Bahraini240z
Everything posted by Bahraini240z
  1. After installing 40phh Mikuni triple carbs Fuel pressure starts to drop from 7psi to 1.5psi after the car warms up. I'm running an MSD ignition along with a mild cam on a flat top L28. running an electric stock in-tank pump and another stock L28 mechanical pump. What could be causing it and how to solve it? What are ppl running similar setups have? Thanks
  2. Thanks bro... It's a custom build by a local workshop, 2.5" from the Monza headers all the way to the muffler u see
  3. Thanks... Running 225/45/16 and 195/50/16 on staggered setup 16x8 and 16x7 Lowering it in 2 days, hope it doesn't rub with zero offset in the back
  4. If you want 513s, u will find it on the link bellow my sig pic
  5. Gongrats man, that is amazing. We will certainly be following ur news. Wishing u and ur team all the best
  6. Would love to see some pics and learn more info on the setup
  7. Sorry for ur loss man. Hope u recover from this financial situation and start a better build I'm just curious how ur ride turned out. Pix maybe
  8. Thanks guys, that makes sense. Sorry for my ignorance, never been into the carbs business before. My othe Z is running on an Fcon V-pro, huge technology difference
  9. Since we are tuning triples, how can we adjust them using a single wideband gauge? My point is, one of the triples could be running richer and causing the overall reading to be rich.
  10. Thanks for the post... In fact I never knew that Gude produced cams for datsuns, I know they do for hondas, until I found this on eBay! Not sure what was the story of this cam really and why was it built (race engine, street, etc)! I guess I learned my lesson here, the hard way
  11. This was copied from his ebay page... Was mentioned twice! Will I be needing any other mods to fit a shneider 274 cam? Is it a direct fit?
  12. My god! I thought that was a mild cam, looking at the 272 number! Thanks for the reply... Cam up for sale Since I don't wanna do the same mistake, what is a good deal on a decent cam to run with 40phh mikuni triples, flat top pistons and headers? Shneider perhaps?
  13. I bought a cam from eBay that was re-grind from Gude Performance E31 cam. The lift is .579, the duration is 272 degrees, cam lobe angle is 108 degrees. Cam did not fit on E88 head with stock rocker arms, valves and retainers. Do I need to change those to have it fit? The spring gets pushed to maximum
  14. I guess the last 2 spark plugs can be changed from inside the car I remember that we started a similar combo project to a 4-door 510 and we had to cut a lot.. I will try to find some pix just to understand how much the engine goes in, but it was a drag project anyways Yet, this is one of the nicest swaps I've seen
  15. Wow! That thing is amazing! Neat swap. Wondering how much they had to cut into the firewall to fit that long 2jz
