240Z_Master
Everything posted by 240Z_Master
  1. Either that or a Apex SAFC or something... hell you have to change the plug too
  2. Are you going to run the Stock RB25 intake manifold? Or go with the aftermarket Greddy or Greddy 'style' manifold?
  3. Some photos would help to see what you're missing!
  4. I need help finding these grommets, apparently only available through Nissan as an entire headlight assembly... does anyone know of anyone who makes these aftermarket? Or any cool solutions that would help the set screw? I'm going to be purchasing new adjustment screws (the ones you adjust from the outside up/down/left/right) Nissan part number 26022-19900 Should I just go to the nuts/bolts/fasteners place and see if they have any threaded sleeve type things?
  5. It's interesting to see the British influence on the rest of the world way back when they used to rule those colonies/countries
  6. Again... I knew what I meant... you just said it better, haha
  7. Yeah I was meaning to say Left Hand Drive vehicles... but I just was in a clusterfck for words
  8. Hella ECE Housing, with step on the right side (for left side driven vehicles) Re-using my previous H4 Piaa Bulbs, and NOT HIDs (for now... still deciding) As for a previous picture to compare I didn't take one (doh!) Low Beam High Beam
  9. The only forged pistons that came from factory if I recall correctly was the Nismo 400R (R33). Come to think of it the Z-Tune R34 did as well... and even the N1 blocks didn't have forged pistons... Please correct me if I'm wrong.
  10. Do a good tune up, drive it stock, and work on suspension/brakes/chassis/bushings... There's no point in doing a huge motor swap then realizing you can't stop, or you can't put power to the pavement
  11. It all depends on what your HP goals are... If you're going for more than 450 then yea you could replace all the fancy stuff... but the RB25/26 can handle a ton of power on the stock bottom end
  12. Thanks for the response John, I wasn't sure of what services you offered and will keep your business in mind for any future purchases if I'm in the market for specifically what you specialize in. I may have been misinformed of what you do or do not offer. My apologies.
  13. I tried getting a price and emailed/called him but I just didn't get a response.
  14. On a second note as well... factory RB26's (R32's and R33's) if I'm not mistaken their wastegates were set for 10 psi, and the GT-R's had boost restrictors of 1 bar from the factory as well.
  15. The numbers are bone stock out of the factory etc... As I'm sure you weren't running the factory exhaust, factory cat, and all that stuff were you?
  16. Well chances are if you haven't heard of them.. they're no good.
  17. That's not my setup, that's FricFrac's setup using Visionxusa VX-7RD housings with HIDs. My recommendation before ordering from Rallylights is calling them to check if they have housings in stock... I ordered mine mid-May and they are back ordered. /product_info.html"]Visionxusa Housing
  18. 202 HP SR, 250HP RB, 276HP 2JZ-GTE
  19. I did not get any positive vibes from John @ H4Lights... The Hella Housing units he quoted me $139.98, so I asked what else he had... he mentioned some Bosch units for $60/pair w/bulbs, I mentioned I didn't want bulbs and was just trying to buy housings so I can drop HID's in, then he ranted that HID's scatter light yadda yadda, (as research has shown properly aimed and properly designed housings with cut offs and what not will work perfectly well)... then the guy never responded back to me. If it was up to me... I wouldn't recommend this guy to anyone. $0.02 <Photo from FricFrac>
  20. Hood clearance issues on the Cuimmins fo sho!
  21. No one can "HERE" you... but they might "HEAR" you
  22. Although these engines are badass... I don't think our poor Z's can handle the torque
  23. Unless you already have a RB20... but RB25's are newer motors, and well they're bigger displacement motors =)
  24. How about scratch the whole RB20 idea and go RB25
  25. Is this Australian or something? Check the Skylines down under forums too
