BrandenZ
Everything posted by BrandenZ
Wiring harness dilemma...
BrandenZ replied to 2eighTZ4me's topic in Gen III & IV Chevy V8Z Tech Board
Is your intent to try to run the LS6 using MegaSquirt? I certainly can't advise you if that's the case. I can say that folks have had quite a bit of success on LSx motors simply using hptuners (or something similar) to re-flash the PCM, be it just to tune for say I/H/E, or even for spray or boost. I likely won't get underway with my swap until after the current racing season closes out, but based on the research I've done, I think I'm going to save myself the headache of having to print a giant wiring diagram and follow each and every pinout and either get a re-worked harness from Speartech, or reach out to PSI and get a standalone from them. PCM pinout diagram for download: http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-general/170791-ls6-cts-v-pcm-wiring-diagram.html Speartech link: http://www.speartech.com/LSX_Wiring_Harness_Rework_s/1833.htm PSI link: http://www.psiconversion.com/ Hope it helps! -
Thanks all! I've "borrowed" so many wonderful ideas from these forums, happy to contribute back in some fashion! Another member, Zzeal, hooked me up with an exceptional deal on this: http://www.summitracing.com/parts/abt-sp112 I'll be honest, it's a _really_ tight fight. Here's an album from the cell swap itself: The pics aren't perfect; it's a bit hard to get good ones. However, just beware that the dimensions are about as close as it gets across the board. If I had to do it all over again, I'd probably opt for a 10 gallon to have more wiggle room. The width is just perfect to locate it and still fit dual exhaust. The depth is just perfect to be able to locate it between the diff and bumper, and the height is just perfect to leave enough room for AN fittings and braided steel (clearing the spare tire well cover) and sit ever so slightly above the diff and exhaust, at an angle. It sits 5" off the ground on a fairly aggressive drop (5 3/4" off the rocker) with sectioned struts, and my region allows 4" at the lowest. Coming off the trailer, I think 4.5" would be the lowest that would clear. I got kind of lucky, measuring everything post-purchase.
Just cross-posting this here to try to help out anyone who may miss it over in Fuel delivery: http://forums.hybridz.org/topic/122633-diy-spare-tire-well-fuel-cell-cover/
Once I decided to go the fuel cell route in my 240z, one of my biggest concerns was what to do about all of the huge holes that would be left behind in the hatch area, not only simply for comfort (noise and air quality), but also to pass tech for autox/track events. I enlisted the assistance of a fantastic fabricator buddy of mine (thanks Max!), and this is the (mostly) end result: For those just interested in pictures, the full album is here: What we decided to do was cut a hole parallel to the hatch floor. What this did was leave behind a nice perfect (70's-ish) circle, and wider recessed circular area where the cardboard cover sits. Then the idea was to fashion a cover to essentially sit where the original cardboard sat, but fastened through the sheet metal in the hatch. Of course, the next issue was figuring out how to create an access area for servicing the cell (feed, return, etc.), and more importantly refueling! After searching high and low for over-sized fuel doors for trucks and other assorted applications, one day I was just staring into the hatch space trying to brain storm and I noticed the factory tool doors. Perfect! Not only is the opening big enough to fit your entire hand in, but they're wide enough to cover virtually all of the serviceable components of the cell! I was able to find a used Z tool door quite easily off of eBay. We then sourced a large enough piece of 18 gauge stock sheet metal to cut out a 27.5" diameter hole, and sent the stock and tool door off to a local waterjetting shop. They were able to cut it to 27.5" diameter, and also cut a hole slightly under-sized for the inspection door: From here, I ordered 25 feet (15 would've been plenty, but I make mistakes and wanted extra) of X-1015 U-channel, for both the outer edge of the cover and the inner edge of the inspection hole: http://www.britechindustries.com/uchannels/ We then drilled 8 holes for fasteners, 1/4" in from the outer edge (to sit dead center on the U-channel), and 22.5 degrees offset from center (of the front of the car, offset because of the chassis supports behind the diff and in front of the tail lights). We also drilled 4 holes for the inspection cover: Then we placed the cover in the hatch, and drilled matching holes through the recessed area of the sheet metal. From here, we slowly worked the trim around the outer edge of the cover: We then lifted the trim up at the edges just enough to locate a punch on top of the rubber, and punched out matching holes on the top and bottom of the trim, and also fitted the trim on the inner portion of the inspection hole. From here, it was just a matter of placing the cover back in the hatch, lining up the fastener holes, and slowly working the fasteners down through the cover: Lastly, we had to fabricate tiny pieces of aluminum risers (~1/4") for the inspection door, to sit on top of the cover and below the hinges on the door. This allowed the hinges to sit nearly flush, and most importantly allowed the door to be elevated just ever so slightly, so that the latching mechanism actually had tension against the U-channel rubber and would latch appropriately: As a happy coincidence, the new "3rd Z tool door" happens to sit almost dead centered with the factory ones, as the cell sits as far to the passenger side and as far forward (weight distribution) as possible: It could use another paint-job to try to clean up some of the flashing, but all in all I'm extremely happy with it. It should be both air and water tight, and provides as-good sound dampening as the original spare tire well. There's also the matter of all the original fuel hose holes (I can't believe it was even legal to run them into the hatch area, considering it isn't isolated from the driver's cabin). I used this kit, which worked to plug up ALL of them, except for the original fill hole: http://www.ebay.com/itm/221225241137?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Picture for reference as the auction will inevitably end: For the original fuel fill hole, we'll just be making a small square cover, and using the original 3 bolt holes to fasten it down... and that should be that! Please feel free to ask or PM me any questions, happy to help any Z owners to sort through this daunting task!
From the album: Fuel cell cover
