s30red240z
Everything posted by s30red240z
  1. I've tried many nissan TPS, into megasquirt, and some had troubles, try another nissan TPS
  2. I agree, i am megasquirt user, and is the cheapest way to do your own realtime stand alone, but some people like the stock nissan EFI systems, is up to them the choose.
  3. You can swap the entire z31 harness and L28ET distributor, sensors. i mean z31 efi upgrade.
  4. Could be a z31 ecu upgrade and nistune! that works fine.
  5. The oil filter relief valve is different i've tried this, the hole in the vg33 is bigger and deeper.
  6. I gonna built a VG33 with VG30 crankshaft and accessories. I need oil filter stud, oil filter relief valve, where i can get this? thanks.
  7. http://www.gotech.co.za/usermanualsminix.html
  8. Hi, i am looking for L20 turbo forged pistons for my new project L24ET, i wanna keep the L24 engine block and i will overbore to 85mm.
  9. I have a 16x16 megatune N/A 160cc injectors, if you want it. L24E
  10. Hello, I am looking for a clutch upgrade, and i am confused about a few questions. My flywheel is 240z. The 240sx clutch kit will fit? 225mm I have a bronze clutch kit from a VG30E, this kit will fit, if i would get a L28ET, 2+2 flywheel? 240mm What about the collar bearing?
  11. try with out resistors this settings on V3.0 * PWM Time Threshold to 1.0 msec, and * PWM Current Limit to 30%
  12. EFI upgrade! wire again with new connectors and sensors, and distributor less ignition.
  13. i agree!, i am looking for an intercooler and piping kit for my 240z too, but i got a cuestion, the holes on the front have 28--29 inches between, i saw in ebay intercoolers with 28 inches total, is enough? for the perfect fit!
  14. if the injectors have voltaje supply when you start the car.
  15. Hello, i am looking for a good and cheap intercooler, and piping kit. to start the next level, thanks!
  16. on my vg30 datsun 1200, spools around 4k too but when spools spools i lost traction on 3 and 4 gear, and i have to depress the gas pedal. Yes it has antisurge!
  17. I dropped my datsun 1200 project, and i have a 6262 for my 240z l24 engine, this turbo will fit on the L24 engine?, and another inconvenient is the external wastegate, i have to put on my stock turbo manifold. i am thinking about oside tiger injectors, because i bought venom injectors and are miss matched, does not work. Some body knows another injectors options? all suggestions are welcome thanks! Uploaded with ImageShack.us
  18. I would love too, but i don't have any paper, LOL, only like a wet back :S
  19. How can i swap the 24 tooth wheel into LS1 crank, or i have to install another wheel on the pulley?
  20. I would like to know this, i've been thinking about a L28ET for my 240z
  21. i mean, the advantages of 3.1 really are good versus the spend of money, on a turbo engine.
  22. Hello, i would like to know the differences and benefits between L28 and L3.1 turbo setup. Is good choice spend money on L3.1 strocker, or is better keep L28 engine with mods? I've been thinking upgrade my 240z to turbo 2.8 or 3.1 engine.
