List your Z's specs...
Smnall block chevy ..
350 four bolt main - Filled with concreete
elgin 4340 3.75 stroike crank - 390 cubes with curent over bore..
eagle 4340 H beam rods..
J and E custom piston..
total seal gapless rings..
Dart Conquest aluminum heads with major port work
huge by large 255 at .050 intake 265 at .050 exhaust 633 lift straight across solid roller cam
turbo 350 with 3000 stall
250 horse nos kit..
r-200 limited slip out of 89 300z turbo .. stock half shafts..
235/60/14 m and H race master cheater DOT slicks.
et 9.76 @ 149.6 so far..
  • Replies 67
1974.5 260Z
355 sbc
Edelbrock RPM heads
Edelbrock RPM intake
Holley 600 cfm carb (Edelbrock soon)
Comp Cams lifters and cam
Hooker 2100 block hugger headers
700R4 transmission
Carter 5 psi fuel pump w/o regulator
Powermaster 150 amp alternator
84 Camaro radiator (JTR recommended)
Black Magic FLX-150 fan
FACTORY AC with Chevy compressor
Arizona Z stiffer springs
Koni D shocks all around
Original renewed fuel tank
Cool under this hood!
Dual 2-1/4 exhaust
79 Toyota 4x4 calipers with ZX rotors (front)
79 ZX calipers and rotors (rear)
14" ZX 6 spoke rims
Grant Mohogany steering wheel
MSA strut bar in rear
Polyurethane bushings all around
Top Speed with 3.54 rear end = 167 mph
1972 240Z (red)
383 SBC - Eagle crank, Eagle rods, Edelbrock aluminum heads (straight plug), forged pistons - Ross or Probe with about 9.5:1 compression, Victor RPM intake, Holly Avenger 770 carb, Edelbrock aluminum water pump, roller rockers, Acell billet distributor, Acell 300+ ignition, Flowtech block huggers 15/8ths to 2.5inch pipes to a single 3inch through a Sebring stainless muffler. I'll be adding 2 Dynomax bullets and 13/4 Rewarder headers "soon". Flat tappet hydraulic cam - specs are posted here somewhere. Need to find those specs darn it. Dynoed 300RWHP but I'm pretty sure the secondaries weren't opening. icon_sad.gif
T56 trans, stock style replacement clutch. 3.7 R200LSD diff. Denny's Driveshaft cro-moly driveshaft.
Holly "blue" pump and regulator. Braided -8 to the front.
4coil-over struts (SCCA's stuff) w/Tokico carts. Stock length struts for now.
17X8 Konig 5.0 wheels (5lug) 225/45 Nittos up front 245/45 Nitto 555 drag radials in back
12X1.25 brakes up front w/Outlaw 4piston calipers. 11inch solid rotors in back with Outlaw 2piston calipers. (SCCA's stuff again) We're still working on an E-brake solution.
8pt mild steel cage, Triangle 10gallon aluminum fuel cell. Battery in back in an aluminum box.
Phantom gauges in all stock locations.
Howe radiator, Cobra fan.
Spolier up front, 'glass cowl hood (SubtleZ), MSA 'glass bumpers. Dynamat everywhere.
I think that's it icon_biggrin.gif Not much "stock" left anymore. Have no idea what it'll run. Yet to be done is CVs in back and EFI of some sort. Have a spare intake to modify but may use a different one and have NO idea what ECU to use. Trying to quiet it down right now and get some bugs straightened out...
'85 4.3 V6. 7.5:1 Forged. Cam: CC 232 @ .050 .483, 114degree. Edelbrock performer. Ported stock heads, Manley proflow valves, CC magnum roller rockers, Holley 600 dbl pmpr, Mallory distrib, 140 fuelpump and regulator, MSD 6AL 7000 rpm rev limiter, Fluidamper, ATI 600B Procharger up to 18 psi, 14 right now. Custom made headers, dual 2 1/2 into 3". Tremec aftermarket 6 speed, centerforce dual friction clutch, nodular iron lightweight flywheel. 3.54 200 rear. 16" Centerlines Falken Ziex 205 50/ 225 50.
Getting close to starting round II: 383 sbc Scat lightweight 6", forged rods, AFR 195s, Victor Jr, CC# 12-7771-8 solid 242/248 @ .050, 570/576,110.(this will be the first "off the shelf" cam I've used in 10+ years!) Forged SRP 10.5-11.0:1. Stay tuned!
JS
[ October 09, 2001: Message edited by: John Scott ]
[ October 10, 2001: Message edited by: John Scott ]
10/1970 240 HLS30-10908
Converted: April 1985
Loose Nut Behind The Wheel: 5'10" 170# 46 years old.
