I'm not a suspension guru, but our cars are very similar, so i'd like to learn along with you. With the V8, I have to be very careful with throttle application even in a straight line or I lose traction in back. All the more exiting turns. Mine was very touchy toward oversteer even before the konis when i had lots of droop with Illuminas. Do you currently have problems with oversteer even if the throttle is held constant thru the turn, or just when you start to add throttle as you exit (like the title says)? I so want a couple of dedicated hours on a skid pad , but I've never gotten to play on one. It doesn't address our limited droop, (and I'm sure you've done this), but I did notice improvement by dropping the tokicos to full soft and dropping rear tire pressure significantly. A big inprovement in controllability was made by reprograming my DBW such that more pedal input is required for each degree of throttle body opening. This year (if I can ever get to the track) I have obtained some wider rear wheels and tires to run a little stagger. I also may drop the tail some, which builds in more droop. Hey, that's an idea: drop the rear static ride height a couple inches and see if it helps. 1.4g is awesome-I doubt seriously if I am anywhere near that.
