Buzz
Everything posted by Buzz
N0, just laying on the floor,car on jack stands.It's just not going in striaght,I put in a new piolit bushing no play.I never had a trany go in so hard.Stupid question,I can't remember does the clutch disk go in with the springs facing the pressure plate,I think so? Mike P.s. Nice video!
Boy do I feel stupid,I just spent 2.5 hrs tring to install a 4 speed into my 77 L6, what the heck.I installed the clutch,with a alignment tool,tried turning the output shaft,wiggling the engine, pushing the trany from side to side. O and I even have another imput shaft that slides right in with no problem.raised the engine, lowered the engine ,lowered the trany,raised the trany.funny thing is it's the trany that came out.It wouldn't be so bad if it were another trany.I'm just fustated,I'll get it.It's not the first trany I've installed,just been awhile! Mike
Hi: Any one remember what engine mout goes on which side L28. long or short on drivers side.I can't remember! I'm getting ready to install the engine.I didn't realize they were different when I took them out..Thank's Mike
Check the brushes inside,also try tapping on the alt. while it's running.If it starts to charge while tapping on it ,it 's probbably the brushes. Maybe a cheep fix!
One bolt will hold it! LoL
I had a MOMO five star wheel repaired by a company in Cal. http://www.wheeltechniques.com/ They did a great job. The wheel was center bent. I had sent it to another wheel repair shop,when it came back they said they couldn't fix it and it looked like an egg and some one was beating on it with a hammer! I sent it to http://www.wheeltechniques.com/ it looked like new when it came back! They do package deal for refinishing to. Mike
Sorry I tried to edit and ended up posting the same thing twice.
Hi: You probably could get by using a 20amp breaker if your not running the welder at it's max,But if you have low voltage it might trip the breaker.Lower voltage makes the amperage go higher so you better use a 30 amp breaker. Black and red number ten wire for the hots on a 2 poll breaker Use green for the ground. Mike
Hi: You probably could get by using a 20amp breaker if your not running the welder at it's max,But if you have low voltage it might trip the breaker.Lower voltage makes the amperage go higher so you better use a25 or 30 amp breaker. Black and red number ten wire for the hots on a 2 poll breaker Use green for the ground. Mike
280Zone did you get my e-mail
Yes I did ,I e-mailed you back!
OK Thanks ! Mike
Hi: The welder should say on it some where what the amperage and the voltage It needs thats what tell you what size wire and the size of the plug,20,30, 50amp. and breaker you need. Look for a tag on the welder. Mike
Hi: No not 100% but the rack dosen't sit square to the crossmember.I'm in orange county NY. Mike
HI: It dosen't appear that any one looks at the old posts,I was hoping that somone would have a spare crossmember that they would like to sell.Sorry to post a new thread.
Hi: Anyone have a spare crossmember that they want to sell.Somthing wrong here, the rack dosen't sit right.Seems like the crossmember is twisted out of wack. Any Ideas!!! what do you guy's think. Rack boot hits croosmember.somthing wacky!! Thank's mike
Hi: As you Know cygnusx1 is helping me put my car back together after redoing the engine compartment.The steering rack sits crooked on the crossmember.We don't see where it is bent or anything out of alignment.The car was hit in the front at one time before I bought it and repaired. All the damage looked to be in front of the crossmember.I hate to put it together out of wack,It will only wear and rip the rack boot again.Does anyone have a non-bent spare crossmember laying around that they might want to sell? I would like to see if it's the crossmember,Mine dosen't look bent,but maybe!.Cygnusx1 checked his and has about 1" between the boot and the crossmember and his sits straight. MY z is a 77 his is a 76. Thanks Mike
Yeah all day. but I primed 2 days ago.I have been waiting for a friend that does body work to come over and spray it,but I couldnt wait any longer.I think a year is long enough.
Compared to the engine bay flat panels should be easy,It's tuff crawling around in there trying not to tuch any thing that you just painted behind you.
Thank's guys makes me want to get this done.yeah thats the same engine bay, started about 10am done about4:30pm.PPG DBU paint and clear and gfg 670 gun worked real well Like I knew what I was doing! Not to bad for a beginer.
Thank's I was nervous about doing it but it had to be done. I think I have more clear in my hair than on the car!
Hi: This is the first time I painted anything,after waiting about a year for a friend to come over and paint it .I said what the hell I can't wait any longer summer will be over.I have to get the engine back in!!!I missed out on driving it last summer. It's a 77 z L28 moded tripple webers. So now the engine bay is painted , It wasn't that hard, I bought a good Gun And read a lot of foums.It came out good no runs. Here are some shots. Thanks to Hybid z paint fourm. What do you think? It's actualy blue metalic pic's look greenish blue just lighting. paint code #305 Thanks MIKE
Hi: This is the first time I painted any thing,after waiting about a year for a friend to come over and paint it .I said what the hell I can't wait any longer summer will be over.I have to get the engine back in!!!I missed out on driving it last summer. It's a 77 z L28 moded tripple webers. So now the engine bay is painted , It wasn't that hard, I bought a good Gun And read a lot of foums.It came out good no runs. Here are some shots. Thanks to Hybid z paint fourm. Thanks MIKE
WHY WOULD FUEL PUMP RELAY WIRES HEAT UP? AND SHUT OFF PUMP?
Buzz replied to THUNDERZ's topic in Fuel Delivery
HI: I'm having a similar problem with holly pumps,loss of pressure,and now the pump just stops.It over heats and shuts down on over tempature.same thing from fuel tank,to filter,to fuel pump,to fuel block,to triple webers.I've replaced the pump,lines,filter,put in heaver wires#12 way big enough!I removed the tank,boiled it acid washed it,resealed it!I did find loss of pressure on gauge may be dude to heat under hood.I installed a liquid filled gauge and it seems once it heats up it shows a loss in pressure even't though there isn't one.so I installed a non liquid filled gauge and it stayed constant.HUMMM! the pump seems to slow down after it warms up causing loss of pressure,and now just stops on over temp after about 4 miles.WTF!I emailed Holly's tec's But no responce.I may have to change the position of the pump to verticial.You shouldn't need a return line with low press.I tried that too.I just ordered a new WALBRO pump from JC whitney $50. turns on and off when float in carbs opens, It must have built in switch.I'm giving up on HOLLY CRAP!!!!