Favorite saying: "Sticks and stones will break your bones, but plastic cars will kill you".
Curb Weight in present config: @2440 pounds
Block: Chevy 4 bolt: 010/020 alloy
Bore: 4.031: 355 CID
Compression: nominal: 11.3 to 1
Observed cranking compression: 175 PSI
Decks milled: Squared and parallel to crank
bore, cut to bring pistons .005 out of deck
Head Gaskets: Non brinnelling Felpro PT (ouch $$$$)
Pistons: 4.0285 KB 120 Flat top: 10cc valve relief trough, pressed pins, Skirt clearance .0025
Piston weight: 534 grams
Pin Weight: 144 grams
Rings: 59 grams
Rod: (small end) 170 grams
Rod: (big end) 396 grams
Bearings & oil: 105 grams
Balance weight: 1804 grams
Rods: Stock HD, flash ground, comparative end balanced, ARP rod bolts, Side clearance: .013 to .015
Rod journal to bearing clearance: .0025
Main clearance: .0025 to .003
Crank: Stock steel 020/020 radius ground and balanced
Rings: Hastings Moly: Top gap .020, Second gap: .018
Cam: Hi-Tech 101015: 234/244 @.050 .488/509: degree lobe centers: 107/117 (112)
Dialed (2) degrees early (Intake opening: 12 degrees BTDC @ .050.) Stock lifters
Chain: Cloyes true roller, drilled and buttoned for advance.
Heads: 1991 OEM Corvette Alum "D" ports. Chambers enlarged to 56cc. (They were 53cc out of the box) Intakes unshrouded
Valves: 2.020/1.600 Manley Streetmaster. back cut stems, swirl polished
Porting: Full: Exhausts ports polished
Intake dimensions:Felpro FPP 1205 "small race":1.28 x 2.09.
Intake Volume: 180 cc (after porting)
Valve springs: 1.25 inch Melling
Installed height" 1.700
Seat pressure: 110#
Open pressure: 280#
Rockers: 1.52 Crane Aluminum roller
Intake: Wiand Team "G" Open plenum: match ported to "small race"
Intake spacer: 9/16" aluminum
Carb: 750 CFM 4779 Holley Double pumper: Air horn removed and port smoothed: 50cc primary pump, Edelbrock "PowerPlate" Weber jet externally adjustable primarys.
C.O. Cruise: no load: 1.0%
HC at Idle: 800 PPM
Fuel Octane used: 91 RON Chevron
Moroso Lowrise 14x3 inch Air filter.
Distributer: Mallory Comp 9000 dual magnetic pickup, Mallory 8mm wires, Mallory 692 Highfire, Mallory(3) stage adjustable retard.
Timing: 20 BTDC/36 total: full advance at 2200 RPM.
Headers: 2147 Hooker Supercomp heat coated, full length.
Exhaust: 2.5 inch collectors into Flowmaster street "Y". 3.0 inch out, mandrel bent 3.0 through 3.0x 12.0 inch Walker Race muffler then Edelbrock Stainless flow through with Megs cone finisher.
Trans: Turbo 350
Converter: 9.5 inch GER 3300 stall, anti-ballon plate
Rear gears: 3.54 200mm
Spider pin: Thrust blocked ZX style
Spider Gears: "Lincoln Continental" (Lincoln welder, Continental Air cooled welder motor)
Axels: milled to accept thrust block
Bracket tires: 26x10x15 Hoosier
Street tires: BFG TA R1 on Centerline Convo Pro. 8.5x15
Brakes: Stock Semi-met front & Rear
Best ET: 10.9+ at 129+ (with 700R4 lockup, lasted two years then fried the 3/4 clutches big time)
Best ET: 11.34 at 119 mph (present 350 trans)
Over 600 wrinkle wall burnouts/passes and only one broken U-joint.
Reliability: Outstanding
Throttle response: almost(2) stroke like.
Streetability: Stays cool even on the hottest days of summer. 195 degrees.
Mileage: City: 10-12
Highway: 17-20
Future additions: 125HP Powershot Nitrous. Better ground effects package.
Upgrade to a Valentine.
Guest RON JONES
This is cool.I think We did this a year ago or so,but updates are good!
