P79 Cam in Turbo engine with stock ECU
Ben's Z
One of the best cams to use in a turbo setup is the early "a" cam, though I don't have first hand experience, just plenty of the gurus here saying so. My point isn't to go find that cam, but rather that using an OEM cam isn't going to kill you or matter all that much. The factory ECU won't run "as well" as it would on the factory cam, but who cares? Right now you just want the thing running, I get that. A NA cam isn't going to make such a huge difference you'll be in danger of breaking something. Just be careful before doing any WOT pulls. Get a wideband on it, even if you have to borrow one, to find out what it's doing under part throttle and low load, and slowly work up the throttle and load once you know it's safe.
People have gotten 300+ hp out of the factory ECU, and I'd love to get more just to prove it can be done. Is it "optimum"? Hell no. But if you went back to the 80's nothing was optimum by today's standards.
  • Replies 46
Posted Images
"I am not doing anything half assed. I have just made the determination to use my 77 280z Cam, because input from the crowd for or against was never answered."
You just aren't looking for the answer. It's there and has been said over and over again: if you are BUYING a cam, don't waste your money on ANY stock cam!
I've see more than one idiot pay more for some supposedly "desirable" USED STOCK CAM than you would pay for a PROPER REGRIND that would net you REAL results.
But there is a slothful ness that has permeated this line of thought from the outset, and dooms the project. Everything being asked about has been discussed. Ad Nauseam. Or it's in any of the basic printed reference material out there everyone building their first engine should have on-hand for the effort.
Gollum nails it once again: it just isn't going to matter that much from one stock Crappy Bumpstick to the next.
You wanna plunk down $100 for a cam, call Isky, get a 460 or 470" lift regrind of the stock cam with slightly altered valve events (closer to N/A than Turbo)--- that grind will be head and shoulders a bone ANY stock cam you can buy from some Dilbert on eBay.
Now, if you're like me, and have a Class 5 Hoarders in the back yard, you COULD experiment quite a bit. IMO there is one word for ANY stock Nissan "JAPAN" Cam: C O R E !
Mr. D, send off any stock cam to Isky and tell them to do that? Once again this is using the factory ECU, at least from the onset. Anyone think Isky could fix that first damaged cam I got before it becomes a table lamp? I could use my 77 cam to get this thing running and put in the reground P90 at a later time.
Thanks again fellas.
Start an anonymous poll thread. Should Ben use the 77 cam or the P90 cam? That way no one gets the blame if it fails later.
You could also call Isky and ask about the cracked dowel pin hole. They might tell you not to worry about the crack and it will be a no-brainer.
  • 1 month later...
Valve lift is different than cam lift, and you're going to get different readings than what is advertised as cam lift on websites, catalogs, etc.
In the pushrod world this is well understood, and people all understand that catalogs are just showing you "cam" specs on cams, because that's what they are... cams. But then you've got your rockers which can be run at various RATIOS, giving more or less aggressive valve lift.
Even the datsun design has a bit of ratio play in the geometry and even how the valve train is setup can effect the overall lift of a cam.
Too bad there are no references on the atlanticz page to tell where the information comes from.  The L28 A cam specs in the table are 0.1 off from the 1978 FSM, so probably not copied from there.  Somebody must have measured or has another document to work from.  0.1 is pretty close though.
One A cam measurement shouldn't be enough to paint the whole table as completely innaccurate though.  That would be some radical extrapolation.
Picture from the 1978 FSM Engine Mechanical chapter:
Oh, I should mention, that if you've really got any of the "A" cams in there, and you're only reading .385 total lift on the valve then you've either got a severely worn cam or you need to work on your rocker geometry quite a bit... it really shouldn't be that low at all.
Are you talking about inches or millimeters? 0.1inches more lift in a cam is very noticeable in drive-ability.
10.4 mm vs. 10.5 mm  - atlanticz table vs. 1978 FSM data.
I thought the topic was about the validity of the data in the atlanticz table, not driveability.  You said the atlanticz table was completely inaccurate and we're trying to determine if that's true or not.
The cam isn't worn... I stated the valve lift figures were inaccurate, not the entire chart. Has anyone here actually measured valve lift or is everyone completely relying on that chart?
We're relying on Nissan's published figures. It's in the FSM, as ZH points out. The atlanticz website is very similar to the FSM's specs.
