Hi Phil...
Hmmm - as I recall, I had to play with the cam timing to get that cam to run well. If you are having to lean the map out, then that says you aren't breathing as well as before, as you've probably figured out. Sounds like you have already started, but play with the cam timing and take note on how the mixture is affected for different settings. Seems like advancing the cam timing would be what you need, but the #3 hole does add 8 degrees of advance (assuming the stock 3 hole cam gear), and that's quite a bit.
Sorry I'm not that familiar with the Holset turbos - how big is it's hot side?
Also, the idle vacuum you mentioned is pretty much what I would have expected with that cam.
