44
Everything posted by A to Z
01-28-2023 UPDATE: I have been working on my water neck that splits off to the heater. Since I am heater deleting my 240Z I decided to look into blocking off the port in a nicer way. So, I went to Lowes and bought a rubber plug that was tapered, and got one that fit right in. Then I coated it with Gorilla glue and pushed it in. After a couple hours, I checked it and it was permanently in there. So I held it up and poured water from the inside which actives the gorilla glue and then filled it up with gorilla glue from the inside. Now, because this stuff expands, I had to keep wiping it smooth. This will all be sanded up inside and cleaned up, but once this is done, it will look much cheaner than a piece of tubing with a bolt in it to block it off. So, more to come on this. Also an update on the block, it is all cleaned up, was magnafluxed and all is well, and is going to be bored shortly. Its been so cold you have to enjoy ANY progress. Heres a couple of pics in mid finished state. Cheers.
01-22-2023 UPDATE. I finally finished up the engine bolt cleaning!. All cleaned up and ready for the block when it gets back from the shop. Crank is done....010 under all the way across, ZERO run out, nice and straight. I also wire wheeled up the driveshaft then cleaned it up. Then before I went in for the day, I got one side painted. Once dry I will flip it over and paint the other side. Look at the pic, this is the 2nd wire wheel I have completely wore out on this car......but hey it's Progress. Hey it's cold! I have heater in the pics, and it's keeping it manageable. But a one car garage is rough.
01-14-2021 UPDATE: More progress......cleaning bolts up with the wire wheel in the drill and a pair of pliers to hold them. Then painting of more parts, and replaced the steering rack mounting bushings......went with urethane this time, and painted the K memberr. Lastly I spent some time cleaning uo the compartment before calling it a day. Pics follow. :)
01-09-2023 UPDATE: Well I got the block, rods and pistons down to the machine shop, and the crank should be done tomorrow. They ended up going .010 under on all the journals and got the runout completely out of it. So after all of that, I went ahead and began the process of cleaning up and prepping all the stuff to be put back on when the block gets back. I painted the engine plate and washer for the harmonic balancer in the Same "Old Ford Blue" I will paint the block with. It's a Duplicolor engine paint. Distributor, misc bolts, etc all cleaned up and buffed out with steel wool, I just need to paint the motor mounts and transmission mount......I still have a few more engine bolts to clean, then it is on to getting the crossmember, etc. painted in the car, that I couldn't really get to before when the engine was in. Pics
01-01-2023 UPDATE. Happy New Year! I was able to use my new carbide burr bit, and get closer to having the block ready to go to the machine shop. Clearancing, clearancing, clearancing. Because I am boring so much, I can't fully clearance the bottoms of the bores until it is back, but I was able to finish the sides. Pics follow.
K1 Forged H beam Rods with ARP 2000 bolts I got from Steve Bonk.
01-01-2023 UPDATE. Happy New Year! I was able to finally get the engine and transmission out and into the bed of it's new home. I also was able to use my new carbide burr bit, and get closer to having the block ready to go to the machine shop. Clearancing, clearancing, clearancing. Because I am boring so much, I can't fully clearance the bottoms of the bores until it is back, but I was able to finish the sides. Pics follow.
12-29-2022 UPDATE. Big day! My custom pistons from Traum arrived. Time to send the block and these in for boring, etc.
12-24-2022 UPDATE: Merry Christmas everyone! Today I began disassembling everything to remove the existing engine and transmission. After that, I removed the head and intake and exhasut manifolds all as one single piece. Hooked up the hoist and pulled it all off! Amazed at how the head already looks like the valves are been un-shrouded. It appears that the head still has it's brass valve seats. Oh well. Even after draining the fluids, it still ends up messy and the remnants find a way to leak all over. The top end is ready to go on the stroker short block, but I will do a bit of extra cleanup. Next I pull the block and finish prepping the block. The pistons will be here in a couple of days and it all goes to the machinist. The rear diff will wait until this is done.
12-22-2022 UPDATE: Well good news today, my pistons are in the mail.....crank almost done. Block is going to the machine shop to get a lot of work done, as well as the rotating assembly. I may have him assemble the rotating assembly since he is a pro and I need it perfect.....I can do the rest....we shall see. He is very skilled, likes to stick the bearings in the con rods and measure to ensure tolerances are as good as possible, so that may be an option I would be crazy to skip at this point So, things are starting to come together. My shift knob and shift boot arrived.
12-20-2022 UPDATE. Well the rear differential arrived, and my new Bosch starter as well. Also received the burr bit I need to finish clearancing the block for the rods and crank, and some new Nissan flywheel bolts. I got them from the Z Connection and were about 10 bucks cheaper than anywhere else....gotta love eBay. Transmission will be done most likely in 2-3 days, crank is in Denver getting the full treatment, probably be done in a week.....and no word on my pisotns yet. I should be getting my used cam in a couple days and then decide if I want to send it to Schnieder for a regrind. That is the best way to go, as the factory cams, are the real deal, strong, forged, versus the aftermarket which are not quite as well made. Schnieder is also able to measure the cam after the regrind such that I can get the exact right size of lash pads.....question is, do I want to get it? When my pistons ship, Rebello is sending me a set of springs to handle a cam.....decisions, decisions. Here are a couple pics.
Hello all, Curious.....I know it is important to find guys who know how to port the datsun heads so that they will make the max pwoer. That if it isn't done correctly, it really can screw things up. So, please give the name of guys you know who know how to do it. Slover's Head Porting in California I have heard is good. HARD to get ahold of. Rebello is not taking any more head work....he is really backed up on heads awaitng work. Who else?
Just looks great!!
Twin cam head for the L6 from Derek at Datsunworks
A to Z replied to Derek's topic in Nissan L6 Forum
Sure would be nice with crank fired ignition, coil on plug and 50 mm ITB's and a nice ceramic coated header. Have Dave Rebello build me a 3.2 variant with an offset ground V07, use an early sleeved block. Only thing nicer would be an aluminum block, and those don't exist. -
12-14-2022 UPDATE: I finished getting the garage ready to work in for the drivetrain swap. So, today also became the messy day.....draining the engine, radiator and automatic trans. I don't think there IS a way to drop the pan on the trans without spilling and making a mess. So, after I got that done and cleaned up, I took some time to start on the clearancing of the block, so the Diesel crank will clear. The trans pan had further signs of the cars low mileage.....original cork gasket and not much for metal filings in it. Click link below to see video at the end of the pics. (18) Facebook
12-13-2022 UPDATE: So, I went ahead and prepped the garage for the engine build, etc. Just waiting on pistons, and then waiting in line for machine work on the block. The cool alternator adjustment bracket I found on eBay arrived as did my shifter I got from Steve Ehlers. Transmission is at Precision Standard Transmissions locally getting a rebuild.....waiting for my K case 4.11 R180 rear diff to arrive as well.
12-9-2022 UPDATE. Trans arrived last night. I took some pics and loaded it in the trunk. It goes to Precision Standard Transmissions here in Colorado Springs for a rebuild....will drop her off today! Also got a shifter for it, and the new bushings so I can sart playing with the way the shifter sits in the car and make any mods necessary after the rebuild and the tranny is in the car. Here are a few pics from last night.
