lubu Posted November 14, 2011 Share Posted November 14, 2011 Does anyone know what Z those cvs came from? They look a bit long for the 280zxt's, Im thinking of the z31 NA cvs but Im not sure, could be z32? The reason I ask is I want to source the bolts for the cv to the flange. Thanks Quote Link to comment Share on other sites More sharing options...
nullbound Posted November 14, 2011 Share Posted November 14, 2011 They appear to be 280zxt, but it's hard to tell from a picture. Measure the length to know for sure which axles they are. Read this page for length info on the 280zxt and 300zx axles: http://zhome.com/rnt/FordPower/HalfShaft.html Quote Link to comment Share on other sites More sharing options...
inline6 Posted November 15, 2011 Share Posted November 15, 2011 Those are 280zx ones. These are z31: z31 axles Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted November 15, 2011 Share Posted November 15, 2011 (edited) I could swear I was post #2 in this thread.....where did it go? Oh musta been at classiczcar....lol Edited November 15, 2011 by cygnusx1 Quote Link to comment Share on other sites More sharing options...
nullbound Posted November 15, 2011 Share Posted November 15, 2011 On 11/15/2011 at 3:19 AM, inline6 said: Those are 280zx ones. These are z31: z31 axles The pic you posted is of z31 turbo axles. The n/a z31 axles look like the 280zx turbo axles, but are longer. Click the link I posted above for more info. Quote Link to comment Share on other sites More sharing options...
lubu Posted November 15, 2011 Author Share Posted November 15, 2011 Thanks guys, I'll confirm after when they are here. As for the bolts, should I order them from Nissan or any high tensile bolts will do? Quote Link to comment Share on other sites More sharing options...
zcarnut Posted November 15, 2011 Share Posted November 15, 2011 On 11/15/2011 at 8:50 AM, lubu said: ... As for the bolts, should I order them from Nissan or any high tensile bolts will do? The bolts are special. They are shoulder bolts with nylon lock nuts. Do not sub! BTW, the easiest way to tell the difference between the 280ZX turbo axle and the Z31 non-turbo axle is the height difference of the dimple on the grease shield. Quote Link to comment Share on other sites More sharing options...
lubu Posted November 15, 2011 Author Share Posted November 15, 2011 On 11/15/2011 at 12:46 PM, zcarnut said: The bolts are special. They are shoulder bolts with nylon lock nuts. Do not sub! BTW, the easiest way to tell the difference between the 280ZX turbo axle and the Z31 non-turbo axle is the height difference of the dimple on the grease shield. Thanks Steve, do you by any chance know the part number for the bolts? Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted November 15, 2011 Share Posted November 15, 2011 (edited) I used high grade studs and bolts frrom McMaster. There are six on each side. They have a HUGE safety factor. You can use a nylock nut, or just some locktite. It's not THAT critical. SEE HERE: http://forums.hybrid...__1#entry276479 Edited November 15, 2011 by cygnusx1 Quote Link to comment Share on other sites More sharing options...
zcarnut Posted November 15, 2011 Share Posted November 15, 2011 On 11/15/2011 at 3:51 PM, lubu said: Thanks Steve, do you by any chance know the part number for the bolts? The part numbers are listed in Pete Paraska's conversion article at http://alteredz.com/240ZCVHalfshaftConversion.htm bolt 39606-W1202 nut 01223-00041 washer 08915-13810 Quote Link to comment Share on other sites More sharing options...
evildky Posted November 15, 2011 Share Posted November 15, 2011 is it just me or do those inboards appear to be for a viscous? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted November 15, 2011 Share Posted November 15, 2011 Just you. Just looking at a pair of inners sitting on a shelf here, they look right to me. Quote Link to comment Share on other sites More sharing options...
inline6 Posted November 17, 2011 Share Posted November 17, 2011 On 11/15/2011 at 4:30 AM, nullbound said: The pic you posted is of z31 turbo axles. The n/a z31 axles look like the 280zx turbo axles, but are longer. Click the link I posted above for more info. Oops. My bad. I stand corrected. Quote Link to comment Share on other sites More sharing options...
