Search the Community
Showing results for tags 'throttle body'.
	Hello everyone. I'm going to jump right in. I just installed a new motor. Fully stripped of emissions except charcoal canister. Cold start delete. Bcddd deleted and plugged. EGR delete. All new vacuum lines. New plugs E3's /wires MSD 7mm. New fuel pump (95psi) regulated to 35psi on rail, and filters before and after. Clean grounds. New battery, starter, alternator. Clean connections on injectors. All injectors were bench tested and contacts cleaned w/ new gaskets. Vacuum tested @ 17. New Fidanza flywheel installed with exedy clutch. The issue: Car starts right up strong. Will rev to 3k decent. If I hammer throttle it backfires out the exhaust. I have played with the AFM because both units I have already been played with. I have calibrated one using the guide on Atlanticz.ca and everything went well. On reinstall, the car would not start. I had to tighten the clock spring on afm for it to run again. Now it is soo tight I am afraid to go any further. If I hold extra tension on the AFM it runs beautiful and smooth to 6.5k easy. What else can/should I do to correct this issue? Open to all suggestions.
- 8 replies
		- throttle body
- throttle
- (and 5 more)
	The link for modifying a 240sx throttle body is no longer available. Can someone please explain the steps to modify it to work with the stock throttle linkage? I was in the middle of modifying my own a couple weeks ago and now the webpage is gone.
	I have an L24 with SU carbs. I've had this idea of the ability to go from carbs to EFI and back relatively easily.This would require a bolt on replacement for the carbs. I'd still be using the stock intake runners and air cleaner. I'd also try to keep the TBs the same length as the carbs. This is what I've doodled so far. This uses a compact EV14 injector: http://www.bosch-motorsport.de/media/catalog_resources/Injection_Valve_EV_14_Datasheet_51_en_2775993867pdf.pdf Some fuel rail I found the dimensions of: http://www.rossmachineracing.com/images/large/dash8wire.jpg And the flange patterns from the SUs. This drawing lacks stuff still. The idle air intake, I figure, could go on the sides of the TBs facing each other and be plumbed to a T where one adjustment screw handles both the TBs idle. The placement of the injector is arbitrary. I just plopped it there and it worked out that the fuel rail doesn't interfere with the stock air cleaner (orange line). It's angle's just 45*. I'm not sure how evenly the fuel would be distributed down the 3 asymmetrical runners with this set up. Probably over thinking that though. The placement of the throttle plate is arbitrary as well. I've merely spaced it 1 cm from the flange to provide room for bolting on the air cleaner. These should retain most of the stock throttle linkage too. This drawing also assumes that both the front and rear of the SUs are 44 mm inside diameter and coaxial. I'm not sure about this. I know next to nothing about injectors. According to some megasquirt literature though; If I want the capability to fuel around 150 HP then I need 2 injectors around 500 cc/min each. Any reasons why this might not be feasible?
- 19 replies
		- fuel injection
- efi
					(and 7 more)
					Tagged with:
