Dan_Austin Posted November 26, 2012 Share Posted November 26, 2012 I've been putting off upgrading my alternator since installing a megasquirt this summer, but the end of daylight savings time has also put an end to my procastination. I called a local rebuilder to pick up a 95A Maxima alternator, since the parts stores in this area will not swap pulleys anymore. The shop owner said she was not a fan of the Maxima unit, and suggested a Delco CS130 off an 88-90 Eagle Premeir/Dodge Monaco. It turns out this is a dual foot unit with the mount lugs at 6 &12 like the Nissan unit, and factory rated at 105A and has a lower activation RPM compared to the Maxima alternator. The one I picked up was tested and confirmed to max out at a 117A. The unit required minor wiring tweaks, and slight massaging of the upper bracket, but no major cutting. I skipped the bracket massage and picked up a small turnbuckle at a hardware store, making this a straight bolt in project. Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted November 26, 2012 Share Posted November 26, 2012 pics? Quote Link to comment Share on other sites More sharing options...
Dan_Austin Posted November 26, 2012 Author Share Posted November 26, 2012 I did not snap any as the alternator was dimensionally identical to the 280ZX unit it replaced and the turnbuckle tip was covered in the CS144/AD244 install thread. I can take a couple later tonight and add them to the thread. Quote Link to comment Share on other sites More sharing options...
NewZed Posted November 26, 2012 Share Posted November 26, 2012 Did the shop owner swap the pulleys? The internet says that the Premier/Monaco alternator is a six rib pulley, not v-belt. And, are you just using the S and L pins on the back of the alternator, connected to S and L at the car's T plug? Looks interesting. Thanks for posting an extra option. How is it under low idle speed brown-out conditions - wipers, headlights, and heater on? Here's a useful link for any future modifiers. Napaonline.com shows the pinout for the alt plug along with their product descriptions - http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=RAL134551F_0209469829 Quote Link to comment Share on other sites More sharing options...
Dan_Austin Posted November 26, 2012 Author Share Posted November 26, 2012 (edited) The shop owner did swap the pulley. I went with the large GM pulley, which is similar in diameter to the Nissan. A small GM pulley would have been about 18% faster, but she did not have one in stock. At idle the e-fans would pull the system with the previous alternator down to 11.9V, now it hovers around 13.1, both values taken from the ECU voltage reading and logs. I did not check the lights and other accessories, as the the fans were the biggest draw. And this is at a 750 RPM idle, by 800 RPM voltage is back up to 13.6, so it is a shame the small GM pulley was not available. The correct pins are the S and L (leg of the T). The shop owner recommended not connecting the sense lead, so I have it taped off for the moment, but can connect it if desired. Edited November 27, 2012 by Dan_Austin Quote Link to comment Share on other sites More sharing options...
Josh280z Posted November 27, 2012 Share Posted November 27, 2012 I'd be interested in some pics and part numbers for all this stuff. Quote Link to comment Share on other sites More sharing options...
Dan_Austin Posted November 29, 2012 Author Share Posted November 29, 2012 I can look up the part number for the alternaotr, but finding it by make and model will likely be easier. The turnbuckle and pulley do not have numbers on them. The pulley is just a standard Delco (GM) v-belt, which a decent shop should have on hand. The turnbuckle was a 3/8 X 7.75" OSH special. One small issue to watch for is the battery lug is low and on the inside, putting it fairly close to the lower radiator hose. It cleared by enough not to make me worry, but worth checking. I almost had to retract my positive review today, having major charging issues, but instead is seems a decent alternator can quickly finish off a battery on its last legs. Quote Link to comment Share on other sites More sharing options...
Josh280z Posted November 29, 2012 Share Posted November 29, 2012 Got any pics of the wiring? Quote Link to comment Share on other sites More sharing options...
Dan_Austin Posted November 29, 2012 Author Share Posted November 29, 2012 I replaced the externally regulated alternator for an internally regulated one four years ago using the AtlanticZ write-up, so no photos of that. That leaves four wires on the alternator, the charge and ground leads are self explanitory. The new alternator connector has embossed labeling (PLIS or PLFS), with only the L and S leads used. Connect the top of the T connector to the S lead and the L to the leg of the T. The wires on my T connector has discolored to the point that they look the same, so a photo of them would not help much. Quote Link to comment Share on other sites More sharing options...
NewZed Posted November 29, 2012 Share Posted November 29, 2012 I almost had to retract my positive review today, having major charging issues, but instead is seems a decent alternator can quickly finish off a battery on its last legs. In Post #5 you said that you had left the S wire disconnected on the advice of the shop owner. Are you sure she didn't mean the L wire? With no (S)ense wire the alternator will put out maximum voltage. That might be what fried your battery. Quote Link to comment Share on other sites More sharing options...
