ball out of the cage. I've found that it's usually easier to remove the balls in a star pattern than it is to roll the inner race around to hit the next ball to the left or right. In this particular picture I was able to move the race enough to remove two of the ball bearings at once. 10. Once all the balls are out, you need to get the cage and inner race out. The cage has two larger windows. By aligning the longer windows vertically with the races, you'll find that the race will slide right out of the housing. Interestingly, the inner balls are slightly different than the outer ones. The inner balls are slightly larger. 11. The inner cage comes out by means of those longer windows as well. 12. Once you have all the parts disassembled, clean everything and inspect for damage and wear. The main thing to look out for is pits in the races and chips on the ball bearings. CV bearings from a 25 year old car probably won't be perfect, and they don't need to be absolutely flawless. If they have significant pitting, replace the joint. Junkyard gold tip: early Pathfinders (90-93 and possibly other years) use the same joints with a much shorter shaft, and since they are front driveshafts in a 4wd application that is rarely used, they're often in nearly unused condition. 13. Time to reassemble! Hopefully you're now installing your CV joints on a set of custom chromoly CV shafts from M2 Differentials so that you can use them in an S30 without the CV shaft bottoming. The first part of the reassembly is the inner CV. Slip the inner race into the cage and again align the long slots in the cage with the housing so that the cage and inner race are installed in the housing with no ball bearings. Then, just the opposite of how you removed the ball bearings, re-install them into each of the windows until all 6 are back in place. 14. Greasing the CVs. Greasing CV's is kind of like greasing wheel bearings. Just as you do not pack the entire spindle with grease out to the dust cap, likewise you do not need to pack the entire boot with grease either. On the inner CV, you cannot grease the CV joint until it's entirely assembled. Once it is assembled, I pack grease into the bearings and into the hole where the shaft plugs in, trying to get grease into all the little spaces. When you insert the shaft, some grease will be pushed out, but this is not a problem. The FSM specifies 4.06 - 5.47 oz of grease. 15. Installing the shaft into the inner CV race. The circlip groove is deeper and wider than the snap ring groove at the outer end, so it should be easy to tell apart. If you took the circlip off to clean the shaft or because you need to transfer it to your bitchin new M2 shafts, now is the time to do it. The circlip is WAY too big to fit tightly to the shaft. When you have the circlip installed, it will hang well off to the side of the shaft.
Are bumpstops required with coilovers?
JMortensen replied to nazgule6's topic in Brakes, Wheels, Suspension and Chassis
You should have bumpstops. -
Thanks for the high praise Matt. Your project definitely has my attention, your end product is going to be very similar to what I'm looking for out of mine, so I'll be keeping a close eye on it.
How much welding are we talking about here? I haven't done any testing, but I'd imagine that a couple tacks with a mig on the center of the cut end of the shaft isn't going to change the temper of the shaft outside of the HAZ in any meaningful way. Those balls aren't actively trying to come off of the end of the shaft, so you don't need a whole lot of weld to hold the thing together.
There are some pretty good arguments to be made for longer, squishier bumpstops, but if your suspension is sprung stiffly enough that you don't hit them often, then it probably doesn't make too much difference. Here's an example of a "really nice" bumpstop: http://fatcatmotorsports.com/FCMstops_comp.htm -
I thank you for all your helpful input. Out of all the forum users that I have had contact with. You are one of the most insightful and well read. I go off of data. Plain and simple. You like to back up your comments with data. I can only hope you keep your input coming and we learn more as we move forward.
Why so much resistance to this exact idea when I brought it up after the test then? (see posts 3-8): http://forums.hybrid...-datsun-s-30-z/ Matt is talking about paneling the whole underside of the car. If the whole underside of the car is paneled, then the lack of paneling as a critique against running a diffuser doesn't make a lot of sense. It's all about context. Diffuser on a stock Z at stock height that bobs up and down all over the place? No. Diffuser on a Z with flat bottom? Why not? Will it make a difference? If the whole underside is flat, it should. How much? Is it worth the effort? You'd have to actually do it and then compare lap times or test in the tunnel to find out for sure. Based on some of the time trialing cars that have been kicking ass and taking names in the past few years and the emails I've traded with Simon McBeath and posted here, I'd say it's probably worth a shot. -
Makes no difference at all until the cage is going to contact something. I suppose if you were likely to shorten the arms you'd want them flipped, and if you were likely to lengthen them you would want them in the standard orientation. Unless you're making the arms a lot longer or shorter it just doesn't matter.
