I did a test out of the FSM. Theres T shaped plug with two terminals (one + & -, i'm assuming?) that connects to the Ignition module.
The FSM has a testtable and one of the tests is called the "Power Supply Circuit" test. It involves connecting the positive terminal of the multimeter to the | terminal of the plug, and connect ground terminal of the multimeter to the ignition coil bracket. Then tun the ket to the "ON" position.
Two results and two actions of FSM:
Result-------------- Action
1. 11.5 - 12.5 volts Procees to step 6.
2. Below 11.5 volts Check wiring from ignition switch to I.C. unit.
My result was 0.06 volts What should I do? Also I had a issue when I was trying to start it. For about 5 attempts the fuel pump would just keep running instead of priming it for 5 seconds or whatever th duration of time is it does it for, it wouldnt stop unless I turned the key to off.