  • Motor
  • BBC540CI
    • Dart Pro1 345 heads
      • Dart single plane intake
  • Holley 1050 Domanator Preped by Carb Shop
  • Ultrdyne Roller .796/.775
  • Callies 4340 pro crank
  • GRP Aluminum rods
  • Fabracated Moroso oil pan
  • Wiesco 13.7 pistons
  • Jessel belt drive and shaft mounted rockers
  • Trans
  • PG W/trans brake
  • 1.76 J&W Pro gear set
  • Rear End
  • 9" Ford w/4.10 pro gears
  • 35 spline axles
  • Spool
  • Chassis
  • 2X3 Mild steel frame w/12 point cage
  • Stock 280 front suspension
  • 4-link rear w/coil overs
  • Interior
All Aluminum
  • Body
  • All stock w/front air dam
  • Tires
  • Rear 14x32-15 Phoenix slicks
  • front 26x4.5-15 Moroso DS-2
  • Rims
  • Centerline
  • Paint
I am trying to sell the car again,but not for very long.It has been in the National Dragster for sale the last couple weeks and I think it has one more week left.If it doesn't go,its geting painted for sure this winter.
I'm here not much but its a start.
1972 240z Red for the moment
ZZ4 350 Engine (24502609) Specifications
Displacement: 5.7 liters (350 cubic inches)
Horsepower: 355@5.250 rpm
Torque: 405 ft-lb @ 3500 rpm
Bore/Stroke: 4.00" x 3.48"
Compression Ratio: 10:1
Crankshaft: Nodular iron LT4 Corvette Connecting Rods: Forged powdered metal
Pistons: Cast aluminum with offset pins
Camshaft: Hydraulic roller tappet
Valve lift: (Intake/Exhaust): .475"/.510"
Duration (Intake/Exhaust): .208deg./.221deg @.050" tappet lift
Cylinder heads: Cast aluminum (Intake/Exhaust): 1.94"/1.50"
Rocker Arm Ratio: 1.5:1
Distributor: High energy ignition with centrifugal and vacuum advance
Intake Manifold: Dual-plane high rise with d q-jet stage I
Exhaust: Hooker 2001 Block Huggers, Dyno Max 52” sidepipes
Topless, no top, no shell, not a convertible, never rains in Washington
R180 winter project to R200
Turbo 350, Birthday wish a 700R
Rims - Stock 4 spoke, star or what ever they are called, with 205/14/70
Norgskog digital gauges in stock location
B&M megashifter, powermaster mini starter
Shaved door handles
See web site for mor info www.madmanadam.com
Life time project do they ever end? Hope not keeps me young.
Thanks for sharing
Adam
79 280ZX charcoal grey 72 400 s/b chevy 4 bolt mains ported and polished stock heads Edelbrock Performer RPM package,cam,lifters valve springs,750 manual choke carb Crane Enigizer roller rockers,guide plates, Milidon high volume water pump,Griffin radiator,belt fan and electric fan in front. tall Edelbrock Elite valve covers,upgraded HEI ignition and 8.8 wires. Hooker full length headers,dual in /out 2.5 Dynomax muffler w/turndowns Turbo 350 trans w/prostick shifter and shift kit in trans. approx. 380 h.p. mechanical guages B.F. Goodrich drag radials on rear, T/As on front. more to come soon
Did I ever mention that I'm still an Inliner? Stock original 78 280z bought from the original owner. Odometer now shows 180k & still gets 23mpg. A/C works great, 4spd (yea-couldnt believe it was a 78 & still had a 4spd), 3.545 rear w/stock wimpy wheels/tires.
Wish list...377 SBC/T-56 & dido on ScottieGNZ's Corvette rear swap...and cant forget my A/C-gotta have my A/C if/when I get to do the swap; oh yea-dont forget the brakes all points in between.
Did I mention it was still a boneb stock Inliner?
Kevin,
(Yea,Still an Inliner)
"engine RB-26DETT", Geez stony, how did you get a skyline engine? How much was it and where did you buy something like that? Does this mean that your steering wheel is on the right side?
Cool thread, didnt see many inliners here (KEVIN!?) so I figured I would post too.
Suspension/wheels
-Ground control coilovers
-17x8 OZ monte's with 245-40-17 re730 potenzas
-MSA swaybar kit
-Tokico illuminas
-Strut tower bars
-Urathane (of course)
Engine
-L28 turbo
-turbonetics hybrid
-Greddy profec a boost controller
-boost, egt and a/f gauge along with fuel pressure and that crap.
-NPR I/C
-Nissan T5 trans
-3" mandrel exh. with dynomax loud azz muff.
-SX fuel pump/regulator
-Forged lower end with comp at 8.5 to one and bored to 2.95 liters
-SDS management
-audi wastegate on a pipe welded into the stock exhaust manifold.
-Electric fan conversion (painless rules!)
-delco CS130 alternator
Stereo
-Tube driver amps, crossover and line driver
-Behinger DSP8024 (pro audio, but converted to 12v)
-Vifa components in custom kicks
-Clarion 9255 cd player
-Neutrik balanced cables for the TD stuff.
