75280z
Everything posted by 75280z
Long time, No SEZ - (Old Timers SEZ Shootout Roll Call) - just for kicks
75280z replied to Warren's topic in Non Tech Board
I am still around, I don't check regularly. I still have my Z. I joined here when I was 15, I am about to turn 38. -
Everyone. I had two giant vacuum leaks, I needed a new PCV system, fixed a fuel leak, and replaced the spark plugs. The car runs SO much better! .
Finished the video, not a ton of earth shattering content here, just as I tinker with small things on the car I am recording it. .
Oil change, greasing throttle linkage, and making a giant mess today! Sorry got a little ahead of myself on the video...
The video is pretty long sorry. I replaced the door handle, replace the inner fuzzy sill piece, adjust the angle of the upper window frame, add sound deadener, make a new moisture barrier from a shower curtain, and replace the clips on the door panel. .
10 years after hybernation - '75 280z
75280z replied to tamo3's topic in S30 Series - 240z, 260z, 280z
Hey I have been doing similar work on my Z, where did you get the rubber that you installed on the outer portion of the window? I would like to do this on mine as well.- 230 replies
- 280z
- hybernation
(and 1 more)
Tagged with:
Alright a quick update. I had my door handle break last month. Just fatigue over the last ~43 years. - Door handles ordered from FutoFab - Inner Fuzzy pieces ordered from MSA - Outer Squeegees ordered (they are NLA currently from MSA so I had those cancelled from MSA) What I have done recently - Replaced the door handle - Adjusted the drivers door to close tighter and then adjusted the window frame where it sits against the weatherstripping (Can't believe I never noticed that before) What I am planning on doing soon: - Add a tiny bit of sound deadening inside the door - Replace the inner fuzzy trim on the window - Add in a new moisture seal - Reattach the door panel
This car is still around and awesome. I drive her daily currently. This summer I have installed a new rubber shift boot, and replaced a brake light. I also got new wheels and tires for her last month as the tires that were on it were getting pretty bald.
I haven't used it for towing yet. I picked up a Buick Roadmaster Wagon. They had versions with a 5k towing capacity and are great for daily driving (though fuel mileage isn't great)
Great car with a ton of unique touches. I am over in Aurora. There are quite a few Z guys/gals around. What did you end up doing with the old truck steering wheel?
Twin cam head for the L6 from Derek at Datsunworks
75280z replied to Derek's topic in Nissan L6 Forum
Derek, congratulations on firing it up. From concept to reality you made it happen. Thanks for doing this and i look forward to seeing more videos and a dyno run in the future. -
Another year has gone by and all that I have done is change the front brake discs and pads. I took it out to High Plains Raceway and shaved about 2 seconds off my fastest time out there so far from 2:29 to 2:27. I got that while hitting a lower top speed by a few MPH. I really have gotten more comfortable with the car and it is definitely nice to learn the limits of the car. I pushed myself much harder than I ever have in the past, and I took some video, but really it is pretty boring to watch. I am sure I will do a bit of editing, but the app I was using no longer allows me to export the data for free it only lets me do 2 minutes which is no good.
The reason I haven't been working on the Z is because life and work have been getting in the way. Oh and I have been gathering karts for me and the kids, as well as doing a lot more projects around the house. Also I have been doing a bit more of this. I have a video of the first day I took the kart out. I have since taken it out for quite a bit of fun, clocked it at over 40MPH. This karting thing can be very fun.
Here is part two. I have been trying to add more comments on the video but don't always do the best job. The light output is crazy awesome on these lights! Headlight install Day 2
You know since you started this thread in September you have averaged 126 views a day? To be fair I might have been like 20 of those on a couple of the days. I usually just check the page smile, get super impressed, then leave but today I wanted to post again just to give you encouragement and kudos this is a fantastic project and even just reading it I am learning a ton. I have been thinking about a repaint for mine in the future (I painted mine in 2003ish memory is a bit fuzzy). Good luck and I continue to look forward to your updates. -
Started installing my Dapper Lighting V2 Projector HIDs today. I am excited to get them the rest of the way in, but I am going to do a bit more studying on how I want to run my wiring.
Last one from this day. The GPS went way off on this run. I had just put in more fuel and kept smelling gasoline so I brought it in. I found out it just leaked a little on the car around the funnel causing the smell. http://youtu.be/SnUYoq3NFfM
Looking good keep it going! How are the HIDs? I got my set and will be doing that this winter!
Another session finished rendering. I got my personal best speed of the day 112.4MPH! Great day for racing. I have one more session after this one.
Another session. This was the 3rd session for D group. I am getting better at race render, but I am not skilled enough at Youtube editing to get rid of the half second water mark at the end of each 3 minute clip. I changed the track to show my fast and slowest spots. The car ran great, and I got black flagged because I passed when I shouldn't. It was still a fun run! http://youtu.be/YEKzziW-W98
So I got one of the sessions complete using racerender. Here is one session nothing that cool happened sorry.
So I got a lap uploaded I will be working over the coming weeks to get the rest of them done.
