Gollum
    19
Everything posted by Gollum
  1. 45mpg back then is pretty darn impressive considering most prius owners I talk to only get around 40-45.... I bet a full restored S30 with zero rust and a well done diesel swap could get better mpg than a prius, be a ton more fun, and cheaper too! Sounds like my kinda swap if you ask me. I'd love to see some more people doing modern diesel swaps.
  2. S130's won't be affected by that bill. Cars more than 25 years of age won't qualify, and anything with less than 18 combined EPA MPG won't qualify either. So that's two ways even the 280ZX Turbo won't qualify (it's combined EPA was around 19-21MPG iirc) Plus by law the wreckers will be required by law to destroy the drivetrain. Pretty much no matter what this bill won't help us junkyard dogs.
  3. For what many junkyards want for a turbo, I'd just get a used T3 off ebay. I almost picked up a T3/T4 off a merkur but then realized it'd take me enough time for the $80 price tag to not be worth it, and that they'd probably try to find a way to charge me for the downpipe, wastegate, etc.
  4. Thanks for all the input guys. I'm pretty sure I'll be doing this swap down the road now. Surprisingly though it looks like I have a line on a V8 for my other car, so it'll get it's swap done first, then the 280ZX after that if I haven't bought a different daily yet. If I don't go KA the only other engine I've really considered is the VG30E. Basically I'm wanting to stay nissan so I can keep the stock driveshaft and have it shorted if need be. Just makes the swap go a bit smoother I think.
  5. That's a good bit of into to know, and I bet that's one of the main reason it had a hard time passing smog. In my experience the farther into the test you get in each gear the better the output gets as the cylinder temp rises a bit and the O2 settles.
  6. I've tried low torque (20 lbs) and high torque (40 lbs) and I've always gone in the service manual suggestion, from center outwards. I've tried two different intake manifolds, so I don't think that's the problem, plus it's leaking on the cylinders that don't share. And the leak shows immediately, so the engine isn't even warm before I get a chance to recheck torque. I should have an update to see if my jerry rig works sometime tomorrow or thursday. If it's no good I'm going to have it checked my a machine shop and drop the money for a nissan gasket.
  7. I've been using the run of the mill fail-pro gaskets. I haven't checked my manifold for straigtness because it seems so perfect, and I've talked to the guy who did the swap, who has no reason to lie, who says that he never had a leak with it, and this was less than 4 years ago, possibly less than 3. I'm going to try to cut just the center section out of an old gasket and see if that'll hold. If not I guess I'm going to start checking how straight all my surgfaces really are and if they're good then I'll be buying a nissan OEM replacement.
  8. How far forward will that put the engine though? The transmission is about the same length as the Z transmission yea? They're nearly identical I thought, or at least extremely similar. I was hoping to put the engine as far back as I could get it, but I guess that WILL depend on driveshaft costs. I was also thinking that mounting it as far back as I can get it I'll avoid any crossmember clearance issues I could run into. Thanks for your input, I highly respect it since you're in the middle of the swap.
  9. So I've been kicking around the idea of dropping a craigslist special KA engine into my daily driver 280ZX eventually, and pretty much just driving it 99% stock. Why? Because my current engine has almost 220k on the OD now, and should really get a rebuild before 275,000 which I could hit in a couple years easily with how much I drive. I can get probably slightly better MPG than I would with the L engine, and the KA is a thousand times easier to work on, with more available parts, and lots of go fast parts being sold for next to nothing. But here's my question for you people in this 4 cylinder corner of the swap world. How cheap do you think it can be done? I'm a master penny pincher here. I'll probably fab the mount cross members myself. You can practically get the engine for free around here due to all the SR swaps. I'm hoping I might even find a KA24DE for under $500 with tranny. I think it should be a totally doable swap for less than $600 for a SOHC, and $800 for a DOHC. Anyone disagree? Why so? What exact problems do you see coming up? The big challenge will be finding a shop willing to fab a driveshaft for a price I like. Last time I needed a driveshaft most shops wanted $300 minimum so I just walked away. I might have to drive out to the sticks to find a cheap shop.
  10. So I've had my 75' with a L28ET for well over a year now, and it's had a nasty exhaust leak since the day I bought it. About 6 months ago I replaced the gasket and swapped to a different intake (turbo)... to no avail When recalling the whole thing I realized that the manifold was a PITA to get on because getting the downpipe to fit on nicely while mating to the head was more than a challenge. So I figured my exhaust pipe must be pulling on the turbo enough to not be allowing a good seal... Still leaks. I didn't let the gasket burn in yet, and I tried stacking gaskets. Still same as always. I've confirmed that the leak is at the bottom of the center 3 and 4 cylinders. Am I just having issues getting my gasket lined up right with the manifold? I was thinking before that maybe just letting everything hang on the studs and then bolting it up was letting it hang too low, so last time I taped up the gasket to the valve cover with a bit of tension and put a jack under the turbo to help get the manifold higher up on the ports... And like I said, still not sealing. The leak is DEFINITELY coming from the bottom between 3 and 4. ANY AND ANY Help would be GREATLY appreciated. Hopefully some of you guys with lots of turbo L series engines can help me figure this one out.
  11. As far as I know I thought all the EFI L series had O2 sensors... But at any rate, in CA it's illegal to put in an engine from an older car into a newer car. It's also illegal to put an engine in your car that meets certain lower emission standards (like putting a carb'ed engine into a car that was originally EFI, or not having a PCV valve in a car that originally did). It's also illegal to swap in an engine that's from a heavier class, so you can't put a work truck or a 15 passanger van engine into a passanger car. But I seriously doubt that any smog tech could tell a difference between any EFI L series variant. I bet you could even get a L28ET to get tested as a L28E if you worked hard enough. There's no reason to look under that intake for a turbo for a smog tech...