Dan_Austin Posted November 29, 2012 Author Share Posted November 29, 2012 The sense wire is now connected, and I think it did help deliver the death blow. On the other hand the battery was a store brand generic I bought five years ago that was plagued with an underperforming ZX alternator for years. Its time had come, and was on my list, I just wish I had replaced it before I had to walk the 1.5 miles to the parts store caring the old battery to be tested and back carrying the replacement. If the lamp was not connected the alternator would not get excited and not charge at lower RPMs. She actually suggested the full time charge full charge, but most of her customers are building ridiculous stereo & lighting systems. Quote Link to comment Share on other sites More sharing options...
Josh280z Posted November 30, 2012 Share Posted November 30, 2012 My general question was did you actually mess with the ZX wiring harness that goes to the alternator... I don't do good without a visual, and lately I've been getting home so late that I cant really see to look at any of this stuff. Quote Link to comment Share on other sites More sharing options...
darkstarrocker Posted February 12, 2013 Share Posted February 12, 2013 I just installed this alternator, and I'm getting crazy headlight dimming at idle from my modest stereo. What size pulley are you using? I'm certain mine is too big, seeing how small the serp. Pulley that came in the alt was. Quote Link to comment Share on other sites More sharing options...
Dan_Austin Posted February 13, 2013 Author Share Posted February 13, 2013 I have about a 2.75" pulley on the alternatoer and the Powerforce damper which is supposed to be about a 6" pulley. I have slight dimming with th idle at 750 RPM, but none at 900 RPM. A stock damper or a 2" alternator pulley would help in my case. I did initially have belt slipage that hurt the idle performance, and once tightened past the point that I thought was too tight idle output was very good. Quote Link to comment Share on other sites More sharing options...
mikeatrpi Posted December 31, 2015 Share Posted December 31, 2015 Bringing this back up to add more info and details to the already excellent information here. I am upgrading an 82 280zx. You can swap the stock 280zx pulley onto the 91 Dodge Monaco alternator and use the same belt. The part number for the pigtail is Dorman 85854. I drilled a bolt through the center and tapped it for a #8 screw to use as the ground lugs from Datsun are pretty small. I also had to file out the main lug since the stud is slightly larger on this alternator. Eventually I'd like to run new wiring back to the battery, but this was the easiest way to get the car back on the road. Quote Link to comment Share on other sites More sharing options...
schicksal Posted January 19, 2016 Share Posted January 19, 2016 mikeatrpi did you crimp the F and L wires together on your harness? I'm trying to do this swap and bought the same pigtail. Quote Link to comment Share on other sites More sharing options...
Dan_Austin Posted December 20, 2016 Author Share Posted December 20, 2016 The CS130 that I installed as part of this write-up died last month. Sadly the local rebuilder I used is no longer in business. I found another who was closer, and who seemed well reviewed. It took several tries to get a workable alternator from them, with most issues being they did not follow instructions about clocking or mount location/spacing. When we got past those issues the results were quite positive, with less voltage swing from idle to higher RPMs. One thing they did get right on the first try was my request for a smaller pulley. I went from a 2.75" to a 2.375", which resulted in charging voltage kicking in between 600 and 650 RPM, so no more dimming headlights while idling at a stop Quote Link to comment Share on other sites More sharing options...
thumper300zx Posted May 25, 2019 Share Posted May 25, 2019 (edited) On 1/19/2016 at 11:45 AM, schicksal said: mikeatrpi did you crimp the F and L wires together on your harness? I'm trying to do this swap and bought the same pigtail. I know this is an old post, but I'm doing this now. I bought Dorman 85854. The black (F) wire I believe should be (and was) just bent over and left unconnected within the shrink wrap. For others, the P designation on the harness/pigtail is empty. SFLP (S: red)(F: black)(L: brown)(P: empty) Edited May 25, 2019 by thumper300zx Quote Link to comment Share on other sites More sharing options...
thumper300zx Posted May 30, 2019 Share Posted May 30, 2019 I finished getting my CS130 alternator installed. Alternator 3335-1222 CarID $75.39 (includes $7.95 shipping) ACDelco® 335-1222 - Professional™ Alternator Dodge Monaco 1991, Professional™ Alternator (335-1222) by ACDelco®. Current: 96 Amp. With 6 Groove Serpentine Pulley. Pulley Size: 56mm. With External Fan. Plug Position: 3:00 O'Clock. ) I bought replacement pulley ($12.99): 10mm Belt x 67mm OD x 17mm Bore (part 2411001). Impact wrench took off alternator nut easily. Quick swap. (Delco 10DN ER/EF; 10SI, 12SI, 15SI, 27SI/Type 100 Series IR/EF) (the smaller [overdrive] unit appears to be 111 PowerMaster 2.35" OD). DORMAN 85854 Voltage Regulator Connector $ 5.24 (rockauto) Got blade connectors on Dorman pigtail. Shrink wrap. Got turnbuckle at Lowes hardware. Picked up a couple thicker fender washers (had to drill them out just a bit for bolts to fit). Replaced rear mount alt bolt with one a bit longer (not enough threads on the one I had before that). Drilled a hole in a bolt and threaded (as described in other posts). Quote Link to comment Share on other sites More sharing options...
