A to Z
Super Moderators
    32
Everything posted by A to Z
  1. 12-1-2021 UPDATE: I reapaired the door panel edges tonight. After I cleaned them up, I began a careful inspection. The area(s) where they were turning up, the wood had "dissolved" into a dry but mushy mess. I cut thin strips of sheet metal and glued them from the strong and straight areas to the end which is so far holding and made them straight. The pics make it look like a poor reapir job but nevertheless it worked. Next, I will mask off the chrome trim, wipe down with denatured alcohol, and paint. The top edge where forearms rest is so stained, that even after heavy scrubbing and cleaning, has a darker sheen. I should have just fiberglassed the corners, but I am impatient.
  2. It owuld be really nice if you can pull the engine one more time and take the time to paint and detail the engine compartment and the engine and then re-install.
  3. SEM Napa red is a perfect match for 1972 red interior. Landau black for the console huh? Ok then!
  4. I went ahead and Armor All-ed the interior a bit yesterday. Sure woke things up. I went ahead and ordered the carpeted cover for the dash, and will copy how my dad did it years ago with 2-3 hooks made out of bailing wite to hold in place on the defrost vetns. Also will need to do some more painting of the red surfaces, as both sides of the tranny tunnel really need it. Also will need to get a can of SEM in black this time as the console in the ashtray area is REALLY bleached out. Door panels, some work on the door weatherstripping so the door will close flush, and I think I MAY be able to move forward on the body work and under the engine compartment. The engine compartment still has several items that need to be attended to.
  5. I should also mention, I was able to go back and give each bolt area on the dash trim piece a little shot of paint to hide some installation scrathces. Turned out great! That's it for today.
  6. Instead of black, I decided to buy some GOOD paint in a finish that should mimick the original grey. This stuff works great as long as it is in short bursts swigning the can.
  7. I painted these earlier in the year, and the paint was horrible, leaving a lot of runs in them, etc. So, I sanded them smooth with 150 grit sandpaper and masked them back off.
  8. looks good, doesn't work though. I put a new LED light in it....oh well, another small down the road "fun" job I suppose.
  9. Having installed the dome light yeaterday, I was able to tape it off and spray the area around it with my SEM interior paint to remove a couple fine scratches etc.
  10. 11-27-2021 UPDATE: Ok, so with renewed vigor and the troubes of yeaterday behind me, I was able to get the side mirror bolted on, reattach my painted rear view mirror, Touch up around the dome light after yesterdays installation, straighten things up a tad, and re-spray my tailight frames. To get the side mirror on, I ended uo threading a bolt into it with a nut on it as well, dremel'led the bolt head off, and then backed the nut off to clean the threads. Thus, making it a stud sticking out of the mirror. At that point, I was able to take my cobbled together wrench and finally get a nut started on it and then I was able to cinch it down. SUCCESS!
  11. 1-26-2021 UPDATE: Some days....you just can't get much done. Today was a rough day. Screws refusing to go in....wrestle, wrestle, etc. well the trim is in, I got the side mirror STARTED....talk about a fight.
  12. Little 240Z has it's share of slight door dings etc like this. there are 2 schools I figure....one is the leave them, clear over and let them add "charm" to the car....the other is to use a bit of glaze and block them out, spray to blend it in and then clear. I am of the school, of remove as much of them as possible. Opinions? This is it for today, Gentlepeople, Cheers and Happy Thanksgiving! God bless each and every one of you. Peace.
  13. Passenger mirror layout. I found out the the factory mirror rotates 180 degrees, so you can use one on the passenger side as well! Since I like the "dainty chrome" look of it, I bought one used, so it matches the original patina on the driver's side and went ahead today and marked it and drilled the mounting holes. The idea is to do everything for the doors NOW, so once closed up, that's it....in theory.
  14. once dry enough I set the dash trim piece in place without bolting it down to just be "there" and out of the way! Yes the piece seem to have a slight bend in it, but it's not noticeable. I didn't do it!
  15. saving this texture was all worth it, I think. mounting bolts got a blast of paint too, why not?
