Ryan Merrill Posted September 6, 2013 Share Posted September 6, 2013 I have read that some people are using an LS gas tank in there Datsun's. Has anyone here completed the setup? Pictures how it looks and install info would be most appreciated. Quote Link to comment Share on other sites More sharing options...
SUNNY Z Posted September 6, 2013 Share Posted September 6, 2013 If you're referring to the F Body gas tank, yes. SEVERAL people have done this with success. The main problem is the fuel filler neck is on the wrong side, so you have to turn the tank 180* to maintain functionality. This makes fuel go away from the pump under acceleration. Not sure what problems people are seeing, but for the work involved, I'd sooner do a cell, or a fab'd tank like mine. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted September 6, 2013 Share Posted September 6, 2013 (edited) I modified a stock tank for an internal sump. Actually I paid someone to do it. Works great-no fuel starvation down to empty even at drags. But, I wish I had cut out spare and done a cell. Just simpler in the end. Gives room for dual exhaust, second fuel pick up for future nitrous system and redundant fuel pump. . Edited September 6, 2013 by RebekahsZ Quote Link to comment Share on other sites More sharing options...
Old Man Posted September 6, 2013 Share Posted September 6, 2013 If you're referring to the F Body gas tank, yes. SEVERAL people have done this with success. The main problem is the fuel filler neck is on the wrong side, so you have to turn the tank 180* to maintain functionality. This makes fuel go away from the pump under acceleration. Not sure what problems people are seeing, but for the work involved, I'd sooner do a cell, or a fab'd tank like mine. I'm in the process of installing the plastic fuel tank in my z. The tank is from a 2002 Camaro, and came complete with the fuel pump. Make sure that's how you purchase your tank. These pumps tend to be expensive, so get it with the tank. I believe the 99-02 Camaro/Trans Am have this style of tank. So far it has been very straight forward. Better system as far as set up and fuel delivery also, and the filler neck is on the correct side. There is no need to rotate the tank! As I progress, I have taken pictures and will continue to do so. My tank installation should be complete this Saturday afternoon.(Sept. 7) Once it is complete, I'll be happy to share the pictures with you. Quote Link to comment Share on other sites More sharing options...
Domzs Posted September 6, 2013 Share Posted September 6, 2013 On the F body , at least 98-02 , the fuel filler/door is on the driver side . The Z is on the pass. side , so Sunny Z is correct , you have to turn it 180 . Quote Link to comment Share on other sites More sharing options...
wfritts911 Posted September 6, 2013 Share Posted September 6, 2013 Keep in mind the 98 gas tanks are metal, the fuel filler neck is metal as well and not removable, so unless you hack it off and clamp on rubber hose it is definitely not going to work. I'm running a stock 280Z tank with an external walbro 255 and a corvette filter/regulator. Never had any starvation issues that I know of. -Will Quote Link to comment Share on other sites More sharing options...
The Infidel Posted September 7, 2013 Share Posted September 7, 2013 I used an EFI 280z tank with my swap, I never saw the benefits of using an fbody tank in my car. Quote Link to comment Share on other sites More sharing options...
EastTnZ Posted September 7, 2013 Share Posted September 7, 2013 I used a 15 gallon universal fuel cell and put the fuel cap behind the license plate. If I had the $$ I would've got a custom tank built to fit the factory fuel door. I agree with rebekahsz because I've got 2 -10AN outputs ready for nitrous/power adders and it's new and clean and simple... And as usual you have to cutout the spare tire well. Good luck with your routing and it's easy to hookup the walbro 255 and corvette fpr setup. I just wish my tank was shallower because it shows from behind the car... Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted September 7, 2013 Share Posted September 7, 2013 Ah, a fuel cell hangin low is bad ass! Quote Link to comment Share on other sites More sharing options...
mattd428 Posted September 7, 2013 Share Posted September 7, 2013 Just go fuel cell you will need one if you plan to do big hp and drag race alot. Quote Link to comment Share on other sites More sharing options...
Ryan Merrill Posted September 8, 2013 Author Share Posted September 8, 2013 I have the mustang for a drag car. This car will be setup for road course and street. I'm going to look for a newer camaro gas tank the fuel nice on the correct side. It sounds like a good choice. I want the pump inside the tank as I hate the noise from externals. Anyone have pictures of there setup? Curious of how people held them in place. Quote Link to comment Share on other sites More sharing options...
Phantom Posted September 8, 2013 Share Posted September 8, 2013 (edited) PM DarthZ about the fuel cell he put in his 240Z. It is where the spare goes, is metal, doesn't hang low, holds 17 gallons,and the filler comes out behind the license plate. I'm old school and just stuck with stock 280Z tank and the external fuel pump. BTW -the only time I hear my fuel pump is when I turn the ignition switch to accessory and listen to it pressurize the system. After that I can't hear it. Edited September 19, 2013 by Phantom Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted September 9, 2013 Share Posted September 9, 2013 I understand about your plan, but with a helmet, running hard at rpm, I can't hear my external fuel pump. Quote Link to comment Share on other sites More sharing options...
PLATA Posted September 9, 2013 Share Posted September 9, 2013 (edited) 280Z gas tank on my LS1 240, no issues Edited September 9, 2013 by PLATA Quote Link to comment Share on other sites More sharing options...