-Audiobahn 12" aluminum cone in the hatch in the spare tire well in a custom glas enclosure.
Well, thats pretty much all im bringing to the table. Just got the alternator working again so its time to finish base tuning and apply some BOOOOST.
This is the second post in the Chevy section I've done - I'm an inliner and will probably stay one - unless I can get an OHC turbo V8 out of the concept stage.
Car: 1978 280Z, bumperless, A/C-less, air dam, 2780lb with me and 3/4 tank.
Engine: L28T, 175k miles, with 270/280 turbo cam.
Turbo: T3/TO4 S-trim, not intercooled (yet), full 2-1/2" exhaust with stainless DP.
Management: Stock fuel system with stock 300ZX ECU and MAS. I got 27 mpg over 250 miles @ 95mph average icon_biggrin.gif.
Cooling: 280ZX oil cooler, 4 row radiator, Permacool electric fan.
Suspension: Eibach progessives, Tokiko non-adjustable struts, solid T/C kit, urethane all around. On Dunlop 225/50/15 Z-rated tires, I pull 1.05G on the road course.
Brakes: 280ZX calipers, 300ZX rotors, stock rear drums.
Drive train: Centerforce II clutch, T-5 tranny, 3.90 open diff with a modified stock mount and urethane bushings.
I finally got into the 14s (14.9 @ 94mph) at 5800' elevation, Bandimere. L28ET is a force to be reckoned with!
[ October 16, 2001: Message edited by: SleeperZ ]
hmm.. My car, which is scattered throughout my house, consists of the following:
76 Datsun 280z
'95 Corvette LT-1
'95 Corvette ZF-6 tranny
Intercooled ATI Procharger
S&S 'full length' headers
An S+W 8pt cage that won't let you in the car unless you remove the steering wheel.
No radiator!
No brakes!
No fuel pump!
No clutch!
No guages!
No body work!
No seats!
No exhaust!
No bumpers!
No airdam!
NO MONEY!
If you're not completely disinterested yet, check it out here:
My 280Z in its earlier, crustier years...
I have an 81 280ZX (One of the few ZX conversions i've heard of...) with a freshly removed l28 trying to wedge in an:
early (lh dipstick) 350 block
flat tops .030 over
dart iron eagle heads
edelbrock performer RPM intake
edelbrock 600 cfm carb 4106
edelbrock cam (don't have specs with me)
HEI Ignition with accell coil and module
TH-350 tranny with B&M Shift kit
Hurst Pro-Matic ratchet shifter
all of this put to the ground through crappy 235 60 14 yokohama's
Engine Info:
- 327 block and forged steel crank and rods w/ SPS rod bolts
- TRW forged flat top pistons and file fit Speed Pro rings
- 1964 "461" casting "double hump" or "Fuelie" heads. Bowl ported, intake matched, 3 angle valve job. Isky heavy duty valve springs, retainers. 2.02/1.60" valves
- Comp Cams hardened pushrods and Pro Magnum 7/16" 1.5 ratio steel roller rockers, 7/16" screw in studs and guide plates.
- This combination gives about 9.7:1 compression ratio.
- Comp Cams Xtreme Energy 274/280 deg. adv. duration (236/240 deg @ 0.050") 0.501/0.510"lift, 110 deg LSA, Solid Lifter Cam
- Holley "Contender" (pn 300-36) hi-rise dual plane intake manifold, port matched. Or Edelbrock Victor Jr.
- Holley 750cfm vacuum secondary carb - blueprinted, accessoried.
- Recurved HEI distributor with Crossfire Cap, HEI BruteThunder Coil, MSD Soft Touch Rev Limiter, MSD 8.5mm Super Conductor Plug Wires, Autolite 303 plugs.
Exhaust:
- Hooker Block Hugger Headers with Stainless Steel/Ceramic coating (along with most of the entire system by Baxter
Custom Engineering)
- 2.5" duals with Dr. Gas X-pipe
- 2 Dynomax Hemi Super Turbo mufflers in stock location (after spare tire well surgery)
Transmission:
Tremec TR-3550 5spd
Blow proof bellhousing
McLeod hydraulic T.O. bearing
Girling 3/4" Master Cyl.
91 Camaro 1LE clutch PP
McLeod dual friction disc
88 300ZX R200, LSD, 3.7:1
280ZX Turbo CV halfshafts
Brake Upgrades Arizona Z Car Wilwood Racing Brakes Front and Rear
Coilovers, Tokico Illumina's, 7/8" front bar, no rear bar