  12. Oh yea, here's some more pictures. Here's the pics of the wiring harness I took apart to supply this project. Warning!!! When you park a project overtop a storm grate you're bound to go swimming for some bolts!!! This is the car owner, my friend, Cody. I need to get another shot like this once the engines 100% back together.
  13. I feel like a kid who's just walked into dad's cigar room filled with guests, old men smoking and talking about things foreign to me. In short, I feel out of place around these parts of the boards. So user Drummingpariah sold his red 240Z to a friend of mine. The motor was toast, but Drummingpariah had already bought a retired 350 out of an ambulance, go figure, so that came with the car. I knew that if I didn't help my buddy out with this project it'd never run, and I told him ahead of time I'd help him out. He bought it just before the first rain this last winter, so probably around October. I knew if I didn't get the new engine in soon it'd sit out in a truck all wet winter, not good. So I helped get the engine in within a few weeks of him getting it. Then it sat. Then it sat some more. Then the sun started to come out again. Then the car became evil: (I find that much more evil than the "splotchy red" it was before) I think it went evil because it got angry about drummingpariah stealing the rims for his new Z... So we started at it again. Only took about 3 days of working on it here and there, and many runs to part stores to oogle shiny things and then walking out with little things here and there. I'm not sure how much my friend has spent on parts, but I don't think it's too bad, probably about $250-300 or so (a lot of that was for the battery and tail lights). So I showed up today and reset the distributor (was off 360 crank degrees, or 180 rotor degrees), and the thing fired right up! Yahoo! I'll be working on it some more tonight, hopefully get it idling a bit smoother (I think I know what it is) and then we're going to start working on wiring up the car from scratch. It won't have AC/Heat, or much else. It's just going to be an engine with some gauges and switches (with relays on all of it). So here's what you all want, a video:
  14. If you look closely you'll notice the bumper is stock, and the lower valance piece is stock too, there's just been a splitter looking piece added on. Who makes it I don't know, but I highly suspect it's a custom one off piece, considering the nature of the rest of the body work. Why spend all that time doing something that's so uncommon or unheard of just to slap on someone's splitter?
  15. I'm not running any kind of BOV either, and I don't seem to have any surge issues from what I can tell. I wonder if my massive exhaust leak might be part of the reason.. I'm also running stock EFI and boost to 6psi with a little bit of creep in 4th sometimes up to 8psi. I've also talked to guys that said that at 10psi on these engines a BOV is more important than an intercooler.
  16. Been a while, but I must say I'm most likely not going to do this intake idea. I found some intake "dynos" if you will, comparing various intake lengths. Shorter intakes did yield better flow at higher rpm, while long lengths did have a low RPM boost, but what was surprising was overall performance. If you're tuning for 1st order harmonics then you're going to get a huge sharp boost for where you're tuning it to, but that's exactly what it is, sharp. The rest of the range suffers from the length, even the RPMS bellow the boost. The reality is that for good all around street performance it looks like you need to tune for 3rd or 4th harmonics. I hope to still make an intake, if not only for the engineering aspect. If/when I do I'll make sure to document it well.
  17. I'd never sell a car to anyone like that, even if it was a geo metro.
  18. your car has made disgustingly good progress as time has passed, so I just want to encourage you as one who's been following along now for a long time. KEEP IT UP.
  19. As one who's owed both, I can really appreciate the auto to manual Air system conversion. Overall that's one extremely well kept Z, props out to ya. Pretty much all the Z cars I've owned have all been well used and abused so I just end up stripping them all down to what's still worth having, but yours seems to be quite the opposite.
  20. Wow, this thread is almost as old as I am on this board. Takes some serious searching into the deep to find one that old! Can someone award him some brownie points?
  21. So today I worked on stripping an old wiring harness of one of my cars that I had lying around. I'm going to use it as a resource bin to wire up a friend's Z car (SBC 350). It's going to be rather simple, so paired with some relays + sockets we should be good to go. Hopefully I'll even have a start up video to share. And this is what a harness from a 81' 280ZX looks like disassembled. (and I mean HARNESS, not just engine harness. I don't think this is all of it as I don't have the wires that plug into the other end of the junction box and go to the dash, as I couldn't seem to figure out where it ran off to. So let's say it's 70% of all the wiring in a 280ZX. And that's about all I got done today, among enjoying a friday doing almost nothing after a short stint of decent pay work.
  22. Well I got the brake lights fixed, morning of the meet I was so anxious about. Woohoo! Headlights are still down... I'm quite angered by the complexity of the stock system and in the frustration of it all I just started hacking away. I started pulling out all the unused wires I've now completely confirmed I don't need. Hack Hack Hack. Some of the remains: I'm still far from done removing all the needless crap, but it's a start. I've decide that instead of getting the stock headlight wiring to work I'm just going to wire up a system with a relay from scratch. Should be better off this way anyways. I also got a little bored and decided to "fix" the crappy sound problem in my ZX... Now it just looks crappy. But that's a lot better than sounds crappy. Didn't cost me a cent!
  23. You're either very sarcastic, or a very big idiot. But that's ok, because I hate V6 engines because they don't make power, you have to have a V8 to make any REAL power.... All joking aside there's plenty of power available from this powertrain and if you'd actually read the thread you'd see that the reasoning for choosing this combo makes perfect sense.
  24. Car looks terrible, maybe you should just give up. In all seriousness I think your car is just a testament to the builder, and all I see is top notch quality. It's just a reflection of your skills, and it looks GOOD.
  25. Sounds amazing, and the swap looks very well done. I bet it pulls like a beast all the way up too!
