Scottie-GNZ Posted May 20, 2012 Share Posted May 20, 2012 What options are out there for a stock-style barb injector in the 42-50lb flow rate range? Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted May 22, 2012 Author Share Posted May 22, 2012 Nobody? Let me ask a different question: What injectors are folks using on their L28et in the 42-50# range? Quote Link to comment Share on other sites More sharing options...
ozzzzz Posted May 22, 2012 Share Posted May 22, 2012 (edited) On 5/22/2012 at 2:06 PM, Scottie-GNZ said: Nobody? Let me ask a different question: What injectors are folks using on their L28et in the 42-50# range? I bought 36lb/hr from Motor Man Fuel Injection Supply. Call them and tell what you want. They have the larger ones there too. They really know their stuff. Just google Motor Man Fuel Injection Supply. They are bosch and he sent the short hoses and clamps with them and the seal on the manifold side. They are a direct fit for my 81 l28et manifold. Edited May 22, 2012 by ozzzzz Quote Link to comment Share on other sites More sharing options...
Zmanco Posted May 24, 2012 Share Posted May 24, 2012 (edited) I have 437 cc/min Ford injectors from Motor Man that work with the stock fuel rail. I found that in the winter when the rubber shrinks that I needed to add a second set of hose clamps around the injector barbs, but other than that, they've been great. Edit: these are just barely on the low end of the range you listed so may not be big enough for your build. Edited May 24, 2012 by Zmanco Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted May 24, 2012 Share Posted May 24, 2012 I've just installed 440cc/min 7MGTE (Supra) injectors, o-ring type, drive them with MS3. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted May 24, 2012 Author Share Posted May 24, 2012 Do any mods have to be done to the intake to fit the o-ring style injectors? Car has a custom rail, but the barbs can be removed and the holes punched out for the 14mm o-ring on the top of the injectors. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted May 24, 2012 Share Posted May 24, 2012 I made no modifications at all, in fact I used factory 280Z o-rings on the tip end. Because I've not actually run them yet, someone else may be able to make a claim as to how well they work; the tip design is different, and the depth into the runner may be different too. Quote Link to comment Share on other sites More sharing options...
Tony D Posted May 25, 2012 Share Posted May 25, 2012 Mercedes units were 42# and barbed, weren't they? I think that is what JeffP used initially. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted May 26, 2012 Author Share Posted May 26, 2012 Thanks for the feedback guys. Quote Link to comment Share on other sites More sharing options...
letitsnow Posted May 29, 2012 Share Posted May 29, 2012 I'm using a set of 14mm seimens 750's(only that big because they were cheap), I used a pallnet rail and the stock seals in the intake. The injectors form more of a face seal than a diametrical seal that the stock injectors had. Quote Link to comment Share on other sites More sharing options...
75datsun280z Posted June 15, 2012 Share Posted June 15, 2012 Hey guys im new to this site and I was just wondering if anyone can help me I have stock fuel system (I guess you would call.it) and I have up graded everything on my motor but the fuel system except for an after market fuel pump and I was wondering what is the next step for a fuel system ... Quote Link to comment Share on other sites More sharing options...
ARiskyCvt Posted June 15, 2012 Share Posted June 15, 2012 I am here looking for Stock style barb fuel injectors but I want at least 500-600CC. Where would I be able to find anything in this area? My intake manifold will not allow the use o the non barb injectors. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted June 15, 2012 Share Posted June 15, 2012 On 6/15/2012 at 6:08 AM, 75datsun280z said: Hey guys im new to this site and I was just wondering if anyone can help me I have stock fuel system (I guess you would call.it) and I have up graded everything on my motor but the fuel system except for an after market fuel pump and I was wondering what is the next step for a fuel system ... If you are changing injector flow rate, the first step is an aftermarket fuel computer. Quote Link to comment Share on other sites More sharing options...
75datsun280z Posted June 15, 2012 Share Posted June 15, 2012 Thanks alot do you have any good choices on a good fuel computer .... And after the new computer would I need bigger injectors ? where can I get aftermarket fuel injectors and a fuel rail ... thanks Quote Link to comment Share on other sites More sharing options...
75datsun280z Posted June 15, 2012 Share Posted June 15, 2012 By the way does anyone know of an after market intake manifold for a 280z Quote Link to comment Share on other sites More sharing options...
NewZed Posted June 15, 2012 Share Posted June 15, 2012 On 6/15/2012 at 7:07 PM, 75datsun280z said: By the way does anyone know of an after market intake manifold for a 280z You should start your own thread. http://www.urbandictionary.com/define.php?term=Thread%20Jacking Quote Link to comment Share on other sites More sharing options...
