BluDestiny Posted March 25, 2013 Share Posted March 25, 2013 Has anyone used one of these? I was looking at one of these for my up and coming SR20 build. I've actually been to there store when I was dropping a part off. http://www.compturbo.com/spotlights/oilless Quote Link to comment Share on other sites More sharing options...
sq_creations Posted March 25, 2013 Share Posted March 25, 2013 I don't have personal experiance with them but every review I have read has be positive. There comp wheels are on par with the precision cea wheels. I have seen a few people running them in low mount or rear mount setups on ls1 tech and yellow bullet. Quote Link to comment Share on other sites More sharing options...
NorwegianZED Posted March 25, 2013 Share Posted March 25, 2013 looks good, all i takes is a teny tiny leap of faith i might get myself one of those when my dailydriver turbo fails. i have one reservation only, oil leaks in the turbo is less of a problem than a water leak, at least in my head... or did i miss something important? also, what are the service intervals on greasing the bearings? Quote Link to comment Share on other sites More sharing options...
sq_creations Posted March 26, 2013 Share Posted March 26, 2013 The oil less turbos are basically just a standard comp TBB center, the only big advancement is the addition of a very specific extremely high temperature capable grease that is used to pack the bearing unit with. This is expected to last 5 years or 40-50k miles. The above is quoted from these thread - http://ls1tech.com/forums/forced-induction/1398813-comp-turbo-oilless-turbos.html I would like to add that the water is run through a totally different chamber that doen't contact the shaft. Therefore couldn't leak into the comp or turbine housings. Quote Link to comment Share on other sites More sharing options...
NorwegianZED Posted March 26, 2013 Share Posted March 26, 2013 Great What about service intervalls? Does anyone know? Quote Link to comment Share on other sites More sharing options...
Xnke Posted March 27, 2013 Share Posted March 27, 2013 First post of the linked thread. Not TL;DR. Quote Link to comment Share on other sites More sharing options...
Tony D Posted March 27, 2013 Share Posted March 27, 2013 Maglev Bearings are coming, industrials have used them for years in oil free process compressors. First had maglev power sources that were the size of a Hummer, now the smaller stuff (400hp range) has a maglev power module no bigger than a couple of briefcases. Quote Link to comment Share on other sites More sharing options...
