Time for the 5.3 to get some more power
So the boss man decided today was an optional work day so I brought the z to work and did a little bit of work on it.  Hot side is done other than the down pipe and waste gate exit.  Havent put the radiator in yet so dont even know if it will fit. But will most likely need to be moved forward. Only took about 10 hours to get it done.
Dang that looks awesome!  Hope you wrap the upper radiator hose with a heat shield sleeve, looks like it'll be close!  Awesome fab work though and someday I may add some boost... sub'd
Can't wait for dyno numbers and 1/4 mile times!
Edited by EastTnZ
Got most of the cold side done. Still have to weld in the blow off valve and order a coupler. Other than that just have to take the pieces to work and put the ridges back on so the couplers wont blow off. Now comes the backhalf...................f**k.
Nice work, I wish I had the skills to do that.
